Unrecognized device
smarty8
Post Thu Mar 02, 2017 3:38 am
Unrecognized device
Serviio refers to devices that he could not recognize as Unrecognized device in the Device Name field.
I would like to be able to modify this field.
Post Thu Mar 02, 2017 9:27 pm
Re: Unrecognized device
Coming in 1. 9
smarty8
Post Fri Mar 03, 2017 7:58 am
zip wrote:Coming in 1. 9
THX
Jean-Max
Post Fri Jun 02, 2017 1:59 pm
Very good news :D !
Once device correctly connected,
Once device verified by its IP and MAC address,
Once correct profile chosen end tested by user on the device,
...It would be useful to correctly name it by replacing this sad "unrecognized device" term ;)
Now waiting for 1.9 ...
-> Is-it possible, at this time, to download 1.9 beta for testing ?
Thanks !
Jean-Max
Sherwood A+P-965 | Inwall JM-LAB | TV Samsung UE48HU7500 | Proj Sony sxrd W40 | Media Player Zbox AD10 | Dvb-T Panasonic DMR-BWT700 | Dvb-T HDHomerun Connect 2 | Nas Thecus N7700Pro | PC Windows 10 + Serviio Pro 1.9.1
Post Fri Jun 02, 2017 2:12 pm
Sure, I've added you to beta testers group, head over to the beta forum and download the beta.
Jean-Max
Post Fri Jun 02, 2017 3:12 pm
Thanks Peter :D
I will test it and let you know here the results
I will try the double install mode read in this thread:
viewtopic.php?f=8&t=4018
Best regards from France
Jean-Max
Jean-Max
Post Fri Jun 16, 2017 6:29 pm
I tested 1.9 Beta :
"Unrecognized device" problem successfully solved by Beta 1.9.1 :
http://forum.serviio.org/viewtopic.php?f=8&t=23769&p=114453#p114453
Jean-Max
Return to Feature requests
Users browsing this forum: Google [Bot] and 9 guests
