Panasonic UHD TV 2016 DXW780 Series
84stangman
Post Fri Apr 15, 2016 4:53 pm
Hello Guys,
I have a newbie question for my TV which is a Panasonic TX-58DXW784 (European 58" 4K Viera)
- I have limited options to select from the profiles the closest to my needs is good with the audio but stretches most of the videos (I presume where transcoding is needed? ) leaving no bar at the top and bottom...
Is there any setting I can change to be able to play AC3/DTS and so on with a normal Aspect Ratio?
Thanks in advance..
Post Fri Apr 15, 2016 10:57 pm
Re: Panasonic UHD TV 2016 DXW780 Series
Which profile are you using?
Have you tried adjusting using the Aspect Ratio button on your remote?
As a test, what happens if you play the movie after setting your tv to use the Generic DLNA profile?
84stangman
Post Sun Apr 17, 2016 10:10 am
DenyAll wrote:Which profile are you using?
Hey There,
adjusting with the button did not help, it just makes the picture smaller, but there is no smart adjustment like in Samsung Devices
As for the Generic DLNA, the aspect ratio is just fine, but then the audio is not playing in most of the cases.... hence I tried the Panasonic profiles :S
Any suggestion I could do?
84stangman
Post Sun Apr 17, 2016 11:04 am
so I chose the 2013 Panasonic profile, and at first the video is good but no audio.
So i change this line, and after this I have audio, but the aspect ratio is wrong.... I don't find it how to set it right DAR does not help either
<!-- remux FLAC/TrueHD in MKV/MP4 to AC3, DTS (MP4) to AC3 -->
<Video targetContainer="mpegts" targetACodec="ac3" aBitrate="384" forceInheritance="true">
<!-- Matches container="matroska" vCodec="h264" aCodec="dca" / --> <!-- Uncomment this line if DTS is not supported natively --> -------------------------------->>>> This one to have sound.
<Matches container="matroska" vCodec="h264" aCodec="dts-hd" />
<Matches container="mp4" vCodec="h264" aCodec="dca" /> <!-- E6 support??, remove this line -->
Post Mon Apr 18, 2016 1:45 am
Try the Panasonic Viera 2010 to see if it fixes the aspect ratio issue.
If it does - you have two choices:
In the Panasonic 2013 profile, keep the change you made (un-commenting that line) and remove the three lines:
This will force the both the video and audio to be transcoded, and should fix the aspect ratio. Remember after changing the profiles.xml file to restart your PC/Serviio service.
OR
Use something like mkvmerge or XMedia Recode to move/add an AC-3 audio track to the file as the first audio stream. This will enable the video to be played natively (without transcoding, which is always better).
herby88
Post Mon Jan 09, 2017 12:19 pm
Hi :)
i'm currently facing the same Problem.
Changing the line in 2013 profile fixed the DTS transcode for me.
Starting a 4k/10bit DTS will also start Video trancode which Ends in to high CPU load :(
found this Profile in some Posts here, but wont get it to work (Validation error).
could i get some help? or add additional lines to the 2013?
Profile:
   <Profile id="vieratx55" name="Panasonic Viera (TX-55)" extendsProfileId="1">
      <!-- Panasonic Viera TX 2015 Models:
      Supports native streaming of mainstream MP4, MKV and XVid files -->
         <!-- Transcode h264 videos with profile level > 4.1 to mpegts with ac3 audio -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" DAR="16:9" targetACodec="ac3" aBitrate="384" forceInheritance="true">
            <Matches container="*" vCodec="h264" profile="high_10" />
            <Matches container="mpeg" vCodec="mpeg1video" />
            <Matches container="matroska" vCodec="vp9" />
            <Matches container="ogg" />
            <Matches container="rm" />
            <Matches container="*" vCodec="h264" aCodec="dca" /> <!-- Uncomment this line if DTS is not supported natively -->
            <Matches container="*" vCodec="h264" aCodec="dts-hd" />
            <Matches container="*" vCodec="h265" aCodec="dts-hd" />
            <!--Matches container="matroska" vCodec="h264" aCodec="flac" / -->
            <Matches container="*" vCodec="h264" aCodec="truehd" />
         <Audio targetContainer="lpcm" forceInheritance="true">
            <Matches container="asf" />
            <Matches container="adts" />
            <Matches container="mpc" />
            <Matches container="ape" />
            <Matches container="dsf" />
         </Audio>
      <GenericTranscoding>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9" aBitrate="384" />
      </GenericTranscoding>
      <Subtitles>
         <SoftSubs mime-type="text/srt" />
      </Subtitles>
      <ThumbnailsResolution>HD</ThumbnailsResolution>
already removed the Detection part, but now Log Reports
2017-01-08 15:52:55,476 ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: cvc-complex-type.2.3: Element 'Video' darf keine Zeichen [untergeordnete Elemente] haben, da der Contenttyp des Typs 'element-only' ist.
2017-01-08 15:52:55,477 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
   at org.serviio.profile.ProfileManager.parseProfilesFromFile(ProfileManager.java:183)
   at org.serviio.profile.ProfileManager.loadProfiles(ProfileManager.java:156)
   at org.serviio.MediaServer.main(MediaServer.java:134)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
   at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:62)
   at com.exe4j.runtime.WinLauncher$2.run(WinLauncher.java:96)
Caused by: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
   at org.serviio.profile.ProfilesDefinitionParser.validateXML(ProfilesDefinitionParser.java:1036)
   at org.serviio.profile.ProfilesDefinitionParser.parseDefinition(ProfilesDefinitionParser.java:162)
   at org.serviio.profile.ProfileManager.parseProfilesFromFile(ProfileManager.java:181)
   ... 8 more
Kind Regards
Herby
herby88
Post Tue Jan 17, 2017 2:48 pm
Hi there,
any working Profile for Pana 2015-16 out there?
Many Posts and views on this and other threads, but no final answer :(
Kind regards
Post Mon Apr 17, 2017 10:00 am
Users browsing this forum: Majestic-12 [Bot] and 25 guests
