pioneer support
sohail579
Post Sun Mar 13, 2011 2:57 pm
pioneer support
Is there any chance of getting a profile for my pioneer krp 500a?
thanks
Post Sun Mar 13, 2011 4:02 pm
Re: pioneer support
sohail579
Post Mon Mar 14, 2011 11:41 pm
Re: pioneer support
thanks zip got that for you here
http-get:*:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:*:audio/L16:rate=48000;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:*:audio/mpeg:DLNA.ORG_PN=MP3,
http-get:*:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,
http-get:*:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA,
http-get:*:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA,
http-get:*:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,
http-get:*:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,
http-get:*:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,
http-get:*:*:image/jpeg:DLNA.ORG_PN=JPEG_TN
Post Tue Mar 15, 2011 10:06 am
Re: pioneer support
Thanks, now can you try Generic DLNA profile and report files that are not playing with that?
Alain
Post Thu Mar 17, 2011 8:49 am
Re: pioneer support
It seems your krp meets the same requirements of my LX5090H
http://forum.serviio.org/viewtopic.php?f=5&t=1479
We could integrate our test experiences to create a generic Pioneer Plasma profile.
Unfortunately until now I was not skilled enough to make a satisfactory one, but it should be similar to the Sony Bravia's one.
sohail579
Post Mon Mar 21, 2011 10:06 pm
Re: pioneer support
finally got around to doing this for you zip! tried all the different files I have on the generic profile
Will Play
.ts file (The resume function works as does the fast forward function and also the time search function) (won't play with DTS sound)
.mpg (The resume function works as does the fast forward function and also the time search function)
.mp4 (The resume function works as does the fast forward function and also the time search function)
Won't Play
.mkv
.avi
One .avi file I had worked and this is the ffmpg for that file..
(C:\Documents and Settings\Administrator>"C:\Program Files\Serviio\lib\ffmpeg.exe
" -i D:\shares\Videos\Sports\world.avi
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[wmv3 @ 01666ac0] Extra data: 8 bits left, value: 0
Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000
/1) -> 30.00 (30/1)
Input #0, asf, from 'D:\shares\Videos\Sports\world.avi':
title : LinkinCreep
artist : LinkinCreep
copyright : LinkinCreep
comment : LinkinCreep
WMFSDKVersion : 11.0.5721.5145
WMFSDKNeeded : 0.0.0.0000
IsVBR : 0
Duration: 01:58:32.69, start: 5.000000, bitrate: 390 kb/s
Stream #0.0(eng): Audio: wmav2, 44100 Hz, 2 channels, s16, 48 kb/s
Stream #0.1(eng): Video: wmv3, yuv420p, 400x240, 340 kb/s, 30 tbr, 1k tbn, 1
k tbc
sohail579
Post Wed Mar 30, 2011 10:23 pm
Re: pioneer support
Hey zip was this enough info for you?
Post Wed Mar 30, 2011 10:26 pm
Re: pioneer support
Yes mate, I have it in my task list to look at this profile for you. Hopefully sometime this week.
sohail579
Post Thu Mar 31, 2011 6:31 pm
Re: pioneer support
thanks
sohail579
Post Sun Apr 17, 2011 2:02 am
Re: pioneer support
any luck with this
15watts
Post Mon Jan 16, 2012 8:56 pm
Re: pioneer support
Hi, I am also looking for a profile for a Pioneer VSX-LX70. Serviio is running happily on Mac OS X 10.7.2 streaming from the iTunes library to a Panasonic TV but the Pioneer amp reports "server error" under all the embedded profiles even though it is visible as an option in the Home Media Gallery. I have read the Serviio support files & the correct ports are open. Any ideas or help would be greatly appreciated. Thanks
japes
Post Thu May 23, 2013 9:03 pm
Re: pioneer support
the profile data for pioneer BDP-450 wich can include in serviio. big thanks for this nice program :) kind of regards from germany
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,
http-get:*:image/png:DLNA.ORG_PN=PNG_TN,
http-get:*:image/png:DLNA.ORG_PN=PNG_LRG,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,
http-get:*:audio/L16:DLNA.ORG_PN=LPCM,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X,
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320,
http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO,
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO,
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320,
http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_ASP_L4_SO_G726,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL_XAC3,
http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_SP_G726,
http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_ASP_L5_SO_G726,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC_XAC3,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA,
http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_H263_MP4_P0_L10_AAC,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520,
http-get:*:image/vnd.ms-photo:*,
http-get:*:image/gif:*,
http-get:*:image/x-ycbcr-yuv420:*,
http-get:*:image/jpeg:*,
http-get:*:image/bmp:*,
http-get:*:image/png:*,
http-get:*:image/tiff:*,
http-get:*:image/x-icon:*,
http-get:*:image/x-quicktime:*,
http-get:*:image/jpe:*,
http-get:*:audio/L16:*,
http-get:*:audio/L8:*,
http-get:*:audio/mp1:*,
http-get:*:audio/mp2:*,
http-get:*:audio/mpeg:*,
http-get:*:audio/basic:*,
http-get:*:audio/aiff:*,
http-get:*:audio/mid:*,
http-get:*:audio/x-ms-wax:*,
http-get:*:audio/wav:*,
http-get:*:audio/x-ms-wma:*,
http-get:*:audio/vnd.rn-realaudio:*,
http-get:*:audio/x-mpegurl:*,
http-get:*:audio/x-wav:*,
http-get:*:audio/x-flac:*,
http-get:*:audio/mp4:*,
http-get:*:audio/vnd.dlna.adts:*,
http-get:*:audio/x-ms-wmv:*,
http-get:*:audio/x-ogg:*,
http-get:*:audio/midi:*,
http-get:*:audio/x-aac:*,
http-get:*:audio/x-ac3:*,
http-get:*:audio/x-atrac3:*,
http-get:*:audio/x-dts:*,
http-get:*:audio/x-pn-realaudio:*,
http-get:*:audio/x-quicktime:*,
http-get:*:audio/dolby:*,
http-get:*:audio/adts:*,
http-get:*:audio/3gpp:*,
http-get:*:audio/sonyoma:*,
http-get:*:video/vnd.dlna.mpeg-tts:*,
http-get:*:video/mp4:*,
http-get:*:video/3gpp:*,
http-get:*:video/mp2p:*,
http-get:*:video/mpeg2:*,
http-get:*:video/quicktime:*,
http-get:*:video/x-dv:*,
http-get:*:video/x-motion-jpeg:*,
http-get:*:video/x-nerodigital-ps:*,
http-get:*:video/mp1s:*,
http-get:*:video/tts:*,
http-get:*:video/x-msvideo:*,
http-get:*:video/divx:*,
http-get:*:video/xiid:*,
http-get:*:video/asf:*,
http-get:*:video/wmv:*,
http-get:*:video/x-matroska:*,
http-get:*:video/rtml:*,
http-get:*:video/x-ms-wmv:*,
http-get:*:video/x-ms-wmx:*,
http-get:*:video/x-ms-wm:*,
http-get:*:video/x-ms-asf:*,
http-get:*:video/x-ms-wvx:*,
http-get:*:video/x-ms-dvr:*,
http-get:*:video/avi:*,
http-get:*:video/mpeg:*,
http-get:*:video/vnd.rn-realvideo:*,
http-get:*:video/x-pn-realmedia:*
kallen100
Post Mon Nov 10, 2014 5:07 pm
Re: pioneer support
Hello, was a profile ever created for this Pioneer BDp450?
japes
Post Wed Apr 01, 2015 10:22 am
Re: pioneer support
my Pioneer BDP have problems with mkv and dts-hd or truehd audio. So I have added a new profile for the BDP and all works fine with BDP-450 and LX55. The dts-hd and truehd audio will transcode to ac3. original ts files with dts-hd and truehd works fine without transcode
<Profile id="pioneer_bd" name="Pioneer BDP" extendsProfileId="1">
<Detection>
<UPnPSearch>
<ModelName>Pioneer</ModelName>
</UPnPSearch>
</Detection>
<Video targetContainer="mpegts" targetACodec="ac3" aBitrate="640">
<Matches container="matroska" aCodec="dts-hd"/>
<Matches container="matroska" aCodec="truehd"/>
Fody
Post Sun Sep 24, 2017 3:16 pm
Re: pioneer support
Please send me further information how can I use my Pioneer BDP-180 device with Serviio media server. See below the device data.
Thanks in advance:
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,http-get:*:image/png:DLNA.ORG_PN=PNG_TN,http-get:*:image/png:DLNA.ORG_PN=PNG_LRG,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,http-get:*:image/gif:DLNA.ORG_PN=GIF_LRG,http-get:*:audio/L16:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAPRO,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMALSL,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMALSL_MULT5,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_MULT5_ISO,http-get:*:audio/dsd:DLNA.ORG_PN=DSD,http-get:*:audio/dsf:DLNA.ORG_PN=DSF,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_192,http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_ASP_L4_SO_G726,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL_XAC3,http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_SP_G726,http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_ASP_L5_SO_G726,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC_XAC3,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_H263_MP4_P0_L10_AAC,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_60_AC3_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HP_HD_AC3_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_ISO,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AC3,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_940,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L31_HD_AAC,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L32_HD_AAC,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3L_SD_AAC,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_HP_HD_AAC,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_HD_1080i_AAC,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_HD_720p_AAC,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_VGA_AAC,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HP_HD_AC3_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_T,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_MP3,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_PRO,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AAC,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AMR,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_JP_MPEG1_L2_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_X_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_LPCM_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_LPCM_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_JP_AAC_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_T,http-get:*:video/vnd.dlna.mpeg-tts:DTV_MVP_PN=AVC_TS_DTV_SD_AAC_T,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_HD_DTS,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_HD_DTSHD_HRA,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_HD_DTSHD_MA,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_SD_DTS,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_DTSHD_HRA_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_DTSHD_HRA_T,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_DTSHD_MA_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_DTSHD_MA_T,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_DTS_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_DTS_T,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_50_L2_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_50_L2_T,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_60_L2_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_60_L2_T,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_X_50_L2_ISO,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_X_60_L2_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC_ISO,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_AC3_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_L2_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_AC3_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_L2_T,http-get:*:video/x-ms-asf:DLNA.ORG_PN=WMVSPML_BASE,http-get:*:video/x-ms-asf:DLNA.ORG_PN=WMVSPLL_BASE,http-get:*:video/x-ms-asf:DLNA.ORG_PN=WMVMED_FULL,http-get:*:video/x-ms-asf:DLNA.ORG_PN=WMVMED_PRO,http-get:*:video/x-ms-asf:DLNA.ORG_PN=WMVMED_BASE,http-get:*:video/x-ms-asf:DLNA.ORG_PN=WMVSPML_PRO,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L2_AAC,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L5_AAC,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_MP4_SP_VGA_AAC,http-get:*:video/3gpp:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_940,http-get:*:video/3gpp:DLNA.ORG_PN=AVC_MP4_BL_L3L_SD_AAC,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_DTS_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_DTS_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_DTS_T,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_NA_T,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_EU,http-get:*:video/x-msvideo:DLNA.ORG_PN=PV_DIVX_DX50,http-get:*:video/mp4:DLNA.ORG_PN=MKV,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_JP_T,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_PS_NTSC,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_PS_PAL,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA_T,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA_ISO,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA_T,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA_ISO,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_KO,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_KO_T,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_TS_SD_KO_ISO,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_HD_KO,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_HD_KO_T,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_TS_HD_KO_ISO,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_T,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_ISO,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_JP_MPEG1_L2_T,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_JP_AAC_T,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_X_T,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_MP_HD_AAC_LTP_T,http-get:*:application/X-arib-cp;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":ARIB.OR.JP_PN=MPEG_TTS_CP,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DTV_MVP_PN=DTCP_AVC_TS_DTV_SD_AAC_T,http-get:*:image/vnd.ms-photo:*,http-get:*:image/gif:*,http-get:*:image/x-ycbcr-yuv420:*,http-get:*:image/jpeg:*,http-get:*:image/png:*,http-get:*:image/mpo:*,http-get:*:image/x-icon:*,http-get:*:image/x-quicktime:*,http-get:*:image/jpe:*,http-get:*:image/x-ycbcr-yuv420:*,http-get:*:audio/L16:*,http-get:*:audio/L8:*,http-get:*:audio/mp1:*,http-get:*:audio/mp2:*,http-get:*:audio/mpeg:*,http-get:*:audio/basic:*,http-get:*:audio/aiff:*,http-get:*:audio/mid:*,http-get:*:audio/x-ms-wax:*,http-get:*:audio/wav:*,http-get:*:audio/x-ms-wma:*,http-get:*:audio/vnd.rn-realaudio:*,http-get:*:audio/x-mpegurl:*,http-get:*:audio/x-wav:*,http-get:*:audio/x-flac:*,http-get:*:audio/mp4:*,http-get:*:audio/x-m4a:*,http-get:*:audio/vnd.dlna.adts:*,http-get:*:audio/x-ms-wmv:*,http-get:*:audio/x-ogg:*,http-get:*:audio/midi:*,http-get:*:audio/x-aac:*,http-get:*:audio/x-ac3:*,http-get:*:audio/x-atrac3:*,http-get:*:audio/x-dts:*,http-get:*:audio/x-pn-realaudio:*,http-get:*:audio/x-quicktime:*,http-get:*:audio/dolby:*,http-get:*:audio/adts:*,http-get:*:audio/3gpp:*,http-get:*:audio/sonyoma:*,http-get:*:audio/dsd: *,http-get:*:audio/x-dsf:*,http-get:*:video/vnd.dlna.mpeg-tts:*,http-get:*:video/mp4:*,http-get:*:video/3gpp:*,http-get:*:video/mp2p:*,http-get:*:video/mpeg2:*,http-get:*:video/quicktime:*,http-get:*:video/x-dv:*,http-get:*:video/x-motion-jpeg:*,http-get:*:video/x-nerodigital-ps:*,http-get:*:video/mp1s:*,http-get:*:video/tts:*,http-get:*:video/x-msvideo:*,http-get:*:video/divx:*,http-get:*:video/xiid:*,http-get:*:video/asf:*,http-get:*:video/wmv:*,http-get:*:video/x-matroska:*,http-get:*:video/rtml:*,http-get:*:video/x-ms-wmv:*,http-get:*:video/x-ms-wmx:*,http-get:*:video/x-ms-wm:*,http-get:*:video/x-ms-asf:*,http-get:*:video/x-ms-wvx:*,http-get:*:video/x-ms-dvr:*,http-get:*:video/avi:*,http-get:*:video/mpeg:*,http-get:*:video/vnd.rn-realvideo:*,http-get:*:video/x-pn-realmedia:*,http-get:*:video/x-flv:*,http-get:*:video/x-tivo-mpeg:*,http-get:*:application/ogg:*
Return to Feature requests
