Sigh, Cannot connect to the server , it doesn't seem to be r
the_hamburger
Post Sat Mar 04, 2017 1:53 am
I know this has been asked and answered but I'm still stuck.
OSX Sierra 10.12.3 (16D32)
I've had wonderful experience with Serviio for many years now, but recently had to reinstall OSX.
After restoring from timemachine I get the above message.
Firewall off , just installed latest JRE + reboot reboot reboot reboot
Here is the log
Sat Mar 04 08:21:58 ICT 2017:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.12.1.1 - (1704137): instance a816c00e-015a-96e8-af2b-fffff4a463b2
on database directory /Library/Application Support/Serviio/library/db with class loader sun.misc.Launcher$AppClassLoader@19469ea2
Loaded from file:/Library/Application%20Support/Serviio/lib/derby.jar
java.vendor=Oracle Corporation
java.runtime.version=1.8.0_91-b14
user.dir=/
os.name=Mac OS X
os.arch=x86_64
os.version=10.12.3
derby.system.home=/Library/Application Support/Serviio/library
derby.stream.error.file=../log/derby.log
------------  Begin Shutdown Error Stack -------------
ERROR XSLA7: Cannot redo operation null in the log.
   at org.apache.derby.impl.store.raw.log.FileLogger.redo(Unknown Source)
   at org.apache.derby.impl.store.raw.log.LogToFile.recover(Unknown Source)
   at org.apache.derby.impl.store.raw.RawStore.boot(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.boot(Unknown Source)
   at org.apache.derby.impl.services.monitor.TopService.bootModule(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.startModule(Unknown Source)
   at org.apache.derby.impl.services.monitor.FileMonitor.startModule(Unknown Source)
   at org.apache.derby.iapi.services.monitor.Monitor.bootServiceModule(Unknown Source)
   at org.apache.derby.impl.store.access.RAMAccessManager$5.run(Unknown Source)
   at org.apache.derby.impl.store.access.RAMAccessManager.bootServiceModule(Unknown Source)
   at org.apache.derby.impl.store.access.RAMAccessManager.boot(Unknown Source)
   at org.apache.derby.impl.db.BasicDatabase$5.run(Unknown Source)
   at org.apache.derby.impl.db.BasicDatabase.bootServiceModule(Unknown Source)
   at org.apache.derby.impl.db.BasicDatabase.bootStore(Unknown Source)
   at org.apache.derby.impl.db.BasicDatabase.boot(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.startProviderService(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.findProviderAndStartService(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.startPersistentService(Unknown Source)
   at org.apache.derby.iapi.services.monitor.Monitor.startPersistentService(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection$4.run(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection.startPersistentService(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection.bootDatabase(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
   at org.apache.derby.jdbc.InternalDriver$1.run(Unknown Source)
   at org.apache.derby.jdbc.InternalDriver.getNewEmbedConnection(Unknown Source)
   at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
   at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
   at java.sql.DriverManager.getConnection(DriverManager.java:664)
   at java.sql.DriverManager.getConnection(DriverManager.java:270)
   at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:71)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:64)
   at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
   at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:80)
   at org.serviio.MediaServer.main(MediaServer.java:125)
Caused by: ERROR XSDB4: Page Page(6,Container(0, 2544)) is at version 176,717, the log file contains change version 182,362, either there are log records of this page missing, or this page did not get written out to disk properly.
   at org.apache.derby.impl.store.raw.data.PageBasicOperation.needsRedo(Unknown Source)
   ... 52 more
============= begin nested exception, level (1) ===========
============= end nested exception, level (1) ===========
------------  End Shutdown Error Stack -------------
Sat Mar 04 08:21:59 ICT 2017:
Shutting down instance a816c00e-015a-96e8-af2b-fffff4a463b2 on database directory /Library/Application Support/Serviio/library/db with class loader sun.misc.Launcher$AppClassLoader@19469ea2
Sat Mar 04 08:21:59 ICT 2017 Thread[main,5,main] Cleanup action starting
java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@19469ea2, see the next exception for details.
Caused by: ERROR XJ040: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@19469ea2, see the next exception for details.
   at org.apache.derby.impl.jdbc.SQLExceptionFactory.wrapArgsForTransportAcrossDRDA(Unknown Source)
   ... 22 more
   ... 19 more
java.sql.SQLException: Page Page(6,Container(0, 2544)) is at version 176,717, the log file contains change version 182,362, either there are log records of this page missing, or this page did not get written out to disk properly.
   ... 19 more
============= begin nested exception, level (2) ===========
============= end nested exception, level (2) ===========
Cleanup action completed
Any and all help is appreciated!
Regards
Burger
Post Sat Mar 04, 2017 6:33 am
Re: Sigh, Cannot connect to the server , it doesn't seem to
Database looks broken. Suggest uninstalling and installing again.
the_hamburger
Post Sat Mar 04, 2017 12:07 pm
I moved Serviio app to trash and emptied trash and the re-installed from previously downloaded and unpacked serviio-1.8-osx.tar.gz , after installation completed "Cannot connect to server"
I then uninstalled completely using cleanmymac , deleted old tar.gz/unpacked .pkg file , emptied trash. Re-Downloaded serviio-1.8-osx.tar.gz , unpacked, installed , rebooted. "Cannot connect to server"
New log
Sat Mar 04 18:48:14 ICT 2017:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.12.1.1 - (1704137): instance a816c00e-015a-9926-13e0-fffff4a463b2
user.dir=/
os.name=Mac OS X
os.arch=x86_64
os.version=10.12.3
   ... 52 more
Shutting down instance a816c00e-015a-9926-13e0-fffff4a463b2 on database directory /Library/Application Support/Serviio/library/db with class loader sun.misc.Launcher$AppClassLoader@19469ea2
Sat Mar 04 18:48:14 ICT 2017 Thread[main,5,main] Cleanup action starting
   ... 22 more
   ... 19 more
   ... 19 more
Sorry for being a pain, but its your own fault , Serviio is so good I need it back ;)
Please advise what I can try now.
Much appreciated.
the_hamburger
Post Sun Mar 05, 2017 12:40 pm
Solved it!
viewtopic.php?f=5&t=22498&p=110804&hilit=sierra#p110804
Uninstall , delete the serviio fiolder in Library , re-install , reboot.
Thanks!
Users browsing this forum: Google [Bot] and 51 guests
