Connect to Media Browser without IP Address?
rumplestiltskin
Post Sun Feb 12, 2017 3:55 pm
My Serviio server is currently configured with DHCP. The Roku's on my network have no trouble finding it. As I'm not going to be accessing the server from outside my LAN, a static IP address didn't seem to ne necessary.
However, if I use a web browser on one of my computers to connect to the Serviio machine, it seems I need to know its IP address in order to enter it into the URL:
http://192.168.1.81:23424/mediabrowser/ ... title=Home
(currently the IP address of the Serviio machine)
But is there some sort of alias or other name I might use in place of the IP or do I just need to set a static IP for the server? I'm looking for a simple solution and, if static is it, then okay.
I will add that VLC (probably because it's using DLNA) on my Mac can connect through discovery. I checked for a Firefox add-on but no luck.
Thanks,
Barry
Post Mon Feb 13, 2017 1:55 am
Re: Connect to Media Browser without IP Address?
On most home networks, the computers are all accessible with their computer name. I have static IPs on my servers, but I use their computer name to connect to the console or MediaBrowser. For me, it's just server:23434/mediabrowser or media:23423/console. Of course, that only works inside my firewall.
Now, of your computer name is long or convoluted, then the IP address might be easier. If you don't want to set a static, at least set a DHCP reservation in your router so it always gets the same IP address via DHCP.
freaknik
Post Mon Feb 13, 2017 1:57 am
x2 for router designation.
Use static ip for server. You can have dhcp on in the router and set it up to assign ip staticly to a certain mac address. That's what I do, all my pcs are dynamic ips except the serviio server, and my bluray player, those are static, makes life easier.
