[question] how to delete or modify files in remote
unecc
Post Mon Feb 06, 2017 9:09 am
Hi to all, i m asking if serviio permit to delete or modify file shared in remote without other 3th part apps.
Tnx
Post Mon Feb 06, 2017 11:59 am
Re: [question] how to delete or modify files in remote
No, Serviio has no file maintenance functionality. To add or remove media, you must do it via computer. If Serviio is running on a computer, you must do it at that computer, unless you have access to the shared file locations from another computer. If Serviio is running from a NAS device, then you have to use a computer with access to the NAS.
