Serviio file monitoring
Belfaborac
Post Thu Jan 26, 2017 10:49 pm
I'm just wondering how Serviio monitors changes to folders and files. Is this a process of active polling, thereby causing the disk(s) to spin up intermittently, or a passive process which registers that there has been activity in one of the shared folders?
Thanks in advance for enlightening me!
Post Fri Jan 27, 2017 12:12 am
Re: Serviio file monitoring
It is capable of either polling or using the native file system functionality to monitor for changes. Default is to use the native system, but if you are having problems with files being detected you can enable the poller on each shared location.
Belfaborac
Post Fri Jan 27, 2017 10:41 am
Thanks for replying!
I have no problems with file detection, or indeed anything else. However, I'm interested to know if Serviio's default detection method is an active one and causes the drives to spin up at regular intervals, or a passive method which "leaves the drives in peace" so to speak. If it relies on active detection and constantly activates the drives, I would obviously prefer to use the native system, or turn automatic updating off altogether, in order to reduce wear and tear.
Post Fri Jan 27, 2017 2:06 pm
Yep, native is the default, so you should be fine.
Belfaborac
Post Fri Jan 27, 2017 7:55 pm
In other words, the native method is one of passive monitoring which will not spin up the drives? If so, excellent.
