Subtitle burn in which are NOT SRT
mylk
Post Sun May 28, 2017 1:11 pm
Hi all,
My TV supports SRT files, but no other formats; like ASS.
With burn in the ASS works fine, but with the option enabled the SRT will be burned in too which I do not want.
Is there a way to disable SRT subtitle burn-in but leave it enabled for other formats?
Post Sun May 28, 2017 3:50 pm
Re: Subtitle burn in which are NOT SRT
ASS subtitles are converted to srt, so you don't need to enable burning in subtitles at all.
mylk
Post Sun May 28, 2017 4:06 pm
If I have burnin disabled and try to play something with an ASS sub then the tv(LG) will just say it is unsupported format.
With burnin enabled it play fine with the subtitle, same with SRT.
Post Tue May 30, 2017 2:11 pm
mylk wrote:If I have burnin disabled and try to play something with an ASS sub then the tv(LG) will just say it is unsupported format.
Can you post detailed log of playing the file with burned-in and disabled burned-in subtitles?
Users browsing this forum: Baidu [Spider] and 67 guests
