Post Sun Apr 16, 2017 2:25 pm
vbox tv gateway
I am trying to get serviio connected to a tv gateway which is on my local network in odrer to get it transcoded and avaiable online using ServiiGo. Copied channel list in m3u format to shared folder with no luck as it is not visible. Tried all sort of things with a playlist plugin and by pointing web resource to the tv gateway but nothing seems to work.
Any suggestion would be much appreciated.
Attached is the channel list as txt file and a screenshot of Gateway's IPTV section.
Best regards,
Dejan
ChannelList.txt
(4.55 KiB) Downloaded 595 times
TV gateway setup.docx
(151.61 KiB) Downloaded 462 times
