Unwanted changes since clean install of Windows 7
Shazzaroonii
Post Tue Feb 14, 2017 2:20 pm
Hi, hoping you can help. I've tried to find the answer, only been able to find the question (on another website) with no answer.
I've recently done a clean install of Windows 7 and since then, Serviio has not been how it was before. Before, on both tvs, it would show up as a 'stand-alone' via source. Now, on one tv, it's showing up as DNLA and on the other as ALLSHARE, and it's not working as well as before. I've just installed Java, updated Kaspersky and the router with the applicable ports...any idea what I've missed? This is what I got from my log.
2017-02-15 01:00:29,526 INFO [WebServer] WebServer starting on port 8895
2017-02-15 01:00:29,777 INFO [Device] Updated bound IP address of Device with UUID: 123d7bcc-2376-3cd4-8e05-366468b3824b, bound address: 192.168.1.107
2017-02-15 01:00:29,777 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2017-02-15 01:00:29,777 INFO [EventDispatcher] Starting EventDispatcher
2017-02-15 01:00:29,778 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2017-02-15 01:00:29,778 INFO [RendererSearchSender] Starting Renderer searcher process
2017-02-15 01:00:29,810 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.107, timeout = 0
Post Tue Feb 14, 2017 9:55 pm
Re: Unwanted changes since clean install of Windows 7
I also recently did a clean install on Windows 7, and didn't encounter this problem. Could you zip your complete log up and post it here as an attachment? There's some startup lines in the log that I'd like to compare to mine to see if something jumps out. It would be fine to remove any part of it after it loads the profiles, as Serviio is fully up and running by then and I don't need to see it scanning your locations or any file titles.
Shazzaroonii
Post Tue Feb 14, 2017 11:03 pm
Thanks for the reply, attaching hopefully what you asked for :)
serviio ZIP.zip
(1.69 KiB) Downloaded 466 times
Post Wed Feb 15, 2017 12:58 am
Shazzaroonii wrote:Thanks for the reply, attaching hopefully what you asked for :)
Close, but not quite. Yes, this is the log, but I would like to see the section before the profiles are loaded. That goes from initial load through the profile additions, which as included here. Basically, look at what you provided here, and give me everything before what you have as the last line, which says "Starting automatic library scan."
Shazzaroonii
Post Wed Feb 15, 2017 3:45 am
I must be missing something, because I think that was from the start of that log. Here is another log, hope that helps?
serviio zip 2.zip
(13.85 KiB) Downloaded 490 times
Post Wed Feb 15, 2017 1:34 pm
That is still not the beginning section of the log. I see you have debug enabled, which makes the logs extremely large. By default the log file is cut off at 500 KBs and a new log file is started. You likely see a bunch of files, but only one ends in .log. The rest have a number at the end. One of those was the opening log.
Stop the Serviio service, delete all the files in the Log folder, then restart the service, wait about 60 seconds, then stop the service again. That should keep the file small enough that everything is there. Or you can go to the config folder and edit the log config file to allow larger files. I'm not at home right now, so I can't quote exactly where to edit that file. Don't change anything if you're unsure what to edit.
Shazzaroonii
Post Thu Feb 16, 2017 2:11 am
Thank you for your patience, I appreciate it :D Now I know I've been doing the logs wrong, still not sure if I have what you're looking for, but I've added 2 more.
serviiomore.zip
(1.85 KiB) Downloaded 478 times
serviio.zip
(3.79 KiB) Downloaded 492 times
Post Fri Feb 17, 2017 2:22 am
Still not seeing the initial load. Here's a copy of a debug log I did a few months ago. This shows the lines I'm looking for:
2016-12-28 17:13:22,305 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2016-12-28 17:13:22,315 INFO  [MediaServer] ------------------------------------------------------------------------
2016-12-28 17:13:22,315 INFO  [MediaServer] Serviio DLNA media streaming server v 1.8 (rev. cc55b64588cc)
2016-12-28 17:13:22,315 INFO  [MediaServer] Petr Nejedly 2009-2015
2016-12-28 17:13:22,315 INFO  [MediaServer] http://www.serviio.org
2016-12-28 17:13:22,315 INFO  [MediaServer] Java 1.8.0_91-Oracle Corporation x86
2016-12-28 17:13:22,315 INFO  [MediaServer] OS Windows 7 6.1
2016-12-28 17:13:22,315 INFO  [MediaServer] File encoding: windows-1252
2016-12-28 17:13:22,365 INFO  [MediaServer] Headless mode enabled: true
2016-12-28 17:13:22,365 INFO  [MediaServer] User: MEDIA$
2016-12-28 17:13:22,365 INFO  [MediaServer] User home dir: C:\Windows\system32\config\systemprofile
2016-12-28 17:13:22,365 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2016-12-28 17:13:22,365 INFO  [MediaServer] ------------------------------------------------------------------------
2016-12-28 17:13:22,365 DEBUG [MediaServer] Runtime params: -Dexe4j.semaphoreName=Local\c:_program_files_pc5dczc_bin_serviioservice.exe0, -Dexe4j.isService=true, -Dexe4j.moduleName=C:\Program Files\Serviio\bin\ServiioService.exe, -Dexe4j.tempDir=C:\Windows\TEMP\e4j84EA.tmp_dir1482973999, -Dexe4j.unextractedPosition=413627, -Djava.library.path=C:\ProgramData\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\AMD\ATI.ACE\Core-Static;C:\Program Files\FileBot\;C:\ffmpeg;;c:\program files\serviio\jre\bin, -Dexe4j.consoleCodepage=cp0, -Xms20M, -XX:+UseG1GC, -XX:GCTimeRatio=1, -XX:MinHeapFreeRatio=10, -XX:MaxHeapFreeRatio=20, -Djava.net.preferIPv4Stack=true, -Djava.awt.headless=true, -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade, -Dserviio.home=C:\Program Files\Serviio\bin\\.., -Dderby.system.home=C:\Program Files\Serviio\bin\\..\library, -Xmx512m, -Xrs
2016-12-28 17:13:22,385 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2016-12-28 17:13:22,415 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2016-12-28 17:13:22,425 INFO  [DatabaseManager] Using DERBY database language
2016-12-28 17:13:23,481 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2016-12-28 17:13:23,481 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2016-12-28 17:13:23,481 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2016-12-28 17:13:23,481 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2016-12-28 17:13:23,481 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2016-12-28 17:13:23,481 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2016-12-28 17:13:23,481 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2016-12-28 17:13:23,481 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2016-12-28 17:13:23,481 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2016-12-28 17:13:23,481 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2016-12-28 17:13:23,481 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2016-12-28 17:13:23,481 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2016-12-28 17:13:23,481 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2016-12-28 17:13:23,481 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2016-12-28 17:13:23,491 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2016-12-28 17:13:23,491 DEBUG [DBLogDAOImpl] Checking if script 'script-1.3.sql' has been run
2016-12-28 17:13:23,491 DEBUG [DBLogDAOImpl] Checking if script 'script-1.4.sql' has been run
2016-12-28 17:13:23,491 DEBUG [DBLogDAOImpl] Checking if script 'script-1.5.sql' has been run
2016-12-28 17:13:23,502 DEBUG [DBLogDAOImpl] Checking if script 'script-1.6.sql' has been run
2016-12-28 17:13:23,503 DEBUG [DBLogDAOImpl] Checking if script 'script-1.7.sql' has been run
2016-12-28 17:13:23,504 DEBUG [DBLogDAOImpl] Checking if script 'script-1.8.sql' has been run
2016-12-28 17:13:23,833 INFO  [WebServer] Socket buffer set to 65535 bytes
2016-12-28 17:13:23,833 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2016-12-28 17:13:23,843 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2016-12-28 17:13:23,843 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2016-12-28 17:13:23,843 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
2016-12-28 17:13:24,375 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/cds) exposed on port 23424
2016-12-28 17:13:24,375 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/mediabrowser) exposed on port 23424
2016-12-28 17:13:24,375 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/cds) exposed on port 23524
2016-12-28 17:13:24,375 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/mediabrowser) exposed on port 23524
2016-12-28 17:13:24,415 DEBUG [LicensingManager] Updating license
2016-12-28 17:13:24,425 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2016-12-28 17:13:24,445 DEBUG [LicenseValidator] Validating license file (370 bytes)
2016-12-28 17:13:24,535 INFO  [MediaServer] ------------------------------------------------------------------------
2016-12-28 17:13:24,535 INFO  [MediaServer] License: PRO (NORMAL, id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx)
2016-12-28 17:13:24,545 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2016-12-28 17:13:24,825 INFO  [Device] Created UPnP Device with UUID: f9b00e1b-a55b-3c2f-b101-b7731030fd1d, bound address: 192.168.0.5
2016-12-28 17:13:25,321 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2016-12-28 17:13:25,321 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2016-12-28 17:13:25,351 INFO  [CustomisationManager] No customisation properties found
2016-12-28 17:13:25,391 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2016-12-28 17:13:25,391 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2016-12-28 17:13:25,401 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2016-12-28 17:13:25,401 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2016-12-28 17:13:25,411 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2016-12-28 17:13:25,411 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2016-12-28 17:13:25,411 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2016-12-28 17:13:25,411 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile ps4
2016-12-28 17:13:25,411 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 4' (id=ps4)
2016-12-28 17:13:25,411 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2016-12-28 17:13:25,411 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2016-12-28 17:13:25,411 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2016-12-28 17:13:25,431 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2016-12-28 17:13:25,431 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_h
2016-12-28 17:13:25,431 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2016-12-28 17:13:25,431 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_j
2016-12-28 17:13:25,431 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (J-series)' (id=sam_j)
2016-12-28 17:13:25,431 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_ef
2016-12-28 17:13:25,431 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2016-12-28 17:13:25,431 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2016-12-28 17:13:25,431 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2016-12-28 17:13:25,431 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2016-12-28 17:13:25,431 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2016-12-28 17:13:25,431 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2016-12-28 17:13:25,431 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2016-12-28 17:13:25,431 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2013
2016-12-28 17:13:25,431 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2016-12-28 17:13:25,431 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2013
2016-12-28 17:13:25,441 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2016-12-28 17:13:25,441 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2016-12-28 17:13:25,441 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2016-12-28 17:13:25,441 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2016-12-28 17:13:25,441 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2016-12-28 17:13:25,441 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2016-12-28 17:13:25,441 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2016-12-28 17:13:25,441 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2016-12-28 17:13:25,441 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2016-12-28 17:13:25,441 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2016-12-28 17:13:25,441 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2016-12-28 17:13:25,441 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile tosh2012
2016-12-28 17:13:25,441 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2016-12-28 17:13:25,441 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2016-12-28 17:13:25,441 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2016-12-28 17:13:25,441 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2016-12-28 17:13:25,451 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2016-12-28 17:13:25,451 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2016-12-28 17:13:25,451 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2016-12-28 17:13:25,451 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2016-12-28 17:13:25,452 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2016-12-28 17:13:25,452 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2016-12-28 17:13:25,453 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2016-12-28 17:13:25,453 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2016-12-28 17:13:25,453 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2016-12-28 17:13:25,453 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2016-12-28 17:13:25,453 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2016-12-28 17:13:25,453 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2016-12-28 17:13:25,454 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2016-12-28 17:13:25,454 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2016-12-28 17:13:25,454 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2016-12-28 17:13:25,454 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2016-12-28 17:13:25,454 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2016-12-28 17:13:25,454 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2016-12-28 17:13:25,455 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2016-12-28 17:13:25,455 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2013
2016-12-28 17:13:25,456 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2016-12-28 17:13:25,456 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2016-12-28 17:13:25,457 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2016-12-28 17:13:25,457 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2016-12-28 17:13:25,457 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2016-12-28 17:13:25,457 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2016-12-28 17:13:25,457 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2016-12-28 17:13:25,457 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2009
2016-12-28 17:13:25,457 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2009)' (id=viera2009)
2016-12-28 17:13:25,457 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2016-12-28 17:13:25,457 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2016-12-28 17:13:25,457 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2016-12-28 17:13:25,458 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2016-12-28 17:13:25,458 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2016-12-28 17:13:25,458 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2016-12-28 17:13:25,458 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2016-12-28 17:13:25,458 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2016-12-28 17:13:25,458 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2016-12-28 17:13:25,458 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2016-12-28 17:13:25,459 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile panasonicBDT220
2016-12-28 17:13:25,459 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2016-12-28 17:13:25,459 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile philips_streamium
2016-12-28 17:13:25,459 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2016-12-28 17:13:25,459 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile roku
2016-12-28 17:13:25,459 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2016-12-28 17:13:25,459 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuMPApp
2016-12-28 17:13:25,460 INFO  [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2016-12-28 17:13:25,460 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile YamBD
2016-12-28 17:13:25,460 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2016-12-28 17:13:25,461 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile TNDC
2016-12-28 17:13:25,461 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2016-12-28 17:13:25,461 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile xbox_one
2016-12-28 17:13:25,461 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2016-12-28 17:13:25,461 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile raumfeld
2016-12-28 17:13:25,462 INFO  [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2016-12-28 17:13:25,462 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile Roku4kMPApp
2016-12-28 17:13:25,463 INFO  [ProfilesDefinitionParser] Added profile 'Roku 4K (not TV)' (id=Roku4kMPApp)
2016-12-28 17:13:25,464 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuStickMPApp
2016-12-28 17:13:25,464 INFO  [ProfilesDefinitionParser] Added profile 'Roku Stick Media Player' (id=RokuStickMPApp)
2016-12-28 17:13:25,464 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuTV
2016-12-28 17:13:25,465 INFO  [ProfilesDefinitionParser] Added profile 'Roku TV (non 4K)' (id=RokuTV)
2016-12-28 17:13:25,483 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2016-12-28 17:13:25,483 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2016-12-28 17:13:25,483 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2016-12-28 17:13:25,493 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile android
2016-12-28 17:13:25,493 INFO  [ProfilesDefinitionParser] Added profile 'Android' (id=android)
2016-12-28 17:13:25,493 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile ios
2016-12-28 17:13:25,493 INFO  [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2016-12-28 17:13:25,493 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile html5
2016-12-28 17:13:25,493 INFO  [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2016-12-28 17:13:25,493 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_standard
2016-12-28 17:13:25,493 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2016-12-28 17:13:25,493 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2016-12-28 17:13:25,493 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_hls
2016-12-28 17:13:25,493 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2016-12-28 17:13:25,493 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_gtv
2016-12-28 17:13:25,493 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2016-12-28 17:13:25,493 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile googlecast
2016-12-28 17:13:25,493 INFO  [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2016-12-28 17:13:25,493 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile chromecast
2016-12-28 17:13:25,493 INFO  [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2016-12-28 17:13:25,563 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2016-12-28 17:13:25,563 INFO  [PluginCompilerThread] Started looking for plugins
2016-12-28 17:13:25,563 INFO  [UpdateChecker] Checking if a new version is available
2016-12-28 17:13:25,593 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe
2016-12-28 17:13:25,593 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe
2016-12-28 17:13:25,753 INFO  [FFMPEGWrapper] Found FFmpeg: C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe
2016-12-28 17:13:25,753 INFO  [FFMPEGWrapper] FFmpeg details: [version=3.0.2, libRtpmPresent=true, libAssPresent=true, libShinePresent=false, libMxfPresent=false]
2016-12-28 17:13:25,763 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib\dcraw.exe
2016-12-28 17:13:25,763 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib\dcraw.exe
2016-12-28 17:13:25,985 INFO  [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2016-12-28 17:13:25,985 DEBUG [AbstractAVTranscodingDeliveryEngine] Deleting temporary transcoded files from: C:\Windows\TEMP\Serviio
2016-12-28 17:13:26,045 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2016-12-28 17:13:26,055 INFO  [WebServer] WebServer starting on port 8895
2016-12-28 17:13:26,327 INFO  [Device] Updated bound IP address of Device with UUID: f9b00e1b-a55b-3c2f-b101-b7731030fd1d, bound address: 192.168.0.5
2016-12-28 17:13:26,347 DEBUG [DiscoveryManager] UPNP device f9b00e1b-a55b-3c2f-b101-b7731030fd1d (192.168.0.5) is available
2016-12-28 17:13:26,347 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2016-12-28 17:13:26,357 INFO  [RendererSearchSender] Starting Renderer searcher process
You can see it starts with the server version and Petr's name and web site address. Copy all that until you get past the profiles being added and where the bound address is shown (one of the last lines I pasted here).
Shazzaroonii
Post Fri Feb 17, 2017 9:52 pm
Wow, I have not come across anything like that on my logs (I wonder why not?). I'll give it another go and see if I can find that sort of info. Thanks.
Shazzaroonii
Post Fri Feb 17, 2017 10:02 pm
And of course, now that I've said that, I've found it. Thanks!
Serviioo.zip
(2.13 KiB) Downloaded 501 times
Shazzaroonii
Post Fri Feb 17, 2017 10:05 pm
I wonder if it has anything to do with this "Haven't found any suitable local IP address, will try again 9 times"? If it does, I'm not sure how to fix it :?
Post Sat Feb 18, 2017 1:43 am
Shazzaroonii wrote:I wonder if it has anything to do with this "Haven't found any suitable local IP address, will try again 9 times"? If it does, I'm not sure how to fix it :?
That's an interesting line. While your local IP seems to be identified, I've never seen that before. I hope Zip sees this and can comment. Do you have either a static IP or reserved IP address on the Serviio computer? If not, it's certainly something to consider. Then go to the Status page on the console, and it the bottom change the Network Settings from Auto to the assigned IP address.
Post Sat Feb 18, 2017 7:27 am
That's normal. You often see something similar after your PC awakens from sleep. It just means that Serviio is ready before your NIC has woken up/established link. Its only an issue if you don't get a subsequent "Updated bound IP address of Device with UUID: xxx, bound address: xxx" message.
Can't really help with your problem. I haven't either device but I thought it was the norm for DLNA servers to appear under the "Allshare" menu of Samsung TV's???
In any case I think which menu the Serviio server appears under on your TV would a function of the TV. It's not something Serviio can control. As to why it changed, the only thing I can think of is (a) your devices got a firmware update (both devices - unlikely); or (b) Windows itself was advertising Serviio as shared appliance (do you recall whether Serviio used to appear on both the Sources and the Allshare menus?) that was then being picked up by your renderers.
On a hunch, try :
  • under Control Panel\Hardware and Sound\Devices and Printers double click your device (assuming it is on and appears as a device) and when prompted enable Media Streaming and then allow access to devices. If neither device appears, select a device with a big green play triangle on it (if there is one).
  • if that doesnt work, enable streaming from Windows Media Player (turn it into a Media Server) and see where that shows up on your devices (and if it fixes the issue).
Post Sat Feb 18, 2017 5:57 pm
At least on my Samsung TVs (have a couple) Serviio appears as a separate selectable icon under the media devices. If Windows Sharing is enabled, the same computer appears again with a different icon, and doesn't have the same name that Serviio gives itself. Same on my older Panasonic, and all my other streaming devices (Smart TVs and BD players). The only time I think I've ever seen anything labeled as AllShare was when I tried the Samsung software on my computer. Didn't care for it at all so removed it.
Shazzaroonii
Post Tue Feb 21, 2017 12:22 am
Thanks, I'll give it a go.
Shazzaroonii
Post Thu Feb 23, 2017 10:28 pm
Strangely enough, Serviio on my newer Samsung TV has changed back from AllShare to Network without me even doing anything.
Post Fri Feb 24, 2017 3:09 am
Do not question the magic that is modern electronics! :lol:
Shazzaroonii
Post Fri Feb 24, 2017 9:58 am
:D
Shazzaroonii
Post Mon Feb 27, 2017 1:10 am
It's gone back to AllShare, I've since worked out, that if I leave it on the generic profile, it will stay as Network instead of AllShare (on the newer tv).
Post Mon Feb 27, 2017 3:01 pm
Man, who knows what Samsung has done. On my set, it's just listed as another media source. Oh well... :roll:
Users browsing this forum: Baidu [Spider], Google [Bot] and 15 guests
