Not reading wavpack metadata
shakeshuck
Post Sun Jun 11, 2017 9:17 pm
I just installed serviio for the first time.
If I use MediaBrowser to look at my files, the track names appear (from the file name I guess) but everything else shows as 'unknown', i.e. no artist/album details.
These are wavpack files, with metadata embedded in each file.
Post Sun Jun 11, 2017 11:21 pm
Re: Not reading wavpack metadata
Not certain Serviio supports that kind of metadata. Since yours isn't appearing, that seems to be the case. See this page (http://www.serviio.org/index.php?option ... icle&id=12) for more information about metadata. If you desire to use the online metadata sources, your files need to be named in a particular format. The same page linked above explains the naming convention as well.
Post Tue Jun 13, 2017 3:11 pm
Yes, that is not supported on this format. Should be done as a part of: https://bitbucket.org/xnejp03/serviio/i ... -for-audio
shakeshuck
Post Tue Jun 13, 2017 5:22 pm
Nice to know it's on the 'to do' list.
Thanks Petr.
