Solved: ServiiGo doesn't show external srt subtitle
m33ts4k0z
Post Mon Jan 23, 2017 7:00 am
I'm having this problem. The srt file that is in the same folder and with the same name as the movie works fine both on my TV and over media browser but when using mx player on Android, I can only see the embedded ones in the movies but not the srt. It used to work before some versions but now that I tried its not working anymore.
Any ideas? Thanks
m33ts4k0z
Post Mon Jan 23, 2017 12:42 pm
Re: ServiiGo doesn't show external srt subtitle
The problem was the httpS. After I connected to the server without https, I got the srt files to stream properly.
Users browsing this forum: Baidu [Spider] and 51 guests
