Subtitles embedded work but no sound
Kelgtar
Post Sat Mar 04, 2017 10:18 am
Hey guys,
I'm a total noob to serviio. So I used to use the Samsung galaxy mini s3 for viewing my vids and subtitles and sound worked. But now when I try it on my Huawei P8 lite, I get the subtitles but no sound. It says codec unsupported AC3 or something. What can I do?
When I put of subtitles, it works fine the sound
Post Sat Mar 04, 2017 12:07 pm
Re: Subtitles embedded work but no sound
Probably the player you use doesn't support ac3 codec (guessing the license is missing). You could try a different app.
Kelgtar
Post Sat Mar 04, 2017 12:32 pm
zip wrote:Probably the player you use doesn't support ac3 codec (guessing the license is missing). You could try a different app.
Have tried BS for Android : same problem
Tried VLC = same problem
Kelgtar
Post Sat Mar 04, 2017 12:49 pm
Problem solved ...
Post Sun Mar 05, 2017 1:40 am
Care to provide the solution? :D
Users browsing this forum: No registered users and 73 guests
