Serviio won't find my PS3
gregory
Post Sun Mar 20, 2011 7:37 pm
Hello
I just got myselfen new TV and PS3 , now I'd like to share my blu-ray movies via local network with my PS3.
I installed the latest serviio, and connected my PS3 to my local network.$
I'm able to use the internet on my PS3
but when I start a server , My PS3 doesn't find any mediaservers.
serviio won't detect anythink usefull aswell ...
my PS3 holds the IP 178.119.200.31
While serviio only finds
192.168.2.3
192.168.2.4
please, if youguys can make something out of this problem , plx help me ^^
Post Sun Mar 20, 2011 7:49 pm
Re: Serviio won't find my PS3
Moderator: Topic moved to Sony.
First please, read that: http://www.serviio.org/index.php?option ... icle&id=21
gregory
Post Mon Mar 21, 2011 8:38 pm
I opened the ports it suggests me to open , and I've put my PC's IP in the bound IP panel.
Still , my PS3 tells me there are no media servers up and running.
Post Mon Mar 21, 2011 9:04 pm
gregory wrote:...
192.168.2.3
192.168.2.4
What are 192.168.2.3 and 192.168.2.4 devices?
Why PS3 IP is 178.119.200.31, not something like 192.168.x.x?
What are mask adresses? 255.255.255.0 ?
Suggess you to disable all DHCP servers, fix IP addresses of all your devices.
gregory
Post Mon Mar 21, 2011 9:15 pm
I think the diversity on IP adresses may be caused by the fact that one of my router ports is being used with a switch port, My PC is plugged into the router and the PS3 is plugged into the switch port.
HERE'S MY LOG BTW..
2011-03-20 16:55:34,817 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-20 16:55:34,817 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-20 16:55:34,817 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-20 16:55:34,817 INFO [MediaServer] http://www.serviio.org
2011-03-20 16:55:34,817 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-03-20 16:55:34,817 INFO [MediaServer] OS Windows XP x86 5.1
2011-03-20 16:55:34,817 INFO [MediaServer] File encoding: windows-1252
2011-03-20 16:55:35,067 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-20 16:55:35,192 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-20 16:55:43,192 INFO [DBSchemaUpdateExecutor] Updating DB schema
2011-03-20 16:55:51,770 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-20 16:55:52,176 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-20 16:55:52,348 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-20 16:55:52,426 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-20 16:55:52,504 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-20 16:55:52,598 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-20 16:55:52,645 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-20 16:55:52,801 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-20 16:55:52,832 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-20 16:55:53,067 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-20 16:55:53,473 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-03-20 16:55:53,567 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-20 16:55:53,629 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-20 16:55:54,067 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-20 16:55:54,082 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-20 16:55:54,192 INFO [WebServer] WebServer starting on port 8895
2011-03-20 16:55:54,723 INFO [Device] Created UPnP Device with UUID: b8788ec1-4308-32fc-a48f-2532c9b147a9, bound address: 192.168.2.4
2011-03-20 16:55:54,770 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-20 16:55:54,785 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-20 16:55:54,785 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-20 16:55:54,785 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-20 16:55:54,785 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-20 16:55:54,785 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-20 16:55:54,785 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300636554785, LastAccessTime = 1300636554785, getTimeToLiveSeconds() = -1, createTime = 1300636554785 ]
2011-03-20 16:55:54,785 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-20 16:55:54,801 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-20 16:55:54,801 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-20 16:55:54,801 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-20 16:55:54,801 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-20 16:55:54,801 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-20 16:55:54,801 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-20 16:55:54,801 INFO [CompositeCacheConfigurator] Finished configuration in 16 ms.
2011-03-20 16:55:54,801 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-20 16:55:54,801 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-20 16:55:54,801 INFO [EventDispatcher] Starting EventDispatcher
2011-03-20 16:55:54,832 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Pakketplanner-minipoort) and address 192.168.2.4, timeout = 0
2011-03-20 16:55:54,832 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-20 16:55:54,832 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-20 16:56:21,067 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-20 16:56:21,082 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-20 16:56:39,020 INFO [ServiioConsole] Starting Serviio Console
2011-03-20 16:56:39,223 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-03-20 16:56:41,614 INFO [Messages] Loaded console message bundle for locale: en
2011-03-20 16:56:42,489 INFO [Messages] Loaded console message bundle for locale: en
2011-03-20 16:56:42,614 INFO [UpdateChecker] Checking if a new version is available
2011-03-20 16:56:48,629 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-03-20 16:56:49,160 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-03-20 16:56:57,067 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-20 16:56:57,270 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-20 16:56:57,270 INFO [WebServer] WebServer shutting down
2011-03-20 16:56:57,270 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-20 16:56:57,270 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-20 16:56:59,551 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-20 16:56:59,567 INFO [DatabaseManager] Shutting down database
2011-03-20 16:56:59,832 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-03-20 16:57:00,848 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-20 16:57:03,442 INFO [ServiioConsole] Leaving Serviio Console
2011-03-20 16:57:22,348 WARN [StatusView] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-03-20 16:57:29,489 WARN [StatusView] Cannot connect to server: [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:14:13,332 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:14:20,379 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:14:27,410 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:14:30,926 WARN [StatusView$3] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-03-20 17:14:34,457 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:14:41,489 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:14:48,442 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:14:55,379 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:15:02,410 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:15:09,364 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:15:13,785 WARN [StatusView$2] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-03-20 17:15:16,504 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:15:23,739 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:15:30,879 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:15:31,379 WARN [StatusView$3] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-03-20 17:15:37,926 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:15:45,067 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-03-20 17:15:45,114 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-20 17:15:45,160 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-20 17:15:45,160 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-20 17:15:45,160 INFO [MediaServer] http://www.serviio.org
2011-03-20 17:15:45,160 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-03-20 17:15:45,160 INFO [MediaServer] OS Windows XP x86 5.1
2011-03-20 17:15:45,160 INFO [MediaServer] File encoding: windows-1252
2011-03-20 17:15:45,160 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-20 17:15:45,707 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-20 17:15:45,957 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-20 17:15:53,426 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-20 17:15:53,457 INFO [Device] Created UPnP Device with UUID: b8788ec1-4308-32fc-a48f-2532c9b147a9, bound address: 192.168.2.4
2011-03-20 17:15:53,785 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-20 17:15:53,832 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-20 17:15:53,879 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-20 17:15:53,879 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-20 17:15:53,879 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-20 17:15:53,879 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-20 17:15:53,879 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300637753879, LastAccessTime = 1300637753879, getTimeToLiveSeconds() = -1, createTime = 1300637753879 ]
2011-03-20 17:15:53,879 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-20 17:15:53,973 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-20 17:15:53,973 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-20 17:15:53,973 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-20 17:15:53,973 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-20 17:15:53,973 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-20 17:15:53,973 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-20 17:15:53,973 INFO [CompositeCacheConfigurator] Finished configuration in 94 ms.
2011-03-20 17:15:54,020 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-20 17:15:54,707 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-20 17:15:54,942 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-20 17:15:55,051 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-20 17:15:55,145 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-20 17:15:55,254 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-20 17:15:55,332 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-20 17:15:55,504 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-20 17:15:55,551 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-20 17:15:55,832 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-20 17:15:56,317 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-03-20 17:15:56,410 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-20 17:15:56,504 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-20 17:15:57,645 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-20 17:15:57,754 INFO [WebServer] WebServer starting on port 8895
2011-03-20 17:15:57,770 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-20 17:15:57,770 INFO [EventDispatcher] Starting EventDispatcher
2011-03-20 17:15:57,770 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-20 17:15:57,785 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-20 17:15:57,785 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-20 17:15:57,801 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Pakketplanner-minipoort) and address 192.168.2.4, timeout = 0
2011-03-20 17:16:23,942 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-20 17:16:24,020 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-20 17:27:58,676 INFO [RendererManager] Stored a new renderer: uuid='2b7d8f0f-2ba6-4241-a60e-f9003ac69359', name = 'greetns ps3', ipAddress='178.119.200.31', profile = '1'
2011-03-20 17:27:58,676 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-20 17:27:58,676 INFO [WebServer] WebServer shutting down
2011-03-20 17:27:58,676 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-20 17:27:58,676 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-20 17:28:01,020 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-20 17:28:01,035 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-20 17:28:01,035 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-20 17:28:01,035 INFO [EventDispatcher] Starting EventDispatcher
2011-03-20 17:28:01,035 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-20 17:28:01,035 INFO [WebServer] WebServer starting on port 8895
2011-03-20 17:28:01,035 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Pakketplanner-minipoort) and address 192.168.2.4, timeout = 0
2011-03-20 17:28:02,785 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-03-20 17:29:21,645 INFO [ServiioConsole] Leaving Serviio Console
2011-03-20 17:30:11,676 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-20 17:30:12,285 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-20 17:30:12,285 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-20 17:30:12,285 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-20 17:30:12,332 INFO [WebServer] WebServer shutting down
2011-03-20 17:30:12,926 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-20 17:30:15,176 INFO [DatabaseManager] Shutting down database
2011-03-20 17:30:17,129 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-20 17:33:21,359 INFO [ServiioConsole] Starting Serviio Console
2011-03-20 17:33:21,359 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-20 17:33:21,453 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-20 17:33:21,453 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-20 17:33:21,453 INFO [MediaServer] http://www.serviio.org
2011-03-20 17:33:21,453 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-03-20 17:33:21,453 INFO [MediaServer] OS Windows XP x86 5.1
2011-03-20 17:33:21,453 INFO [MediaServer] File encoding: windows-1252
2011-03-20 17:33:21,453 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-20 17:33:26,437 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-03-20 17:33:26,765 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-20 17:33:27,234 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-20 17:33:39,000 INFO [Messages] Loaded console message bundle for locale: en
2011-03-20 17:33:47,781 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-20 17:33:48,312 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-20 17:33:48,437 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-20 17:33:48,515 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-20 17:33:48,562 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-20 17:33:48,625 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-20 17:33:48,656 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-20 17:33:48,750 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-20 17:33:48,781 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-20 17:33:48,937 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-20 17:33:49,187 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-03-20 17:33:49,250 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-20 17:33:49,296 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-20 17:33:50,828 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-20 17:33:50,875 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-20 17:33:51,437 INFO [WebServer] WebServer starting on port 8895
2011-03-20 17:33:51,703 INFO [Device] Created UPnP Device with UUID: b8788ec1-4308-32fc-a48f-2532c9b147a9, bound address: 192.168.2.4
2011-03-20 17:33:52,046 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-20 17:33:52,078 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-20 17:33:52,156 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-20 17:33:52,156 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-20 17:33:52,156 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-20 17:33:52,156 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-20 17:33:52,156 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300638832156, LastAccessTime = 1300638832156, getTimeToLiveSeconds() = -1, createTime = 1300638832156 ]
2011-03-20 17:33:52,156 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-20 17:33:52,312 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-20 17:33:52,312 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-20 17:33:52,312 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-20 17:33:52,312 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-20 17:33:52,312 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-20 17:33:52,312 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-20 17:33:52,312 INFO [CompositeCacheConfigurator] Finished configuration in 234 ms.
2011-03-20 17:33:52,312 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-20 17:33:52,312 INFO [EventDispatcher] Starting EventDispatcher
2011-03-20 17:33:52,312 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-20 17:33:52,312 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Pakketplanner-minipoort) and address 192.168.2.4, timeout = 0
2011-03-20 17:33:52,406 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-20 17:33:52,406 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-20 17:34:18,671 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-20 17:34:18,796 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-20 17:34:42,828 INFO [Messages] Loaded console message bundle for locale: en
2011-03-20 17:34:42,937 INFO [UpdateChecker] Checking if a new version is available
2011-03-20 17:34:48,343 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-03-20 17:34:48,656 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-03-20 17:46:08,375 INFO [RendererManager] Stored a new renderer: uuid='f70fe1ea-40b5-4c0c-96de-b7ef2e20ba75', name = 'Unrecognized device', ipAddress='192.168.2.3', profile = '1'
2011-03-20 20:17:23,562 INFO [ServiioConsole] Leaving Serviio Console
2011-03-20 20:19:04,796 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-20 20:19:05,062 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-20 20:19:05,062 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-20 20:19:10,968 WARN [LibraryManager] Cannot read metadata of file G:\movies\'' Youtube Downloads ''\'' neveneffecten ''\2012_ het einde van de wereld.avi via extractor ONLINE_VIDEO_SOURCES. Message: Cannot retrieve movie search results: Server returned HTTP response code: 503 for URL: http://api.themoviedb.org/2.1/Movie.sea ... +de+wereld
2011-03-20 20:19:11,937 INFO [LibraryAdditionsCheckerThread] Added file '2012_ het einde van de wereld.avi' (title: 2012_ het einde van de wereld) to Library
2011-03-20 20:19:30,625 INFO [LibraryAdditionsCheckerThread] Added file 'De vergelijking van Drake.avi' (title: De vergelijking van Drake) to Library
2011-03-20 20:19:40,250 INFO [LibraryAdditionsCheckerThread] Added file 'laatste show 20 maart manhond.wmv' (title: laatste show 20 maart manhond) to Library
2011-03-20 20:19:47,609 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten - Baantjer_lingo.avi' (title: Neveneffecten - Baantjer_lingo) to Library
2011-03-20 20:19:58,687 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten - Huilende Mensen.avi' (title: Neveneffecten - Huilende Mensen) to Library
2011-03-20 20:20:07,640 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten - Stofzuigerverkoper.avi' (title: Neveneffecten - Stofzuigerverkoper) to Library
2011-03-20 20:20:21,562 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten - wildlife lied.avi' (title: Neveneffecten - wildlife lied) to Library
2011-03-20 20:20:28,343 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten 1 - Schatten Uit De Diepte Deel 1.avi' (title: Neveneffecten 1 - Schatten Uit De Diepte Deel 1) to Library
2011-03-20 20:20:30,218 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten 1 - Schatten Uit De Diepte Deel 2.avi' (title: Neveneffecten 1 - Schatten Uit De Diepte Deel 2) to Library
2011-03-20 20:20:34,000 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten 1 - Schatten uit de diepte Deel 3.avi' (title: Neveneffecten 1 - Schatten uit de diepte Deel 3) to Library
2011-03-20 20:20:36,453 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten 1 - Schatten Uit De Diepte Deel 4.avi' (title: Neveneffecten 1 - Schatten Uit De Diepte Deel 4) to Library
2011-03-20 20:20:39,750 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten 2 - Sint Inc Deel 1.avi' (title: Neveneffecten 2 - Sint Inc Deel 1) to Library
2011-03-20 20:20:43,640 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten 2 - Sint Inc Deel 2.avi' (title: Neveneffecten 2 - Sint Inc Deel 2) to Library
2011-03-20 20:20:46,515 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten 2 - Sint Inc Deel 3.avi' (title: Neveneffecten 2 - Sint Inc Deel 3) to Library
2011-03-20 20:20:48,453 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten 2 - Sint Inc Deel 4.avi' (title: Neveneffecten 2 - Sint Inc Deel 4) to Library
2011-03-20 20:20:52,187 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten - De Landing Deel 1.avi' (title: Neveneffecten - De Landing Deel 1) to Library
2011-03-20 20:20:58,203 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten - De Landing Deel 2.avi' (title: Neveneffecten - De Landing Deel 2) to Library
2011-03-20 20:21:00,609 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten - De Landing Deel 3.avi' (title: Neveneffecten - De Landing Deel 3) to Library
2011-03-20 20:21:05,031 INFO [LibraryAdditionsCheckerThread] Added file 'Neveneffecten - De Landing Deel 4.avi' (title: Neveneffecten - De Landing Deel 4) to Library
2011-03-20 20:21:10,546 INFO [LibraryAdditionsCheckerThread] Added file 'neveneffecten aflevering 4.wmv' (title: neveneffecten aflevering 4) to Library
2011-03-20 20:21:16,156 INFO [LibraryAdditionsCheckerThread] Added file 'Jacques Vermeire - Mon Peeters.avi' (title: Jacques Vermeire - Mon Peeters) to Library
2011-03-20 20:21:21,734 INFO [LibraryAdditionsCheckerThread] Added file 'Jeanke Vermeire.avi' (title: Jeanke Vermeire) to Library
2011-03-20 20:21:25,156 INFO [LibraryAdditionsCheckerThread] Added file 'jumpen.avi' (title: jumpen) to Library
2011-03-20 20:22:45,859 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-20 20:22:46,015 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-20 20:22:46,015 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-20 20:24:39,328 INFO [RendererManager] Stored a new renderer: uuid='59f3dcc9-6c4b-4505-8097-3b710bbd551c', name = 'Unrecognized device', ipAddress='192.168.2.4', profile = '1'
2011-03-20 20:30:49,203 INFO [WebServer] WebServer shutting down
2011-03-20 20:30:49,203 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-20 20:30:49,203 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-20 20:30:49,203 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-20 20:30:51,453 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-20 20:30:51,453 INFO [Device] Updated bound IP address of Device with UUID: b8788ec1-4308-32fc-a48f-2532c9b147a9, bound address: 178.119.200.31
2011-03-20 20:30:51,453 INFO [WebServer] WebServer starting on port 8895
2011-03-20 20:30:51,453 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-20 20:30:51,453 INFO [EventDispatcher] Starting EventDispatcher
2011-03-20 20:30:51,453 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-20 20:30:51,453 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-20 20:30:52,828 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-03-20 20:31:10,203 INFO [WebServer] WebServer shutting down
2011-03-20 20:31:10,203 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-20 20:31:10,203 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-20 20:31:10,203 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-20 20:38:33,359 INFO [WebServer] WebServer starting on port 8895
2011-03-20 20:38:33,359 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-20 20:38:33,359 INFO [EventDispatcher] Starting EventDispatcher
2011-03-20 20:38:33,359 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-20 20:38:33,359 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-20 21:21:21,703 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-20 21:21:21,703 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-20 21:21:21,703 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-20 21:21:21,703 INFO [WebServer] WebServer shutting down
2011-03-20 21:21:23,968 INFO [Device] Updated bound IP address of Device with UUID: b8788ec1-4308-32fc-a48f-2532c9b147a9, bound address: 192.168.2.4
2011-03-20 21:21:23,984 INFO [WebServer] WebServer starting on port 8895
2011-03-20 21:21:23,984 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-20 21:21:23,984 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-20 21:21:23,984 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-20 21:21:23,984 INFO [EventDispatcher] Starting EventDispatcher
2011-03-20 21:21:23,984 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Pakketplanner-minipoort) and address 192.168.2.4, timeout = 0
2011-03-20 21:29:05,781 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-20 21:29:05,984 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-20 21:29:05,984 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-20 21:29:08,812 INFO [ServiioConsole] Leaving Serviio Console
2011-03-20 21:29:08,812 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-20 21:29:09,015 INFO [WebServer] WebServer shutting down
2011-03-20 21:29:09,015 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-20 21:29:09,015 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-20 21:29:09,015 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-20 21:29:11,265 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-20 21:29:11,281 INFO [DatabaseManager] Shutting down database
2011-03-20 21:29:12,859 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-20 21:50:11,578 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-20 21:50:11,625 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-20 21:50:11,625 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-20 21:50:11,625 INFO [MediaServer] http://www.serviio.org
2011-03-20 21:50:11,625 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-03-20 21:50:11,625 INFO [MediaServer] OS Windows XP x86 5.1
2011-03-20 21:50:11,625 INFO [MediaServer] File encoding: windows-1252
2011-03-20 21:50:11,625 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-20 21:50:12,750 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-20 21:50:12,843 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-20 21:50:16,171 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-20 21:50:16,453 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-20 21:50:16,656 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-20 21:50:16,718 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-20 21:50:16,765 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-20 21:50:16,828 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-20 21:50:16,859 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-20 21:50:16,953 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-20 21:50:16,968 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-20 21:50:17,125 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-20 21:50:17,359 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-03-20 21:50:17,421 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-20 21:50:17,468 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-20 21:50:18,078 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-20 21:50:18,125 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-20 21:50:18,203 INFO [WebServer] WebServer starting on port 8895
2011-03-20 21:50:18,234 INFO [Device] Created UPnP Device with UUID: b8788ec1-4308-32fc-a48f-2532c9b147a9, bound address: 192.168.2.4
2011-03-20 21:50:18,281 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-20 21:50:18,281 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-20 21:50:18,296 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-20 21:50:18,296 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-20 21:50:18,296 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-20 21:50:18,296 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-20 21:50:18,296 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300654218296, LastAccessTime = 1300654218296, getTimeToLiveSeconds() = -1, createTime = 1300654218296 ]
2011-03-20 21:50:18,312 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-20 21:50:18,312 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-20 21:50:18,312 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-20 21:50:18,312 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-20 21:50:18,312 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-20 21:50:18,312 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-20 21:50:18,312 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-20 21:50:18,312 INFO [CompositeCacheConfigurator] Finished configuration in 16 ms.
2011-03-20 21:50:18,328 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-20 21:50:18,328 INFO [EventDispatcher] Starting EventDispatcher
2011-03-20 21:50:18,328 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-20 21:50:18,343 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Pakketplanner-minipoort) and address 192.168.2.4, timeout = 0
2011-03-20 21:50:18,343 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-20 21:50:18,343 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-20 21:50:44,562 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-20 21:50:44,578 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-20 21:53:24,031 INFO [ServiioConsole] Starting Serviio Console
2011-03-20 21:53:24,171 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-03-20 21:53:28,375 INFO [Messages] Loaded console message bundle for locale: en
2011-03-20 21:53:29,296 INFO [Messages] Loaded console message bundle for locale: en
2011-03-20 21:53:29,406 INFO [UpdateChecker] Checking if a new version is available
2011-03-20 21:53:35,765 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-03-20 21:53:36,078 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-03-20 23:21:08,703 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-20 23:21:08,906 INFO [WebServer] WebServer shutting down
2011-03-20 23:21:08,906 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-20 23:21:08,906 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-20 23:21:08,906 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-20 23:21:11,171 INFO [DatabaseManager] Shutting down database
2011-03-20 23:21:11,171 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-20 23:21:11,296 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-21 20:14:19,046 INFO [ServiioConsole] Starting Serviio Console
2011-03-21 20:14:19,109 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-21 20:14:19,109 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-21 20:14:19,109 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-21 20:14:19,109 INFO [MediaServer] http://www.serviio.org
2011-03-21 20:14:19,109 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-03-21 20:14:19,109 INFO [MediaServer] OS Windows XP x86 5.1
2011-03-21 20:14:19,109 INFO [MediaServer] File encoding: windows-1252
2011-03-21 20:14:19,375 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-03-21 20:14:22,328 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-21 20:14:22,515 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-21 20:14:37,203 INFO [Messages] Loaded console message bundle for locale: en
2011-03-21 20:14:53,562 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-21 20:14:54,156 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-21 20:14:54,312 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-21 20:14:54,390 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-21 20:14:54,437 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-21 20:14:54,500 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-21 20:14:54,531 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-21 20:14:54,625 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-21 20:14:54,656 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-21 20:14:54,828 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-21 20:14:55,093 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-03-21 20:14:55,156 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-21 20:14:55,203 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-21 20:14:58,406 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-21 20:14:58,531 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-21 20:14:58,781 INFO [WebServer] WebServer starting on port 8895
2011-03-21 20:14:58,843 INFO [Device] Created UPnP Device with UUID: b8788ec1-4308-32fc-a48f-2532c9b147a9, bound address: 192.168.2.4
2011-03-21 20:14:59,171 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-21 20:14:59,203 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-21 20:14:59,218 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-21 20:14:59,218 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-21 20:14:59,218 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-21 20:14:59,218 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-21 20:14:59,218 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300734899218, LastAccessTime = 1300734899218, getTimeToLiveSeconds() = -1, createTime = 1300734899218 ]
2011-03-21 20:14:59,218 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-21 20:14:59,343 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-21 20:14:59,343 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-21 20:14:59,343 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-21 20:14:59,343 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-21 20:14:59,343 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-21 20:14:59,343 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-21 20:14:59,343 INFO [CompositeCacheConfigurator] Finished configuration in 140 ms.
2011-03-21 20:14:59,343 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-21 20:14:59,343 INFO [EventDispatcher] Starting EventDispatcher
2011-03-21 20:14:59,343 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-21 20:14:59,421 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Pakketplanner-minipoort) and address 192.168.2.4, timeout = 0
2011-03-21 20:14:59,453 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-21 20:14:59,453 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-21 20:15:07,375 INFO [Messages] Loaded console message bundle for locale: en
2011-03-21 20:15:07,484 INFO [UpdateChecker] Checking if a new version is available
2011-03-21 20:15:25,531 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-03-21 20:15:25,875 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-21 20:15:25,875 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-21 20:15:26,328 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-03-21 20:17:21,359 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-21 20:17:21,562 INFO [WebServer] WebServer shutting down
2011-03-21 20:17:21,562 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-21 20:17:21,562 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-21 20:17:21,562 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-21 20:17:24,468 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-03-21 20:17:24,828 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-21 20:17:24,828 INFO [DatabaseManager] Shutting down database
2011-03-21 20:17:25,000 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-21 20:19:16,937 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-21 20:19:16,953 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-21 20:19:16,953 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-21 20:19:16,953 INFO [MediaServer] http://www.serviio.org
2011-03-21 20:19:16,953 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-03-21 20:19:16,953 INFO [MediaServer] OS Windows XP x86 5.1
2011-03-21 20:19:16,953 INFO [MediaServer] File encoding: windows-1252
2011-03-21 20:19:16,953 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-21 20:19:17,359 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-21 20:19:17,437 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-21 20:19:25,609 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-21 20:19:26,171 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-21 20:19:26,406 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-21 20:19:26,500 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-21 20:19:26,546 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-21 20:19:26,609 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-21 20:19:26,640 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-21 20:19:26,734 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-21 20:19:26,765 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-21 20:19:26,906 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-21 20:19:27,156 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-03-21 20:19:27,218 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-21 20:19:27,265 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-21 20:19:30,843 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-21 20:19:30,921 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-21 20:19:31,656 INFO [WebServer] WebServer starting on port 8895
2011-03-21 20:19:31,812 INFO [Device] Created UPnP Device with UUID: b8788ec1-4308-32fc-a48f-2532c9b147a9, bound address: 192.168.2.4
2011-03-21 20:19:32,187 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-21 20:19:32,234 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-21 20:19:32,250 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-21 20:19:32,250 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-21 20:19:32,250 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-21 20:19:32,250 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-21 20:19:32,250 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300735172250, LastAccessTime = 1300735172250, getTimeToLiveSeconds() = -1, createTime = 1300735172250 ]
2011-03-21 20:19:32,250 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-21 20:19:32,609 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-21 20:19:32,609 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-21 20:19:32,609 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-21 20:19:32,609 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-21 20:19:32,609 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-21 20:19:32,609 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-21 20:19:32,609 INFO [CompositeCacheConfigurator] Finished configuration in 375 ms.
2011-03-21 20:19:32,609 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-21 20:19:32,609 INFO [EventDispatcher] Starting EventDispatcher
2011-03-21 20:19:32,609 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-21 20:19:32,828 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Pakketplanner-minipoort) and address 192.168.2.4, timeout = 0
2011-03-21 20:19:32,875 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-21 20:19:32,875 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-21 20:19:45,750 INFO [ServiioConsole] Starting Serviio Console
2011-03-21 20:19:45,859 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-03-21 20:19:48,359 INFO [Messages] Loaded console message bundle for locale: en
2011-03-21 20:19:49,218 INFO [Messages] Loaded console message bundle for locale: en
2011-03-21 20:19:49,328 INFO [UpdateChecker] Checking if a new version is available
2011-03-21 20:19:56,750 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-03-21 20:19:57,093 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-03-21 20:19:59,296 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-21 20:19:59,296 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-21 21:38:37,031 INFO [WebServer] WebServer shutting down
2011-03-21 21:38:37,031 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-21 21:38:37,031 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-21 21:38:37,031 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-21 21:38:38,109 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-03-21 21:38:39,281 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-21 21:38:39,281 INFO [WebServer] WebServer starting on port 8895
2011-03-21 21:38:39,281 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-21 21:38:39,281 INFO [EventDispatcher] Starting EventDispatcher
2011-03-21 21:38:39,281 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-21 21:38:39,281 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-21 21:38:39,281 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Pakketplanner-minipoort) and address 192.168.2.4, timeout = 0
gregory
Post Mon Mar 21, 2011 9:22 pm
My PC:
IP = 192.168.2.4
Subnetmasker = 255.255.255.0
Standard gateway = 192.168.2.1
My PS3:
Connection method = All automatic
Speed and Duplex = Detect automatically
Adress-settings = Automatic
IP = 178.119.205.239
Subnetmasker = 255.255.240.0
Standard Gateway = 178.119.192.1
Primairy DNS = 195.130.131.5
Secondary DNS = 195.130.130.133
Proxy Server = not used
UPnP = not available
NAT Type = Type 1
Should I perhaps manually change the settings in my PS3 ?
Post Mon Mar 21, 2011 9:48 pm
gregory wrote:My PC:
IP = 192.168.2.4
My PS3:
NAT Type = Type 1
The 2 devices are on completely different subnets so it wont work.
gregory
Post Mon Mar 21, 2011 10:43 pm
ok , switched some cables, put my PS3 in same router as my PC? now they have a similar IP adress
Here's my new log, atleast I think that's the new log ^^
2011-03-21 23:35:34,843 INFO [ServiioConsole] Starting Serviio Console
2011-03-21 23:35:34,890 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-03-21 23:35:42,156 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-03-21 23:35:49,281 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-03-21 23:35:49,375 INFO [Messages] Loaded console message bundle for locale: en
2011-03-21 23:35:56,609 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-03-21 23:36:04,468 INFO [ServiioConsole] Leaving Serviio Console
2011-03-21 23:36:10,578 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-21 23:36:10,578 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-21 23:36:10,578 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-21 23:36:10,578 INFO [MediaServer] http://www.serviio.org
2011-03-21 23:36:10,578 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-03-21 23:36:10,578 INFO [MediaServer] OS Windows XP x86 5.1
2011-03-21 23:36:10,578 INFO [MediaServer] File encoding: windows-1252
2011-03-21 23:36:10,671 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-21 23:36:10,718 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-21 23:36:11,609 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-21 23:36:11,843 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-21 23:36:11,953 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-21 23:36:12,015 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-21 23:36:12,062 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-21 23:36:12,125 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-21 23:36:12,156 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-21 23:36:12,250 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-21 23:36:12,281 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-21 23:36:12,437 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-21 23:36:12,718 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-03-21 23:36:12,781 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-21 23:36:12,828 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-21 23:36:12,890 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-21 23:36:12,906 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-21 23:36:12,921 INFO [WebServer] WebServer starting on port 8895
2011-03-21 23:36:12,937 INFO [Device] Created UPnP Device with UUID: b8788ec1-4308-32fc-a48f-2532c9b147a9, bound address: 192.168.2.4
2011-03-21 23:36:12,953 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-21 23:36:12,953 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-21 23:36:12,953 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-21 23:36:12,953 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-21 23:36:12,968 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-21 23:36:12,968 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-21 23:36:12,968 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300746972968, LastAccessTime = 1300746972968, getTimeToLiveSeconds() = -1, createTime = 1300746972968 ]
2011-03-21 23:36:12,968 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-21 23:36:12,968 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-21 23:36:12,968 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-21 23:36:12,968 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-21 23:36:12,968 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-21 23:36:12,968 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-21 23:36:12,968 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-21 23:36:12,968 INFO [CompositeCacheConfigurator] Finished configuration in 15 ms.
2011-03-21 23:36:12,984 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-21 23:36:12,984 INFO [EventDispatcher] Starting EventDispatcher
2011-03-21 23:36:12,984 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-21 23:36:12,984 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-21 23:36:12,984 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-21 23:36:16,031 INFO [ServiioConsole] Starting Serviio Console
2011-03-21 23:36:16,078 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-03-21 23:36:16,828 INFO [Messages] Loaded console message bundle for locale: en
2011-03-21 23:36:20,796 INFO [Messages] Loaded console message bundle for locale: en
2011-03-21 23:36:20,906 INFO [UpdateChecker] Checking if a new version is available
2011-03-21 23:36:26,515 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-03-21 23:36:26,812 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-03-21 23:36:39,187 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-21 23:36:39,187 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-21 23:39:05,921 INFO [RendererManager] Stored a new renderer: uuid='c7c8265c-74ee-496e-9229-8d02fa6e578d', name = 'PS3', ipAddress='192.168.2.4', profile = '4'
2011-03-21 23:39:05,921 INFO [RendererManager] Stored a new renderer: uuid='29088ce6-42d8-4a4a-8915-0b3b2dfcb0c7', name = 'PC', ipAddress='192.168.2.3', profile = '1'
2011-03-21 23:39:05,984 INFO [WebServer] WebServer shutting down
2011-03-21 23:39:05,984 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-21 23:39:05,984 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-21 23:39:05,984 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-21 23:39:08,015 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-03-21 23:39:08,250 INFO [Device] Updated bound IP address of Device with UUID: b8788ec1-4308-32fc-a48f-2532c9b147a9, bound address: 192.168.2.3
2011-03-21 23:39:08,250 INFO [WebServer] WebServer starting on port 8895
2011-03-21 23:39:08,250 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-21 23:39:08,250 INFO [EventDispatcher] Starting EventDispatcher
2011-03-21 23:39:08,250 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-21 23:39:08,250 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-21 23:39:08,250 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Pakketplanner-minipoort) and address 192.168.2.3, timeout = 0
2011-03-21 23:39:17,593 INFO [WebServer] WebServer shutting down
2011-03-21 23:39:17,593 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-21 23:39:17,593 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-21 23:39:17,593 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-21 23:39:17,609 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-21 23:39:18,890 INFO [WebServer] WebServer starting on port 8895
2011-03-21 23:39:18,890 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-21 23:39:18,890 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-21 23:39:18,890 INFO [EventDispatcher] Starting EventDispatcher
2011-03-21 23:39:18,890 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-21 23:39:18,890 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Pakketplanner-minipoort) and address 192.168.2.3, timeout = 0
2011-03-21 23:41:30,593 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-21 23:41:30,812 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-21 23:41:30,812 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
If u need any other info needed to solve my problem , feel free to ask , A million thanks to the people trying to help me out here.
Post Mon Mar 21, 2011 11:31 pm
Re: Serviio won't find my PS3
so even connected to same router they still dont see each other ???
Post Tue Mar 22, 2011 10:53 am
you are binding Serviio to 192.168.0.4, which is the same IP as the PS3. The Bound IP address must include the IP of your PC!!
you are binding Serviuio to 192.168.0.4, which is the same IP as the PS3. The Bound IP address must include the IP of your PC!!
