BDT-220 No sound with A_EAC3 Audio Track
How can I trigger Serviio to transcode the EAC3 tracks to AC3?
Note - my receiver can't handle DD+ so digital passthrough is not an option.
I'm running Serviio 1.9.
guitarboy wrote:I'm streaming to the Panasonic BDT-220 with the corresponding profile. It works fine for audio tracks encoded for AC3 but not for tracks encoded as EAC3 (DD+).
atc98092 wrote:
Which profile are you using?
freaknik wrote:Can you link to your panasonic support forum thread please in case someone else here has the same issue?
Complete name : E:\cartoons\Dragon Ball Super\Dragon Ball Super Season 05\Dragon Ball Super 5x29.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 98.7 MiB
Duration : 23mn 22s
Overall bit rate : 590 Kbps
Encoded date : UTC 2036-02-06 06:28:16
Tagged date : UTC 2036-02-06 06:28:16
Writing application : HandBrake 0.10.2 2015060900
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 6 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 23mn 22s
Bit rate : 489 Kbps
Width : 848 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Original display aspect rat : 16:9
Frame rate mode : Variable
Frame rate : 23.976 fps
Minimum frame rate : 23.810 fps
Maximum frame rate : 24.390 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.050
Stream size : 81.8 MiB (83%)
Writing library : x264 core 142 r2479 dd79a61
Encoding settings : cabac=1 / ref=6 / deblock=1:1:1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=25.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=17500 / vbv_bufsize=17500 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:0.60
Color range : Limited
Color primaries : BT.601 NTSC
Matrix coefficients : BT.601
Format : AAC
Format profile : HE-AAC / LC
Codec ID : 40
Duration : 23mn 22s
Bit rate mode : Variable
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz / 22.05 KHz
Compression mode : Lossy
Stream size : 16.0 MiB (16%)
Title : Stereo / Stereo
Language : Japanese
Users browsing this forum: No registered users and 71 guests
