Music cover change
angelspawn
Post Fri Jan 13, 2017 2:13 pm
Music cover change
I would like to know how I can change the media covers as on some files Serviio has taken something wrong.
As example I had ripped some old Kids storys but instead of the real cover it's showing now some nude pics that's not what I want to hand over to my kids.
Any idea how to get Serviio to rescan for the real pictures as Plex and Mediamonkey are showing the right pictures.
Kind Regards
angelspawn
Post Fri Jan 13, 2017 6:11 pm
Re: Music cover change
Serviio does not have a method to modify the library. If you are getting inaccurate metadata from online sources, then you should either check your file naming to ensure it matches what is listed in the online databases, or place the inaccurately identified files in a different location, and deselect retrieving metadata for that location.
If these are not personal videos, then you should ensure the files are named correctly. This page describes proper naming, as well as using the IMDB ID number for difficult to match titles. http://www.serviio.org/index.php?option ... icle&id=12
