Serviio 1.9
josch.hh
Post Fri May 19, 2017 1:09 pm
Serviio 1.9
Cant wait to get the new release.
Any idea of the release date?
Post Fri May 19, 2017 7:39 pm
Re: Serviio 1.9
It should go to testing soon. You can sign up for the beta.
GrandM1961
Post Wed May 31, 2017 1:23 pm
Re: Serviio 1.9
I would like to become a beta tester and I have already the 1.9 beta alpha 1 but I can't see anything on the beta page or PM you.
Sony Bravia KDL-42W805A, iMac 27 inch late 2012, MacOS X 10.15 Beta 3
Post Thu Jun 01, 2017 8:01 am
Re: Serviio 1.9
added you, thanks
vitmak
Post Fri Jul 14, 2017 8:32 am
Re: Serviio 1.9
Hello, please add me to the beta testers.
jvthert
Post Mon Jul 17, 2017 12:03 pm
Re: Serviio 1.9
Same here. I'd love to try it out so please add me as well.
Scoty
Post Sun Jul 23, 2017 4:08 pm
Re: Serviio 1.9
Mee too please.
Post Sun Jul 23, 2017 6:04 pm
Re: Serviio 1.9
1.9 is out now
Reynaldo
Post Wed Jul 26, 2017 12:14 pm
Re: Serviio 1.9
zip wrote:1.9 is out now
External caption still not working for Oppo 205. :oops:
Reynaldo
chalkster
Post Mon Jul 31, 2017 2:50 am
Re: Serviio 1.9
having issues with new HTML5 remote viewer in new v1.9 . Not working either over web or on mediabrowser localhost.
Message Im getting on clicking play triangle button after a few seconds is 'hlsjs: Video file not found"
BTW I have transcoding off .. have updated java to latest v8. All other web interface functions seem to be working OK up to this play point.
Installing upgrade fm 1.8 seemed to go well without faults .
Any ideas?
edit - zipped debug log attached
2nd edit - problem sorted was a file source perm issue.. I run the service under other non- std credentials and the install stuffs it every time .. modified it and , BAM
pc5dczc_log.zip
(28.65 KiB) Downloaded 439 times
Reynaldo
Post Mon Jul 31, 2017 7:47 pm
Re: Serviio 1.9
As I wrote in Oppo 205, external caption does not work.
To remove the doubt, I tested with oShareUI software.
The Oppo 205 worked perfectly with external legend.
Why does not it work with Serviio?
Reynaldo
Reynaldo
Post Sat Aug 05, 2017 11:51 am
Re: Serviio 1.9
There is no answer, where is the zip?
Reynaldo
Post Sun Aug 06, 2017 2:25 pm
Re: Serviio 1.9
On holidays.
You will have to provide detail logs of playing the file in Serviio and ideally Wireshark capture when starting the file using the other software to compare.
Reynaldo
Post Sun Aug 06, 2017 6:41 pm
Re: Serviio 1.9
zip wrote:On holidays.
I am not using a PC, I am using a player Oppo 205.
It simply doesn't carry the outer caption.
With this program, oshare, that is very simple, it works perfectly in Oppo 205.
I don't know what's going on, I'll leave the program link that is freeware so you can analyze.
https://sourceforge.net/projects/oshare/
Thank you
Reynaldo
Post Mon Aug 07, 2017 6:18 pm
Re: Serviio 1.9
Will still need you to post detailed log when playing the file on oppo
audimees
Post Sat Sep 02, 2017 6:45 pm
Re: Serviio 1.9
vygeralex@gmail.com
Post Mon Dec 11, 2017 6:37 am
Re: Serviio 1.9
Users browsing this forum: No registered users and 54 guests
