Subtitle not working on Samsung TV H5500
mandark
Post Thu May 25, 2017 3:25 pm
I am a recent convert to Serviio and for many years I've been using MiniDLNA. MiniDLNA never missed any subtitle to be shown on my Samsung TV H5500 but the same video with the same subtitle wouldn't show on the TV using Serviio. If I play the video on my mobile using BubbleUPnP as Serviio server, it renders the subtitles correctly on my mobile screen.
Any help is highly appreciated.
TIA
Post Thu May 25, 2017 9:36 pm
Re: Subtitle not working on Samsung TV H5500
MediaInfo details for the file?
Are the subtitles in a separate file or embedded in the media file?
What are your Subtitle settings in Serviio Console?
Which profile are you using for the Samsung?
When MiniDLNA played the subtitles, were they selectable via your remote (ie. could you turn them on or off, or were they always on - this may indicate that MiniDLNA was burning them in)?
mandark
Post Thu May 25, 2017 11:20 pm
DenyAll wrote:Hi, See my responses below
Media Info
Unique ID                                : 32787313795868375802320587106739446825 (0x18AA9B60A702BCF2E75F97F2886E6429)
Complete name                            : /opt/media/Prison.Break.S05E07.720p.HDTV.x264-KILLERS[ettv]/Prison.Break.S05E07.720p.HDTV.x264-KILLERS[ettv].mkv
Format version                           : Version 4 / Version 2
File size                                : 806 MiB
Duration                                 : 43 min 56 s
Overall bit rate                         : 2 563 kb/s
Encoded date                             : UTC 2017-05-17 02:08:26
Writing application                      : mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 22 2014 08:19:39
Writing library                          : libebml v1.3.0 + libmatroska v1.4.1
Format settings, ReFrames                : 5 frames
Bit rate                                 : 2 128 kb/s
Frame rate                               : 23.976 (24000/1001) FPS
Bits/(Pixel*Frame)                       : 0.096
Stream size                              : 669 MiB (83%)
Writing library                          : x264 core 148 r2762 90a61ec
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=22 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Color range                              : Limited
Bit rate                                 : 384 kb/s
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 spf)
Stream size                              : 121 MiB (15%)
Service kind                             : Complete Main
Subtitle is in a separate SRT file. There's no builtin subtitle.
Enable subtitles (enabled)
Enable extraction of text-based subtitles embedded in video files (disabled)
Try to automatically detect subtitle character encoding (enabled)
Character encoding: UTF-8
Burn-in subtitles (disabled)
Enable retrieve from opensubtitle (enable and provided my account info)
Generic DNLA Profile
I do not know if MiniDNLA burns the subtitle in or not but I know MiniDNLA takes roughly around 2-5% of CPU on my very old dual core processor laptop. So guessing it isn't burning in.
