InvalidMediaFormatException: Unknown video file type
Wattsontour
Post Sat Dec 06, 2014 8:43 am
Hi Guys - Appreciate the help here. Youll have to bare with me as Im not hugely clued up in all this stuff. I have been using the StreamDesktop.bat for a number of years without fault to stream my desktop to tv. It recently stopped working for whatever reason (perhaps a firmware upgrade on the pvr). Ive updated to the latest version of Serviio but still got the same issue. Provided a snapshot of the log below if anyone could help it would be massively appreciated.
Running Serviio 1.4.1.2. Connecting to a Humax 1003s pvr.
2014-12-06 19:32:36,852 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://192.168.1.4:8081. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:320)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:237)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:116)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:467)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:100)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:138)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:299)
... 2 more
Post Tue Dec 09, 2014 8:22 pm
Re: InvalidMediaFormatException: Unknown video file type
what is the output of this?
ffmpeg -i " http://192.168.1.4:8081"
pasko
Post Wed Apr 05, 2017 8:14 pm
Hi.
I'm trying to stream via Serviio the output of an IP Camera and the logs show the same error "Unknown video file type".
The ouput for ffmpeg with the url is the following:
user@Claudia:~$ ffmpeg -i http://172.26.0.26:8080/video
ffmpeg version 3.0.2 Copyright (c) 2000-2016 the FFmpeg developers
  built with gcc 4.8 (Ubuntu 4.8.4-2ubuntu1~14.04.3)
  configuration: --enable-libass --enable-libvpx --enable-libx264 --enable-librtmp --enable-libfdk-aac --enable-gpl --enable-nonfree --enable-libopenjpeg
  libavutil      55. 17.103 / 55. 17.103
  libavcodec     57. 24.102 / 57. 24.102
  libavformat    57. 25.100 / 57. 25.100
  libavdevice    57.  0.101 / 57.  0.101
  libavfilter     6. 31.100 /  6. 31.100
  libswscale      4.  0.100 /  4.  0.100
  libswresample   2.  0.101 /  2.  0.101
  libpostproc    54.  0.100 / 54.  0.100
[mjpeg @ 0xab03880] Changing bps to 8
Input #0, mpjpeg, from 'http://172.26.0.26:8080/video':
  Duration: N/A, bitrate: N/A
    Stream #0:0: Video: mjpeg, yuvj420p(pc, bt470bg/unknown/unknown), 640x480 [SAR 1:1 DAR 4:3], 25 fps, 25 tbr, 25 tbn, 25 tbc
user@Claudia:~$
I have so far recompiled ffmpeg to include libopenjpeg support, but still doesn't work. When I run vlc (or ffplay) with the URL it plays without problems. I have also deactivated metadata generation, just in case. I'm on serviio 1.7.1.1
Is there anything I'm missing?
Thanks in advance.
Post Thu Apr 06, 2017 9:06 am
I'm not sure Serviio supports mpjpeg (or the late ffmpeg renamed it from a different value to this on). I will add it for 1.9
pasko
Post Thu Apr 06, 2017 5:57 pm
Hi.
Thank you for your answer.
Regards.
