Windows 10 Creators Update Problem
xhollyx
Post Sat May 06, 2017 9:31 am
After upgrading to Windows 10 Creators Update 1703 Serviio works no more. I did an uninstall and cleaning all left entries. After a new install it seems to work, but when reading a library it stops after some minutes and the program is hanging. The server is no more reachable. I did it serveral times on 4 different Computers and its all the same. The only one with Aniversary Update still works without any problem.
Dypsis
Post Sat May 27, 2017 1:23 am
Re: Windows 10 Creators Update Problem
Yeah, I have the same problem.
I think it might be related to this Windows 10 Creators Update network issue.
Post Sat May 27, 2017 3:15 am
My computer just updated to 1703 an hour ago and Serviio's working fine. However, I have my firewall disabled. Not certain if that's part of the issue.
Reading that Technet article makes me think it's an IPv6 issue. I run a DNS server on my network, but only for IPv4. There are times I can't connect to any of my computers by name but it works if I use the IPv4 address. There's instructions somewhere on the web that tells Win 10 to use IPv4 as primary instead of v6, and that might help.
Dypsis
Post Sat May 27, 2017 3:22 am
Yes, I think you are right.
It's a Windows Firewall issue. If I disable Windows Firewall, then Serviio works.
I can't figure out how to fix Windows Firewall though.
Dypsis
Post Sat May 27, 2017 5:47 am
I completely uninstalled Serviio and Java using Revo Uninstaller, then reinstalled.
It works now.
Post Sun May 28, 2017 3:22 am
That's happened to people in the past. Serviio is supposed to configure the firewall to allow Serviio to work, but seems to be times the settings don't take. I don't blame Serviio for that. Most likely something Windows related. :D
Users browsing this forum: No registered users and 103 guests
