Are we able to use a startSSL certificate?
m33ts4k0z
Post Thu Jan 19, 2017 10:32 am
I have a valid SSL certificate issued by startcom and I use it everywhere. I recently found that we can use Serviios media browser over SSL on port 23524 but this uses Serviio's own certificate. Is there a way to change this? Thanks in advance.
Post Fri Jan 20, 2017 8:50 am
Re: Are we able to use a startSSL certificate?
m33ts4k0z
Post Sat Jan 21, 2017 3:15 am
Thanks a lot. It worked. I will create a tutorial on how to do it and you can pin it if you want. It was really easy but it took me some extra minutes because it was on my Synology and I didn't exactly know what to do.
Post Mon Jan 23, 2017 10:57 pm
an article on the wiki would be great, thanks
