Tv3Play, Tv6Play, Tv8Play, Tv10Play in multiple countries
ottomatic
Post Thu Nov 13, 2014 12:30 am
UPDATE 2014-11-18: Posted new plugin versions as I found new formats in the tv3play streaming chain.
Also, the rss feed plugin needed to be in a separate file in order to get picked up by the server
Separate Web resource and RSS plugins for Serviio Media Server
Targeted at MTG sites tv3play, tv6play, tv8play, tv10play in different top domains
Should work in the following countries;
    Sweden
    Norway (including viasat4play.no)
    Denmark
    Estonia
    Lithuania
And probably most other countries where MTG use a standard play service.
Use the Web Resource plugin to add individual shows as Web Resource feeds, e.g.:
http://www.tv3play.se/program/blacklist
Or add legacy RSS feeds for the rss feed plugin:
http://www.tv3play.se/rss/recent
http://www.tv3play.se/rss/mostviewed
http://www.tv3play.se/rss/highestrated
One thing to note:
The online streams from tv3play.se seem to have a bitrate at the highest quality which makes the stream rendering fail on my Samsung Blueray player (Profile E/F).
I Fixed this by editing the profiles.xml file inside Serviio:s config directory according to instructions given in this post:
viewtopic.php?f=7&t=15544&hilit=Samsung+D#p95586
If you get similar probolems, you may need to do the same. Or upgrade your firmware :-)
Regards
/ O
Tv3-6-8-10-play-rss.groovy
Tv3Play, Tv6Play, Tv8Play, Tv10Play Rss feed plugin version 2
(15.68 KiB) Downloaded 1516 times
Tv3-6-8-10-play.groovy
Tv3Play, Tv6Play, Tv8Play, Tv10Play Web resource plugin version 2
(23.61 KiB) Downloaded 1619 times
ottomatic
Post Sat Nov 15, 2014 10:01 pm
Re: Tv3Play, Tv6Play, Tv8Play, Tv10Play in multiple countrie
Update: not sure if the legacy rss works.
But the Web resource implementation does.
I forgot to mention the targeted play services use soft subtitles (kept in external xml files) and this is not supported by the Serviio online plugin framework. So, although the plugin knows where the subtitles are located, they cannot be shown. Sorry.
/ O
ottomatic
Post Tue Nov 18, 2014 1:32 am
Hi everyone,
New plugin version(s) posted today.
I found that my previous online feeds were not working because some meta data files along the stream delivery chain had changed.
And while I was at it, I fixed the Rss feed parsing by putting that in a separate plugin.
So, if you want to both be able to add show links and legaxy rss feeds, you now need to download two plugins.
Regards
/ O
audis78
Post Tue Jun 27, 2017 6:36 pm
I downloaded your plugin for http://www.tv{x}play.{xx} and I changed it to http://play.tv3.lt don't know how with quality, but play.tv3.lt plays videos :)
If I correct changed it so it must work with other pages with http://play.tv{x}.{xx}
If you want, can download it from there
(23.59 KiB) Downloaded 1404 times
Thank you for that plugin, it was like example for my changes :)
Return to Available plugins
