Training videos but no "online metadata"
rumplestiltskin
Post Sat Jun 17, 2017 9:34 pm
I hope I'm using the correct description. Here's the problem (and it's admittedly a minor one):
I have a number of training videos (Lynda.com mostly). I've renamed them so they're like this:
LyndaAccess.S01E01.mp4
LyndaAccess.S01E02.mp4
LyndaAccess.S02E01.mo4
etc.
The "series" is what Lynda refers to as a "chapter" and "episodes" are simply the order in which you would watch them.
Here's my question: How do I get a folder full of these files to appear in a "Series"? In "Folder" view, they show up just fine. Is it because there is no bona fide series by that name anywhere online?
Advice appreciated. Thanks!
Post Sun Jun 18, 2017 8:01 am
Re: Training videos but no "online metadata"
Yes, by default Serviio will try and match the filename of your media files to an online source (thetvdb.com) to try and find a metadata for the file (metadata = series title, actors, directors, etc). For your Lynda files there is no metadata info in the online sources.
It can be done, but it will be painful. You will need to change your source for metadata in Serviio Console, Metadata from "Online metadata sources" to something locally (eg. "XMBC .nfo files"). This will allow you to create your own local metadata files (.nfo files) and store them in the same folder as your media files.
Now for the bad news... once its set, it affects all shares. You can't (yet) have some shares use the on-line source and others .nfo files. As such, you will then need to create .nfo files for all your media (even those ones where you could have used online sources). There are some tools around that will use the online sources to create these files automatically for you (for TV series and movies), but you will still need to create them manually for all your Lynda files.
Users browsing this forum: Google [Bot] and 48 guests
