SeasonVar.ru (Web Resource)
lekraft
Post Sun Jan 15, 2017 12:09 pm
Re: SeasonVar.ru (Web Resource)
Some serials...
2017-01-15 18:03:12,341 ERROR [IndexedDiskCache] Region [online_technical_metadata] Failure updating element, key: http://data08-cdn.datalock.ru/fi2lm/cb4 ... .07.12.mp4 old: null
java.io.NotSerializableException: org.serviio.library.local.AudioTrack
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1184)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:348)
at java.util.ArrayList.writeObject(ArrayList.java:762)
at sun.reflect.GeneratedMethodAccessor14.invoke(Unknown Source)
at java.io.ObjectStreamClass.invokeWriteObject(ObjectStreamClass.java:1028)
at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1496)
at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1432)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1178)
at java.io.ObjectOutputStream.defaultWriteFields(ObjectOutputStream.java:1548)
at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1509)
at org.apache.jcs.utils.serialization.StandardSerializer.serialize(StandardSerializer.java:50)
at org.apache.jcs.auxiliary.disk.indexed.IndexedDisk.serialize(IndexedDisk.java:288)
at org.apache.jcs.auxiliary.disk.indexed.IndexedDiskCache.doUpdate(IndexedDiskCache.java:430)
at org.apache.jcs.auxiliary.disk.AbstractDiskCache$MyCacheListener.handlePut(AbstractDiskCache.java:603)
at org.apache.jcs.engine.CacheEventQueue$PutEvent.doRun(CacheEventQueue.java:688)
at org.apache.jcs.engine.CacheEventQueue$AbstractCacheEvent.run(CacheEventQueue.java:607)
at org.apache.jcs.engine.CacheEventQueue$QProcessor.run(CacheEventQueue.java:575)
Messege From PS3 "Content Deleted"
But some serials cached without any problem.... Why? Is it Region problem? Im from Russia.
On my PC i havent problems. My OS FreeBSD 10.3 RELEASE, serviio 1.7 From Ports. Plugin ver. 19.
Ofc i installed Transmission, use it as BitClient... but this plugin is realy good... Can somebody help me?
And this...
2017-01-15 18:12:30,798 ERROR [IndexedDiskCache] Region [online_technical_metadata] Failure updating element, key: http://data12-cdn.datalock.ru/fi2lm/cb4 ... .26.SATRip.[www.Riper.AM].a1.27.10.14.mp4 old: null
This serial is working.....
affazel85
Post Sat Feb 25, 2017 10:27 pm
Доброго времени суток!
Не работает плагин с некоторыми линками. Самое странное, что остальные 4 сезона (1, 2, 3 и 10) показывает без проблем.
Лог:
2017-02-26 01:16:53,518 WARN  [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-1571-Teoriya_bol_shogo_vzriva-4-season.html, waiting for expiry time to try again: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
        at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:79)
        at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:187)
        at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:207)
        at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:203)
        at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:109)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
        at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
        at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
        at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
        at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
        at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
        at SeasonVar.getSourceFromPlayer(SeasonVar.groovy:123)
        at SeasonVar.extractItems(SeasonVar.groovy:68)
        at org.serviio.library.online.WebResourceUrlExtractor.extractItems(WebResourceUrlExtractor.java:72)
        at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:34)
        at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:31)
        at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
        at java.util.concurrent.FutureTask.run(FutureTask.java:266)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        ... 1 more
2017-02-26 01:16:53,644 WARN  [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-3153-teoriya_bol_vzriva.html, waiting for expiry time to try again: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
        ... 1 more
2017-02-26 01:16:53,756 WARN  [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-4975-Teoriya_bol_shogo_vzriva-6-sezon.html, will try again soon: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
        ... 1 more
2017-02-26 01:21:54,715 WARN  [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-7792-Teoriya_bol_shogo_vzryva-7-sezon.html, will try again soon: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
        ... 1 more
2017-02-26 01:21:54,827 WARN  [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-10437-Teoriya_bol_shogo_vzryva-8-season.html, will try again soon: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
        ... 1 more
2017-02-26 01:22:55,320 WARN  [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-12387-Teoriya_bol_shogo_vzryva-9-season.html, will try again soon: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
        ... 1 more
lekraft
Post Fri Mar 03, 2017 4:01 am
affazel85 wrote:Доброго времени суток!
Лог:
        ... 1 more
        ... 1 more
        ... 1 more
        ... 1 more
        ... 1 more
        ... 1 more
У меня такая же проблема...
ind2001
Post Sun Mar 12, 2017 4:02 pm
Отличный плагин!
Ему бы ещё возможность авторизации для просмотра контента в HD - вообще цены бы не было.
ivanoff999
Post Tue Apr 04, 2017 5:04 pm
Доброго времени суток, перестал работать плагин, помогите!
(75.73 KiB) Downloaded 1085 times
Sony Bravia 2010 - KDL-32EX40B Serviio 1.9.2 Pro on Windows 7 x64 SP1/macOS Sierra 10.12.6/Ubuntu Mate 17.04 x64
krom77
Post Wed Apr 05, 2017 1:06 pm
Добрый день.
Не подскажите, на какой версии работает плагин ?
У меня почему-то не в линуксе под любой версией не показывает списки. В винде на версии 4.1 было завелось - потом сдуру переставил версию - и все - больше ни под какой тоже не работает.
Подскажите пожалуйста хоть в какую сторону рыть проблемму ?
Очень классный плагин! Спасибо за труд!
Хотелось бы завести его снова...,
PS: похоже, что у меня та-же проблемма, что и у человека выше. Тоже перестал работать пару дней назад. Но на какой лучше версии он работает -тоже хотелось бы узнать.
ivanoff999
Post Sat May 13, 2017 5:15 pm
Мда... Всё печально, автор плагина не реагирует, к сожалению.
Previous
Return to Available plugins
