Library no longer automatically updating
• Page 1 of 1
I have Serviio Pro 1.8 running on Windows 10 x64. Since updating Windows to build 15063.138 (the so-called "Creators Update"), although I have "Keep library automatically updated" in the Serviio library options, files added to the library are not visible until I manually force a refresh by clicking on the "Force refresh" button in the Serviio console.
Re: Library no longer automatically updating
NickJP wrote:I have Serviio Pro 1.8 running on Windows 10 x64. Since updating Windows to build 15063.138 (the so-called "Creators Update"), although I have "Keep library automatically updated" in the Serviio library options, files added to the library are not visible until I manually force a refresh by clicking on the "Force refresh" button in the Serviio console.
Try changing the update method to poller. Open one of your shared file locations in the Serviio console and select Poller (I'm not home, so can't tell you exactly the wording). It might be that Microsoft changed something that will require an update to Serviio. Wouldn't be the first time MS did something like that! When I get home Friday I'll look and see if my server has updated to that version, and if my library is updating automatically.
I have the same problem. Library notre automaticaly refresh. Someone have a solution ? I have not find the update method to "poller"...what is it ? thanks a lot.
sam561 wrote:Hi,
Follow what I wrote above. It's a setting in the Serviio console for each shared media location you enter.
atc98092 wrote:sam561 wrote:Hi,
Yes, but i don't find this option !
Where is it ?
thanks a lot
sam561 wrote:atc98092 wrote:sam561 wrote:Hi,
Where is it ?
thanks a lot
Go to the Shared Folders location on the console. Open one of your shared folders for editing. The Poller option is available either on the edit screen or when you create a new shared location.
This page explains it as well, but there are no screen shots. http://wiki.serviio.org/doku.php?id=lib ... er_scanner
• Page 1 of 1
