Slow to discover - can I adjust? Also resume question.
Ramrunner
Post Thu May 11, 2017 9:11 am
Hey guys, been running Serviio on a Thecus unsupported for years not too many problems.
Since I've just upgraded to a QNAP with a fully supported Serviio (1.8?) I have a problem where the discovery of the Serviio doesn't happen for up to 2 minutes. When I was running the really old version on Thecus, it was pretty much turn TV or media player on and Serviio showed. This new version can take up to two minutes which is very frustrating when you've just turned the TV on and are sitting around waiting for Serviio to show.
I recently found (but did not bookmark stupidly) an article where someone mentioned you can set the discovery times in the config file somehow to shorten the delay. But no real explanation of how or where.
Does anybody know how to do this?
ALSO
the new version does not mark an episode I'm watching as current UNTIL the episode has reached the 5 minute mark. For example I'm watching show X episode 1, it finishes and flick over to Show X episode 2. If I stop the show anywhere before 5 minutes, it will still keep episode 1 marked as the currently watching episode. This is annoying as obviously I'm now watching episode 2 and when I get back to watch shows I want IT marked as the current one. This doesn't happen unless I allow it to hit the 5 minutes mark.
This behaviour has also been introduced in a later version as this before was also working as expected.
Any ideas on that one also?
Thanks for reading guys
Post Fri May 12, 2017 12:52 pm
Re: Slow to discover - can I adjust? Also resume question.
Re 1 - look at the serviio.advertisementDuration system property: http://www.serviio.org/index.php?option ... icle&id=43
Re 2 - that is now the expected behaviour. It shows a show that has been watched, rather than one that you're watching.
Ramrunner
Post Thu May 18, 2017 12:51 am
zip wrote:Re 1 - look at the serviio.advertisementDuration system property: http://www.serviio.org/index.php?option ... icle&id=43
Awesome thank you. I've ssh'd into the box but don't know where to look as your examples for Windows and OSX on the FAQ are very clear, Linux just says look for serviio.sh.
Does anyone know where this file resides on QNAP?
ALSO
180 means broadcasting every 3 minutes I presume, is there a "safe" limit? I was thinking 10-30 so it's almost immediate on my TV and other devices but I also assume that would also broadcast a lot of unnecessary network traffic.
What did it USED to be set to in the older versions as a guide?
Thanks for your help so far. Great service!
Post Thu May 18, 2017 7:58 am
It's always been on 180, but potentially some broadcast packets are being lost on your network.
On Qnap it shoud be under /share/MD0_DATA/.qpg/seriio/bin (or something like that, going by memory ;-) )
Ramrunner
Post Thu May 18, 2017 9:16 am
zip wrote:It's always been on 180, but potentially some broadcast packets are being lost on your network.
Almost zip..... :D
At least I knew where to start.....
OK everyone for future reference on QNAP, the serviio.sh is under:
/share/CACHEDEV1_DATA/.qpkg/Serviio
I've added " -Dserviio.advertisementDuration=10" to the line that said JAVA_SERVIIO_OPTIONS
Restarted Serviio. Waited a few minutes for the default 10 second broadcasts to happen.
Turn on TV - BAM - Serviio detected and there immediately.
Turn on BluRay - ALSO BAM - Serviio in the list immediately.
10 may be a little OTT but it works.
Thanks for the help zip - your guide was enough to get me there. I used cp to make a copy of the file first then vi to edit it immediately taking me back 26 YEARS when I learnt Unix at University. Amazing how things come back even remembered I needed to hit insert first, ESC to get back then w to write and q to quit without Googling. If only I can remember what I did yesterday......
Thanks guys hope this helps others.
Post Thu May 18, 2017 11:51 am
Man, I haven't used vi in over a decade! :lol: Guess I need to brush up on my *nix skills.
