Samsung QE65Q8CAM Serviio not found on TV
kardokaki
Post Mon Aug 07, 2017 10:29 am
I just installed Serviio on my MacBook Air and it worked fine. I shared a folder and it finds my TV automatically. But when I go to my TV to find the Serviio app there is no where to be found ?? How do I solve this.
Best regards,
Kardo
kardokaki
Post Mon Aug 07, 2017 11:28 am
Re: Samsung QE65Q8CAM Serviio not found on TV
I solved it. If anyone gets this problem you only need to go "Source" and there you can se Serviio.
Post Mon Aug 07, 2017 10:33 pm
OK, you were looking for an app. Serviio does not have an app, and just uses the Samsung DLNA functionality. As you noted, it is listed as an available source when connected to your network.
