Custom Thumbnails
jimgeldermann
Post Fri Jun 09, 2017 9:42 pm
Custom Thumbnails
I've been creating thumbnails for my videos, placing them into a folder with the video and grabbing the thumbnail url with the restapi, to store in my database that renders HTML5 pages. The thumbnails show up correctly when the page loads, but as you can see from the attachment they are very blurry.
I've tried different pixels and jpeg and png, but the results are the same.
Thumbnail opened in Chrome
Thumbnail HTML5 Serviio
Post Sat Jun 10, 2017 12:28 am
Re: Custom Thumbnails
The first thing to set is a setting in the profiles.xml file. At the bottom of the very first profile (the Generic profile) you will see this line:
<ThumbnailsResolution>DLNA</ThumbnailsResolution>
Change DLNA to HD and then either restart the Serviio process or reboot the computer. Now see if that is sufficient resolution for your use.
jimgeldermann
Post Sat Jun 10, 2017 3:28 am
Thanks. Much better.
Sent from my iPhone using Tapatalk
Post Sat Jun 10, 2017 10:05 pm
No problem. Remember that you'll need to make that change every time Serviio is updated. The update install will create a new Profiles file with the default setting.
