Best way to update JRE to 1.8.101 with Serviio 1.8.32
DEJ710
Post Tue Feb 07, 2017 9:52 am
Hi zip,
What's the best way to update JRE to 1.8.101 with Serviio 1.8.32 on a QNAP NAS (TS-451), running firmware 4.2.2? Does Serviio need to be uninstalled?
I tried just upgrading JRE over the top but that didn't work so reverted back to JRE 1.8.65.
https://PrivateLadyEscorts.com - Meet Local Singles - No Selfie - Anonymous Adult Dating - Secret Local Dating
Post Wed Feb 08, 2017 9:24 pm
Re: Best way to update JRE to 1.8.101 with Serviio 1.8.32
I'm not sure - any JRE should work.
DEJ710
Post Mon Mar 20, 2017 9:50 am
zip wrote:I'm not sure - any JRE should work.
Hi zip, updated my NAS to 4.2.4 and then updated to JRE 1.8.101. Serviio is happy now.
Edit. Inadvertently tried to update Serviio to 1.8.64 from the QNAP 4.3 install section, which failed and trashed my Serviio installation and broke the JRE 8.101 link. This shouldn't be able to happen should it?
If I try to run Serviio with JRE 8.101 installed, it wont connect any more. The engine_error.log displays wrong class ELFCLASS32.
Any suggestions?
DEJ710
Post Fri Apr 07, 2017 11:55 am
Hi zip,
Surely with this many views of this post, somebody must know how to fix this. Is anyone else experiencing this problem?
RMcV
Post Wed Apr 19, 2017 12:58 pm
@DEJ710
I don't think Serviio 1.8.32 (32-bit) will work with JRE 1.8.101. Just update the OS to 4.3.., install JRE 1.8.101, uninstall Serviio 1.8.32 (32-bit) and install Serviio 1.8.64 (64-bit). Configure Serviio, let it catalogue your media and then enjoy!
DEJ710
Post Sun Apr 23, 2017 12:31 am
@RMcV
Thanks for your response.
I updated to qts 4.3.3, JRE 8.101 and Serviio 1.8.64 last night and here's what I did:
1. Update to qts 4.3.3
2. Update JRE to 8.101
3. Upgrade Serviio to 1.8.64 (Install over the top) using download from serviio download link
Serviio is still functioning and my library is still in tact
