MediaBrowser Fails Flash Player
don544
Post Thu Mar 16, 2017 11:38 pm
Serviio Flash.JPG (77.84 KiB) Viewed 6985 times
Says I am newbie and that is correct. After install problem straightened out I find this problem.
1: Keeps saying I have no Flash Player, have three browsers all of them have a working flash player up-to-date. Fire Fox set as default. When clicking on the info saying I have none in the media browser it goes to download page at adobe and then we go back to same situation, says no flash player.
2: Shows multiple entries for the same folder/movie and entries for folders movies that do not even exist.
3: As Serviio does not even show as a dlna device on any of our tv or tivo equipment I do not yet know if this is true on those, thought I would start with this one problem.
Any comments or suggestions are welcomed.
Post Fri Mar 17, 2017 4:06 pm
Re: MediaBrowser Fails Flash Player
What is this version? It looks like you opened MediaBrowser from the console application. It should open it in a browser window, where Flash works. Instead it opens it in the web view wrapper, which has been fixed in a previous version.
Post Fri Mar 17, 2017 4:07 pm
Just open mediabrowser on http://localhost:23424/mediabrowser
don544
Post Fri Mar 17, 2017 6:55 pm
zip wrote:What is this version? It looks like you opened MediaBrowser from the console application. It should open it in a browser window, where Flash works. Instead it opens it in the web view wrapper, which has been fixed in a previous version.
It was 1.6 , will download and update to 1.8 and yes it was the link in the console that I was using so launching from the localhost does work.
However I am still working out why the library shows video that does not exist and multiple instances of them as in this pic.
Thank You for your response.
Post Sun Mar 19, 2017 7:58 am
See viewtopic.php?f=5&t=23581&p=113431#p113431. The reason I think you are seeing it multiple times is a series you have needs to be renamed according to the schema.
