Any Idea why the Serviio service stops after a few seconds?
DevXen
Post Mon Aug 07, 2017 1:50 am
I'm using windows. this is from the log. I tried installing the newest Serviio and that didn't fix. Any ideas on how to fix it?
Thanks,
-Dev
2017-08-06 19:45:02,605 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@387f44, see the next exception for details.
at org.apache.derby.impl.jdbc.EmbedConnection.bootDatabase(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.jdbc.InternalDriver$1.run(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:270)
at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:71)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:64)
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:82)
at org.serviio.MediaServer.main(MediaServer.java:126)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:62)
at com.exe4j.runtime.WinLauncher$2.run(WinLauncher.java:96)
Caused by: ERROR XJ040: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@387f44, see the next exception for details.
at org.apache.derby.impl.jdbc.SQLExceptionFactory.wrapArgsForTransportAcrossDRDA(Unknown Source)
... 28 more
Caused by: ERROR XSLAM: Cannot verify database format at {1} due to IOException: C:\Program Files\Serviio\library\db
at org.apache.derby.impl.store.raw.log.LogToFile.verifyLogFormat(Unknown Source)
at org.apache.derby.impl.store.raw.log.LogToFile.getLogFileAtPosition(Unknown Source)
at org.apache.derby.impl.store.raw.log.LogToFile.getLogFileAtBeginning(Unknown Source)
at org.apache.derby.impl.store.raw.log.Scan.getNextRecordForward(Unknown Source)
at org.apache.derby.impl.store.raw.log.Scan.getNextRecord(Unknown Source)
at org.apache.derby.impl.store.raw.log.FileLogger.redo(Unknown Source)
at org.apache.derby.impl.store.raw.log.LogToFile.recover(Unknown Source)
at org.apache.derby.impl.store.raw.RawStore.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.TopService.bootModule(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startModule(Unknown Source)
at org.apache.derby.impl.services.monitor.FileMonitor.startModule(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.bootServiceModule(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager$5.run(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager.bootServiceModule(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager.boot(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase$5.run(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.bootServiceModule(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.bootStore(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startProviderService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.findProviderAndStartService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startPersistentService(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.startPersistentService(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection$4.run(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.startPersistentService(Unknown Source)
... 25 more
Caused by: java.io.EOFException
at java.io.RandomAccessFile.readInt(RandomAccessFile.java:803)
... 63 more
2017-08-06 19:45:04,609 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:50)
Post Mon Aug 07, 2017 5:12 am
Re: Any Idea why the Serviio service stops after a few secon
Not 100% certain, but I believe your database is corrupted. My suggestion is to uninstall Serviio, ensure the install folder is gone (usually C:\Program Files\Serviio), then do a clean install and reconfigure. I don't think it's possible to just delete the DB and let Serviio rebuild it, but I could be mistaken.
Users browsing this forum: No registered users and 50 guests
