mediabrowser
user12345678
Post Sun May 14, 2017 3:29 am
mediabrowser
I am trying to setup mediabrowser on a sagecom fast 5260 router and can't seem to figure out how to foward the ports on the router.
I have done this before but on different routers with different programs.
Thanks for your help in this
Post Sun May 14, 2017 8:44 am
Re: mediabrowser
user12345678
Post Sun May 14, 2017 4:02 pm
Re: mediabrowser
I am fuzzy when it asks for remote host in my router?
I entered 0.0.0.0
Post Sun May 14, 2017 4:12 pm
Re: mediabrowser
user12345678 wrote:I am fuzzy when it asks for remote host in my router?
I entered 0.0.0.0
Remote host is the IP address of the computer on the Internet that is permitted to use this forwarding rule. You are correct entering 0.0.0.0, as that is interpreted as any address.
user12345678
Post Sun May 14, 2017 6:25 pm
Re: mediabrowser
i got the ports fixed canyouseeme sees it
over on serviio i entered where it says external address i tried the ip and clicked check conntivty and still gives error
user12345678
Post Sun May 14, 2017 6:27 pm
Re: mediabrowser
using serviio pro 1.31.1 on win xp
user12345678
Post Sun May 14, 2017 6:31 pm
Re: mediabrowser
i set static ip on serviio machine forgot to add that detail
user12345678
Post Sun May 14, 2017 8:47 pm
Re: mediabrowser
i noticed in the log file the port listed is 23423
on this site http://serviio.org/component/content/ar ... diabrowser is lists port 23424
Post Sun May 14, 2017 9:24 pm
Re: mediabrowser
Port 23423 is for the console, not MediaBrowser. 23424 is correct for the browser. Since the URL is different between the console and browser, that would explain if it wasn't working before.
user12345678
Post Sun May 14, 2017 9:39 pm
Re: mediabrowser
ok so I had it set correctly
everything i enter into the external ip on serviio dont work
i can access it within my network but not outside it
Post Sun May 14, 2017 10:32 pm
Re: mediabrowser
The External Address field in Serviio Console isn't used by Serviio (it's used by other apps) so you can leave it blank.
Perhaps post a screen shot of your port forward page from your router. When testing ensure you are connected to an external network ie. don't try your external address from your home network, some providers don't allow that. Lastly ensure your external address is a public address and is not being natted by your provider.
user12345678
Post Sun May 14, 2017 11:44 pm
Re: mediabrowser
screen shot of my ports
user12345678
Post Mon May 15, 2017 12:01 am
Re: mediabrowser
i had protcol set to tcp-udp but changed it to tcp
user12345678
Post Mon May 15, 2017 1:29 am
Re: mediabrowser
natted?? its been like 10years since i had to foward ports how do i find out if its been natted?
user12345678
Post Mon May 15, 2017 2:39 am
Re: mediabrowser
its working great thanks for all your help
user12345678
Post Mon May 15, 2017 2:42 am
Re: mediabrowser
right now I have it working but i want to change the url from www.ipaddress:23434/MediaBrowser/ to www.custom:23434/Mediabrowser/
user12345678
Post Wed May 17, 2017 2:21 am
Re: mediabrowser
url is masked this is so cool
thank you guys for your help
I also have figured out a way to send it to my Roku from pc
RokuCast
Post Wed May 17, 2017 11:55 am
Re: mediabrowser
user12345678 wrote:natted?? its been like 10years since i had to foward ports how do i find out if its been natted?
I realize you have it working, but to answer this question: you can see your "public" IP address in your router information page. Then go to whatismyipaddress.com and see if it's the same number. If not, then your ISP has a firewall between you and the Internet, so NAT is enabled on their firewall. If that is ever the case, the only way you can have something visible from the Internet is to have your ISP add a port forwarding rule to their firewall just like you did to yours.
But since yours is working, that shouldn't be an issue. :D
user12345678
Post Thu May 18, 2017 2:47 am
Re: mediabrowser
ah yes yes
I see that never thought of what to call that till now
Thank you
