Console Label Problem
eyupaltindal
Post Tue Aug 01, 2017 10:44 pm
Hi everyone,
I have updated serviio from v1.6 to v1.9
I did not uninstall v1.6 because I did not want to lose settings. After updating some labels on the console do not seem normal. They seem like below. Can anybody help me, please?
(I use windows XP)
{{'tab_status_connected_devices' | translate}}
{{'tab_status_connected_devices_overview' | translate}}
Post Tue Aug 01, 2017 11:16 pm
Re: Console Label Problem
Installing over the top does not lose any settings. I've done it many times.
I've also done clean installs with 1.9 and didn't see anything like that. I'm not certain if the two installations are conflicting somehow, or if the install didn't go right.
eyupaltindal
Post Tue Aug 01, 2017 11:30 pm
I uninstalled new v1.9 and installed again old version. Nothing changed.
Post Tue Aug 01, 2017 11:46 pm
eyupaltindal wrote:I uninstalled new v1.9 and installed again old version. Nothing changed.
OK, will have to let Zip check in on this.
eyupaltindal
Post Wed Aug 02, 2017 12:18 am
it was a browser problem. I cleaned the browser cache. Everything is fine right now. :)
thank you.
Post Wed Aug 02, 2017 12:07 pm
eyupaltindal wrote:it was a browser problem. I cleaned the browser cache. Everything is fine right now. :)
thank you.
Well, I wouldn't have considered that. Thanks for the update! :D
