Compatible devices list
Using Serviio with Sony BDP-S370. The 0.5.1 update made playback much better (Sony doesn't deal with MKV files well and that is what I've transcoded my library to) and am hoping that the 0.5.2 will remove my last obstacle (AAC audio). Wish Wii and WMP12 were DLNA compliant too.
Re: Compatible devices list
ac_carshop wrote:Using Serviio with Sony BDP-S370. The 0.5.1 update made playback much better (Sony doesn't deal with MKV files well and that is what I've transcoded my library to) and am hoping that the 0.5.2 will remove my last obstacle (AAC audio). Wish Wii and WMP12 were DLNA compliant too.
does the WII have DLNA systsem on it ??? and wmp12 wont ever be fully supported as MS messed it up so badly..
I don't know how I had missed this poll.
I'm using serviio on a Sony BDP-S370.
Humax Fox T2 with the generic DLNA profile. Works very well.
Samsung UE37C5700
Upgrade 0.5 -> 0.51 seemed like a quantum leap to me. Like black powder -> dynamite!
Samsung UE37C5700, Server-PC: Mobile T5500 on Abit iL90MV (945GT chipset)
Sony KDL-32ex308
Serviio Server on FOXCONN NT-330I Netbox 2Gb ram
Sony Bravia profile
Works great
Sony Bravia profile
Works great
Sammy c5500
LG 50pk950 tv
LG 50pk950 tv
Samsung PS50C670
LOVING serviio. Thanks
Samsung BD C5500
Xbox 360
Samsung Galaxy Mobil - TBC... definatly works with allshare.. need to confirm serviio
Mart
Xbox 360
Mart
Sharp Aquos 814E (LC-40-LX814E) - works great with Sony Bravia profile
Sebastian_T wrote:Sharp Aquos 814E (LC-40-LX814E) - works great with Sony Bravia profile
Can you provide some information on this device so we can add its own profile to serviio ( Provide supported formats of a device link in my signiture )
Sebastian,
Could you start a new topic under "Serviio Support & Help" section with informations you already post about your Sharp TV(viewtopic.php?f=7&t=278&start=10#p13627) ?
Just confirmed, works flawlessly with Smasung galaxy S
Interesting, it supports playlists (movies) but wont FF or RW
Ironically you use Samsungs allshare app, but it sees the serviio server, and not the allshare server ??
Mart
Mart
I use a Samsung BD-D5300, Xbox 360, Netgear EVA2000 and on my laptops I use XBMC.
Works fine with my Samsung LN46C550 --- connected to Belkin G router from Walmart and cheapo Rosewill RNX-N1 from NewEgg (costs less than half of the Samsung proprietary wireless adapter).
Having been told by a ghetto moron (smugly) at the Samsung 800 # that this model of TV couldn't get internet connections, I am thrilled to prove him wrong.
Nor could get I get the Samsung PC Share Manager (which Samsung moron said did not exist) to accept my files. It found the TV, but the software wouldn't take the files.
After just 10 mins with Servio I'm up and running! Thank you so much for all of your hard work and your generosity in sharing it with us!!
a wd tv live hd works ok, with the original fw.
i need a new profile to avoid transcoding flac files, since the device handles them quite well on its own.
has anyone tried to write up a wd tv live hd profile?
I want the setup to be serviio and not network shares, since then I can use the iPod Touch remote app and not have to start the TV to play music.
And a terabyte of disk stores like > 2000 CDs lossless, which is just about right for me. Then the other terabyte can store like 5-600 one hour TV shows in 720p.
n3mmr wrote:a wd tv live hd works ok, with the original fw.
There will be one in 0.6, but it's basically just very slightly edited Generic DLNA profile (which doesn't transcode anything), so you can use that.
Petr
Help translate Serviio
zip wrote:n3mmr wrote:a wd tv live hd works ok, with the original fw.
The generic 0.5.2 one transcodes flac into lpcm, doesn't it? So I guess the 0.6 WD TV Live HD one is just a generic profile with all transcodings removed?
n3mmr wrote:The generic 0.5.2 one transcodes flac into lpcm, doesn't it? So I guess the 0.6 WD TV Live HD one is just a generic profile with all transcodings removed?
The generic one has not transcoding configured - does not transcode anything
Petr
zip wrote:n3mmr wrote:The generic 0.5.2 one transcodes flac into lpcm, doesn't it? So I guess the 0.6 WD TV Live HD one is just a generic profile with all transcodings removed?
You are of course right.
So, a flac file will be sent to my WD TV Live HD as a flac stream.
Good!
