Problem with shared folders
serviiouser22
Post Wed Jul 19, 2017 4:15 pm
I am running Serviio Pro 1.8 on Windows 10. I successfully defined multiple shared folders.
For example:
c:\TvShows\Unwatched
d:\Unwatched
e:\myVideos\Unwatched
When I access the folders from my Samsung devices, I see all the Unwatched folders (correct number). However when I look at the contents of the folders, they all display as whatever directory is the first shared folder that I defined.
Post Thu Jul 20, 2017 9:10 am
Re: Problem with shared folders
I assume you go there via the Folders category?
Post Sun Sep 10, 2017 4:07 pm
This is a bug in the Samsung software. It asks for the same folder ID when selecting the different folders with the same name.
