Fetch Tv - Australia
pfinlay75
Post Sun Jul 23, 2017 7:12 am
Hi All,
I am trying to set up Serviio using Fetch Tv as my media server.
Firstly, does anyone have a profile or know if any of the profiles listed in the Serviio profile area work for Fetch Tv?
Secondly, If i set to present my Videos as Folders only it will only load 426 movie files from a total of 860 move files that i have on my hdd. I think the issue is due to profiles?? I have tried many profiles and nothing really provides me with the full list of movies in my folder.
If instead of using the Folders in the presentation I use the Titles than i get to see all of the movies listed. Can anyone explain this or assist in helping me resolve the presented folders not displaying all of the movies for me?
cheers,
Post Sun Jul 23, 2017 12:57 pm
Re: Fetch Tv - Australia
I think you mean that you want to use Fetch as your media player (not Media Server). I have Fetch TV (Optus TV by Fetch) and could assist in developing a profile.
Having said that I had a quick play and the Generic Profile seems to work well for most of my media, so give that a go.
Suggests that you probably haven't got the movies named correctly and Serviio cannot collect the metadata. See my post viewtopic.php?f=5&t=10626&p=70544#p70544
pfinlay75
Post Mon Jul 24, 2017 9:42 am
yes you are right, my media player.
ok, i will check out the naming convention and then will advise.
cheers for the assist,
Pete.
pfinlay75
Post Tue Jul 25, 2017 7:31 am
Hi DenyAll,
ok, i set the moves to display movie.title [year] as suggested for serviio.
uninstalled and reinstalled serviio,
allowed serviio to go through the process to load back in the movies.
I have set the Presentation to Movies only and display content only.
Only 1 movie now shows in the Movie folder out of 830 movies that i have. Serviio profile is usiong the generic DLNA profile as well.
Is there anything else i need to check or do to make Fetch Tv see all the other movies?
Ta
Pete
