Serviio 1.7.1 on QNap - connection refused
avg_joe
Post Thu Dec 29, 2016 11:18 am
I have installed Serviio 1.7.1 on my Qnap NAS TS-410 using the app provided by Qnap.
When I try to access the Serviio setup page on the NAS, in my case http://192.168.1.49:23423/console, I get the error message "ERR_CONNECTION_REFUSED"
Uninstall/re-installing the app does not make any difference, neither is stopping and restarting the services. A quick check using netstat on the NAS showed that there is no service currently using port 23423.
Any suggestion will be greatly appreciated.
Post Fri Dec 30, 2016 9:38 pm
Re: Serviio 1.7.1 on QNap - connection refused
Check the NAS system log, see if the service started
Also chack serviio log files. Easiest is SSHing to the NAS and go to /share/MD0_DATA/.qpk/Serviio (I think)
avg_joe
Post Fri Jan 06, 2017 8:04 pm
Thanks for your help. I cannot find any process called serviio using ps -ef, I presume this means it is not running?
If that's the case, how do I start it manually?
Also, there is no file called serviio (or Serviio) under any of /share subfolders.
Further suggestions?
---- EDIT ----
I have used the following command to start the service:
/etc/init.d/serviio.sh start
Result, however, was not as hoped:
Starting Serviio ... Serviio startup command failed
Still no idea where the Serviio file log would be
avg_joe
Post Sat Jan 21, 2017 6:09 pm
Has anybody got the same problem?
Any suggestion?
Post Mon Jan 23, 2017 11:08 pm
log would be under /share/MD0_DATA/.qpkg/Serviio i think
ianfretwell
Post Mon Jan 30, 2017 8:18 am
I think the problem might be more because that NAS simply isn't up to running the newer version of Serviio - I had a TS412 and couldn't make it run on that either. No issue with more recent models though...
Users browsing this forum: Google [Bot] and 3 guests
