[SOLVED] Sony Tv can't find Serviio
Hank
Post Tue Jan 25, 2011 5:14 pm
Help please. I have installed Servio on my PC and set up music and image content for sharing. I would like to stream this content from my windows PC to my Sony bravia. I can connect the TV to internet but when I search for servers Serviio does not appear in the servers list. My network set up is PC cabled to wireless router - router cabled to devolo home plug - devolo homeplug cabled to Sony. I have set bound ip address to that of the PC.
Hank
Post Tue Jan 25, 2011 5:15 pm
Re: Sony Tv can't find Serviio
Hank
Post Tue Jan 25, 2011 5:35 pm
Hi zip, thanks for the speedy reply, is this what you need.
2011-01-25 17:29:03,250 INFO [WebServer] WebServer starting on port 8895
2011-01-25 17:29:03,250 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-01-25 17:29:03,250 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface 192.168.1.254
2011-01-25 17:29:03,250 ERROR [DiscoverySSDPMessageListener] Cannot open multicast socket
java.net.BindException: Address already in use: Cannot bind
at java.net.PlainDatagramSocketImpl.bind0(Native Method)
at java.net.PlainDatagramSocketImpl.bind(Unknown Source)
at java.net.DatagramSocket.bind(Unknown Source)
at java.net.MulticastSocket.<init>(Unknown Source)
at org.serviio.util.MultiCastUtils.startMultiCastSocket(MultiCastUtils.java:30)
at org.serviio.upnp.discovery.DiscoverySSDPMessageListener.run(DiscoverySSDPMessageListener.java:80)
at java.lang.Thread.run(Unknown Source)
2011-01-25 17:29:03,250 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-01-25 17:29:03,250 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-01-25 17:29:03,250 INFO [EventDispatcher] Starting EventDispatcher
2011-01-25 17:29:03,265 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.sendAlive(DiscoveryAdvertisementNotifier.java:117)
at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.run(DiscoveryAdvertisementNotifier.java:87)
2011-01-25 17:29:08,265 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2011-01-25 17:29:13,265 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2011-01-25 17:29:18,265 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2011-01-25 17:29:23,265 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2011-01-25 17:29:28,265 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2011-01-25 17:29:33,265 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2011-01-25 17:29:38,265 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2011-01-25 17:29:43,265 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2011-01-25 17:29:48,265 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
Cheers Hank
Post Tue Jan 25, 2011 5:37 pm
Is 192.168.1.254 the IP of the PC? If yes, there is already something blocking UDP 1900 port on that address
Hank
Post Tue Jan 25, 2011 5:41 pm
I am sure that 192.168.1.254 is the router.
Post Tue Jan 25, 2011 6:42 pm
So put the IP of your PC into the Bound IP address field (and don't forget to click Save)
Hank
Post Tue Jan 25, 2011 6:51 pm
zip wrote:So put the IP of your PC into the Bound IP address field (and don't forget to click Save)
Already done that. Just did it again to be sure.
Post Tue Jan 25, 2011 6:53 pm
It's not using it, try restarting Serviio, then open console and make sure it displays the proper IP in the field
Hank
Post Wed Jan 26, 2011 9:49 am
zip wrote:It's not using it, try restarting Serviio, then open console and make sure it displays the proper IP in the field
Tryed restarting Serviio, PC ip shows in the bound ip box. Still no connection, aaaaaargh.
Post Wed Jan 26, 2011 10:26 am
can you post the log again?
Hank
Post Wed Feb 23, 2011 5:01 pm
Problem solved.
Hey zip thanks for taking the time to try and solve this issue. Due to work etc. I haven't had the time to deal with this wee problem. However, yesterday I shut off the mains electricity while I replaced a light switch. Last night I switched on the TV to watch a programme on BBCi Player, guess what appeared in the video options? Serviio.
So if any one else has a similar setup to mine and can't get Serviio up and running, try switching off the computer and the sockets with the router and the home plug lan addapters in them, then power it all back up and see if it works. It seems to have worked for me as I have made no changes to my network settings.
kkk222
Post Sat Mar 19, 2011 5:08 am
Re: Problem solved.
Hank wrote:Hey zip thanks for taking the time to try and solve this issue. Due to work etc. I haven't had the time to deal with this wee problem. However, yesterday I shut off the mains electricity while I replaced a light switch. Last night I switched on the TV to watch a programme on BBCi Player, guess what appeared in the video options? Serviio.
Well, this happened to me and now I cannot see Serviio. I've lost power for a little bit and exactly the reverse. I see Windows Media player/server but not Serviio.
Post Sat Mar 19, 2011 7:59 am
Re: Problem solved.
This home plug lan stuff is more trouble than its worth, a ' Decent ' wireless N router will perform better, although will cost you abit more.
