Re-Build Library
lad7770
Post Thu Feb 23, 2017 6:29 pm
Re-Build Library
I recently add 3 movies to may folder. This 3 movies wont show on the library, but they can be found and view if I use the search.
I try to force the rebuild of the library without lock.
I like to know if there is some kind of cache that I can clear and try to make Serviio re-build my library
Post Thu Feb 23, 2017 7:56 pm
Re: Re-Build Library
do they show under the Folders category?
lad7770
Post Sat Feb 25, 2017 12:17 pm
No, I only can find them if I do a search
lad7770
Post Tue Feb 28, 2017 3:38 am
Any help would be apreciated. I also found more movies that Servio is not adding to the collection
Post Tue Feb 28, 2017 11:35 am
you'll have to post your log, ideally a detailed log, when trying to add the files.
