renderers not detected
coredump
Post Sat Feb 04, 2017 1:38 pm
after upgrading to 1.8 and doing a clean install most of my devices aren't detected anymore:
2017-02-04 14:18:39,631 INFO [MediaServer] ------------------------------------------------------------------------
2017-02-04 14:18:39,632 INFO [MediaServer] Serviio DLNA media streaming server v 1.8 (rev. cc55b64588cc)
2017-02-04 14:18:39,632 INFO [MediaServer] Petr Nejedly 2009-2015
2017-02-04 14:18:39,632 INFO [MediaServer] http://www.serviio.org
2017-02-04 14:18:39,632 INFO [MediaServer] Java 1.8.0_101-Oracle Corporation amd64
2017-02-04 14:18:39,632 INFO [MediaServer] OS Linux 3.10.0-514.6.1.el7.x86_64
2017-02-04 14:18:39,632 INFO [MediaServer] File encoding: UTF-8
2017-02-04 14:18:39,666 INFO [MediaServer] Headless mode enabled: true
2017-02-04 14:18:39,666 INFO [MediaServer] User: serviio
2017-02-04 14:18:39,667 INFO [MediaServer] User home dir: /opt/serviio
2017-02-04 14:18:39,667 INFO [MediaServer] Temp dir: /tmp
2017-02-04 14:18:39,667 INFO [MediaServer] ------------------------------------------------------------------------
2017-02-04 14:18:39,673 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2017-02-04 14:18:39,679 INFO [DatabaseManager] Using DERBY database language
2017-02-04 14:18:41,524 INFO [WebServer] Socket buffer set to 65535 bytes
2017-02-04 14:18:41,524 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2017-02-04 14:18:41,526 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2017-02-04 14:18:41,528 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2017-02-04 14:18:41,528 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
2017-02-04 14:18:41,656 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/cds) exposed on port 23424
2017-02-04 14:18:41,656 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/mediabrowser) exposed on port 23424
2017-02-04 14:18:41,656 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/cds) exposed on port 23524
2017-02-04 14:18:41,656 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/mediabrowser) exposed on port 23524
2017-02-04 14:18:41,707 INFO [MediaServer] ------------------------------------------------------------------------
2017-02-04 14:18:41,707 INFO [MediaServer] License: PRO (NORMAL, id: 63a7a146-63af-4835-8c34-5fed4ae8ac90)
2017-02-04 14:18:41,724 INFO [Device] Created UPnP Device with UUID: e20c74f7-16b9-357e-a5c8-c54bdc2c6714, bound address: 192.168.100.76
2017-02-04 14:18:41,875 INFO [TrakttvService] Started trakt.tv sync updater
2017-02-04 14:18:41,876 INFO [TrakttvService] Started trakt.tv scrobble poster
2017-02-04 14:18:41,897 INFO [FileDeltaWatcher] Using 'sun.nio.fs.LinuxWatchService' for delta scan
2017-02-04 14:18:42,028 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2017-02-04 14:18:42,045 INFO [CustomisationManager] No customisation properties found
2017-02-04 14:18:42,065 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2017-02-04 14:18:42,073 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2017-02-04 14:18:42,075 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2017-02-04 14:18:42,075 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2017-02-04 14:18:42,076 INFO [ProfilesDefinitionParser] Added profile 'Playstation 4' (id=ps4)
2017-02-04 14:18:42,076 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2017-02-04 14:18:42,077 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2017-02-04 14:18:42,077 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2017-02-04 14:18:42,078 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (J-series)' (id=sam_j)
2017-02-04 14:18:42,078 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2017-02-04 14:18:42,079 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2017-02-04 14:18:42,079 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2017-02-04 14:18:42,080 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2017-02-04 14:18:42,081 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2017-02-04 14:18:42,081 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2017-02-04 14:18:42,082 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2017-02-04 14:18:42,082 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2017-02-04 14:18:42,082 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2017-02-04 14:18:42,083 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2017-02-04 14:18:42,083 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2017-02-04 14:18:42,083 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2017-02-04 14:18:42,088 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2017-02-04 14:18:42,088 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2017-02-04 14:18:42,088 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2017-02-04 14:18:42,088 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2017-02-04 14:18:42,089 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2017-02-04 14:18:42,089 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2017-02-04 14:18:42,089 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2017-02-04 14:18:42,089 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2017-02-04 14:18:42,090 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2017-02-04 14:18:42,090 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2017-02-04 14:18:42,090 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2017-02-04 14:18:42,091 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2017-02-04 14:18:42,091 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2017-02-04 14:18:42,091 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2017-02-04 14:18:42,091 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2017-02-04 14:18:42,092 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2009)' (id=viera2009)
2017-02-04 14:18:42,094 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2017-02-04 14:18:42,094 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2017-02-04 14:18:42,094 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2017-02-04 14:18:42,095 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2017-02-04 14:18:42,095 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2017-02-04 14:18:42,095 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2017-02-04 14:18:42,095 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2017-02-04 14:18:42,095 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2017-02-04 14:18:42,096 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2017-02-04 14:18:42,096 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2017-02-04 14:18:42,096 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2017-02-04 14:18:42,096 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2017-02-04 14:18:42,097 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2017-02-04 14:18:42,118 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2017-02-04 14:18:42,118 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2017-02-04 14:18:42,119 INFO [ProfilesDefinitionParser] Added profile 'Android' (id=android)
2017-02-04 14:18:42,119 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2017-02-04 14:18:42,119 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2017-02-04 14:18:42,119 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2017-02-04 14:18:42,120 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2017-02-04 14:18:42,120 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2017-02-04 14:18:42,120 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2017-02-04 14:18:42,120 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2017-02-04 14:18:42,121 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2017-02-04 14:18:42,140 INFO [PluginCompilerThread] Looking for plugins at /opt/serviio/plugins
2017-02-04 14:18:42,140 INFO [PluginCompilerThread] Started looking for plugins
2017-02-04 14:18:42,141 INFO [UpdateChecker] Checking if a new version is available
2017-02-04 14:18:42,168 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg
2017-02-04 14:18:42,169 INFO [FFMPEGWrapper] FFmpeg details: [version=2.6.8, libRtpmPresent=false, libAssPresent=true, libShinePresent=false, libMxfPresent=false]
2017-02-04 14:18:42,180 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2017-02-04 14:18:42,187 INFO [WebServer] WebServer starting on port 8895
2017-02-04 14:18:42,187 INFO [Device] Updated bound IP address of Device with UUID: e20c74f7-16b9-357e-a5c8-c54bdc2c6714, bound address: 192.168.100.76
2017-02-04 14:18:42,195 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2017-02-04 14:18:42,195 INFO [EventDispatcher] Starting EventDispatcher
2017-02-04 14:18:42,195 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2017-02-04 14:18:42,196 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface enp2s0 (enp2s0) and address 192.168.100.76, timeout = 0
2017-02-04 14:18:42,198 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2017-02-04 14:18:42,198 INFO [RendererSearchSender] Starting Renderer searcher process
[root@barney log]# tail -f serviio.log
2017-02-04 14:19:02,201 INFO [FeedUpdaterWorker] Started looking for information about online resources
2017-02-04 14:19:02,201 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2017-02-04 14:19:02,218 INFO [LocalLibraryManager] Starting automatic library scan
2017-02-04 14:19:02,219 INFO [LibraryDeltaScanner] Starting the library delta scan
2017-02-04 14:19:02,221 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2017-02-04 14:19:13,053 WARN [RendererManager] Error while retrieving renderer description: Read timed out
2017-02-04 14:19:43,089 WARN [RendererManager] Error while retrieving renderer description: Read timed out
2017-02-04 14:20:13,121 WARN [RendererManager] Error while retrieving renderer description: Read timed out
2017-02-04 14:20:43,154 WARN [RendererManager] Error while retrieving renderer description: Read timed out
2017-02-04 14:21:13,187 WARN [RendererManager] Error while retrieving renderer description: Read timed out
2017-02-04 14:21:43,201 WARN [RendererManager] Error while retrieving renderer description: Read timed out
Post Sun Feb 05, 2017 12:13 pm
Re: renderers not detected
Is this network interface right?
coredump
Post Sun Feb 05, 2017 6:08 pm
Hi Petr,
for sure the interface is up and running:
enp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.100.76 netmask 255.255.255.0 broadcast 192.168.100.255
ether 00:01:2e:4e:f9:b8 txqueuelen 1000 (Ethernet)
RX packets 275609531 bytes 365812032484 (340.6 GiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 262640373 bytes 166697701055 (155.2 GiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
The funny thing is that some WIFI based devices are detected, some not. All wired devices are detected properly. It seems that at least all Android devices (4.x/6.x) are affected, Chromecast, Pure Flow and Philips2010 as well. Amazon Fire TV stick however works. The working fire stick is not pinging faster than the other affected WIFI devices. I'm running several WIFIs and it is not related to any dedicated access point. Looks either like kind of timeout or serviio protocol error. Not sure whether it makes sense to check with Wireshark as 1.6.1 is working properly. No firewalls are in use between server and end devices.
drMARTINS
Post Tue Jul 11, 2017 9:16 pm
I can confirm.
I have same problem.I use ios and vlc or infuse player
edit: after downgrade to 1.7.1.1 everything is ok again
xentaur
Post Sat Aug 26, 2017 10:48 am
Hi
Having same issue on 1.8 on ubuntu 16.04.
Is this rectified on v1.9?
I had no issues with devices being recognised when I used to run serviio on XP. Since switching to ubuntu 16.04 I've noticed a lot of the time I need to turn my PS3 and PS4 on and then restart serviio for the playstations to show serviio. Under XP serviio seemed to recognise new devices had joined the network any time I switched them on, without the need to restart serviio. It seems on ubuntu that serviio will check at startup only for devices and not continue to check intermittently if new devices have joined since startup.
Could the renderers not detected error be a timeout issue? It's frustrating me moreso that my kids keep hassling me that their consoles can't find serviio.
Any help appreciated.
Many thanks
coredump
Post Sun Aug 27, 2017 2:47 pm
Seems that the issue was solved in 1.9 at least for me running Centos 7.3
No more errors so far.
Return to User experiences
