New D8000 series and Matroska
abece
Post Thu Mar 24, 2011 8:29 am
Hello! I am trying to set up 46D8000 to work with Serviio on MacBook. I have succesfully installed Serviio and most of files streams with no problems on my LED TV. But there are problems with some Matroska (*.mkv) files - I am receiving error like 'codec is not supported'. As I understand *.mkv must be transcoded and indeed if check the config file there is new profile entry (id="2") for B series with *.mkv transcoding section. The problem is that in Serviio config client in 'Status' tab 'Renderer Profile' setion I see only 1 line : <TV set IP adderess>, UE46D8000, Generic DLNA profile (but config file has many). The question is - how to create profile for D8000 series? I could dublicate B series config part, but I dont know what must be changet there. I believe the changes must be made in lines
<Detection>
<UPnPSearch>
<FriendlyName>^TV$</FriendlyName>
<ModelName>Samsung DTV DMR</ModelName>
<ModelNumber>1\.0</ModelNumber>
</UPnPSearch>
</Detection>
or in lines
<Profile id="2" name="Samsung TV (B-series)" extendsProfileId="1">
because these are the onliest lines related to SAMSUNG.
Can somebody help with values what must be put there so that Serviio takes SAMSUNG profile not Generic DLNA profile?
Post Thu Mar 24, 2011 10:01 am
Re: New D8000 series and Matroska
Oh, D series is out? nice. I'd think you should use C series profile, just click on the Generic Profile in the console and you'll be able to select others. Don't forget to Save.
It might still not work with your file, as some H264 streams are not very liked by the TV, but most are (that's why we don't transcode them)
abece
Post Thu Mar 24, 2011 10:44 am
Indeed. I have to click on 'Profile' column and then drop down with profiles appears. How could I miss that? I will post if selection of 'Samsung C series' profile helped. Let's hope. But this will be the half way at least for me as my initial target was to make it all work on Ubuntu 10.10. ;)
Post Thu Mar 24, 2011 10:53 am
In order to identify the D series properly in the future, could you install Intel tools (link in my signature, Win only) and run Device Spy. The locate your TV in the list on the left (there might be multiple entries there), right-click, Get Device Description XML and post the result here (for each in the list)? Preferably pack them all into a zip file and attach to this topic.
Post Thu Mar 24, 2011 1:03 pm
if we can get this up and runnign fast we will eb first ones to support D series and that will go along way to promote serviio :D
abece
Post Thu Mar 24, 2011 6:13 pm
I can confirm that Matroska files are working with 46D8000 when C8000 profile is selected. I also attached xml files extracted by Device Spy. Extreamly happy right now... :D Now will try to set up this on Ubuntu.
UE46D8000.zip
(3 KiB) Downloaded 910 times
Post Thu Mar 24, 2011 6:28 pm
abece wrote:I can confirm that Matroska files are working with 46D8000 when C8000 profile is selected. I also attached xml files extracted by Device Spy. Extreamly happy right now... :D Now will try to set up this on Ubuntu.
awesome so you can confirm that all your files play on a D series when the C series profiel is used ???? can you also confirm what firmware is on your device please :)
abece
Post Thu Mar 24, 2011 7:06 pm
In Menu->Support->Software Upgrade->By USB at right side is located such text: Current version: 001003 so I believe this number is firmware version. Right now I have only 7 mkvs to test and there are no problems with them. I will try to get some more test samples encoded with different codecs to test with. Maybe such test samples can be downloaded legaly? If yes, can somebody provide the link?
Post Thu Mar 24, 2011 8:04 pm
abece wrote:In Menu->Support->Software Upgrade->By USB at right side is located such text: Current version: 001003 so I believe this number is firmware version. Right now I have only 7 mkvs to test and there are no problems with them. I will try to get some more test samples encoded with different codecs to test with. Maybe such test samples can be downloaded legaly? If yes, can somebody provide the link?
yes try the search box for these forums ;)
viewtopic.php?f=5&t=608
Post Thu Mar 24, 2011 8:38 pm
Thanks for this, I've added D series detection to 0.5.2
abece
Post Fri Mar 25, 2011 10:35 am
Just found first *.mkv file which can't be played - it gives codec error. Attached ffmpeg log and MediaInfo log. Just saw 'Profile 5' and maybe this is the problem.
Sleepers-MediaInfo-log.log
(4.86 KiB) Downloaded 1122 times
Sleepers-ffmpeg-log.log
(2.27 KiB) Downloaded 1082 times
Post Fri Mar 25, 2011 10:51 am
Yes, looks like High profile with level 5.
Could you add the bit of XML to your profile as Illico described here? viewtopic.php?f=10&t=2052#p11492
It'll try to transcode it into mpeg2, so will take a lot of CPU (if it's HD)
solid54
Post Fri Mar 25, 2011 5:37 pm
I also have the D8000 series TV. Unfortunately my video files aren't working. I can get them to work with another DLNA server, just not Serviio. Here is information on one file, any ideas?
FFMPEG info
FFmpeg version 0.6-4:0.6-2ubuntu6, Copyright (c) 2000-2010 the FFmpeg developers
  built on Oct  5 2010 22:36:53 with gcc 4.4.5
  configuration: --extra-version=4:0.6-2ubuntu6 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
  WARNING: library configuration mismatch
  libavutil   configuration: --extra-version=4:0.6-2ubuntu3+medibuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-libmp3lame --enable-libfaac --enable-nonfree --enable-gpl --enable-postproc --enable-x11grab --enable-libfaad --enable-libxvid --enable-libx264 --enable-librtmp --enable-libopencore-amrnb --enable-version3 --enable-libopencore-amrwb --enable-version3 --enable-libdc1394 --enable-shared --disable-static
  libavcodec  configuration: --extra-version=4:0.6-2ubuntu3+medibuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-libmp3lame --enable-libfaac --enable-nonfree --enable-gpl --enable-postproc --enable-x11grab --enable-libfaad --enable-libxvid --enable-libx264 --enable-librtmp --enable-libopencore-amrnb --enable-version3 --enable-libopencore-amrwb --enable-version3 --enable-libdc1394 --enable-shared --disable-static
  libavformat configuration: --extra-version=4:0.6-2ubuntu3+medibuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-libmp3lame --enable-libfaac --enable-nonfree --enable-gpl --enable-postproc --enable-x11grab --enable-libfaad --enable-libxvid --enable-libx264 --enable-librtmp --enable-libopencore-amrnb --enable-version3 --enable-libopencore-amrwb --enable-version3 --enable-libdc1394 --enable-shared --disable-static
  libavdevice configuration: --extra-version=4:0.6-2ubuntu3+medibuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-vaapi --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-libmp3lame --enable-libfaac --enable-nonfree --enable-gpl --enable-postproc --enable-x11grab --enable-libfaad --enable-libxvid --enable-libx264 --enable-librtmp --enable-libopencore-amrnb --enable-version3 --enable-libopencore-amrwb --enable-version3 --enable-libdc1394 --enable-shared --disable-static
  libavutil     50.15. 1 / 50.15. 1
  libavcodec    52.72. 2 / 52.72. 2
  libavformat   52.64. 2 / 52.64. 2
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.19. 0 /  1.19. 0
  libswscale     0.11. 0 /  0.11. 0
  libpostproc   51. 2. 0 / 51. 2. 0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '*****.m4v':
    major_brand     : mp42
    minor_version   : 0
    encoder         : HandBrake svn3849 2011031801
  Duration: 02:08:12.67, start: 0.000000, bitrate: 3651 kb/s
    Stream #0.0(und): Video: h264, yuv420p, 842x368, 3199 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
    Stream #0.1(eng): Audio: ac3, 48000 Hz, 2 channels, s16, 448 kb/s
MediaInfo
Complete name                    : *****.m4v
Format                           : MPEG-4
Format profile                   : Base Media / Version 2
Codec ID                         : mp42
File size                        : 3.27 GiB
Duration                         : 2h 8mn
Overall bit rate                 : 3 651 Kbps
Encoded date                     : UTC 2011-03-23 21:39:18
Tagged date                      : UTC 2011-03-24 10:10:23
Writing application              : HandBrake svn3849 2011031801
Format profile                   : High@L3.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 6 frames
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 2h 8mn
Bit rate mode                    : Variable
Bit rate                         : 3 200 Kbps
Width                            : 842 pixels
Height                           : 368 pixels
Display aspect ratio             : 2.25:1
Frame rate mode                  : Constant
Frame rate                       : 29.970 fps
Bits/(Pixel*Frame)               : 0.345
Stream size                      : 2.87 GiB (88%)
Writing library                  : x264 core 114
Encoding settings                : cabac=1 / ref=6 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=0 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3200 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Color primaries                  : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : ac-3
Duration                         : 2h 8mn
Bit rate                         : 448 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 411 MiB (12%)
Language                         : English
Post Fri Mar 25, 2011 6:54 pm
solid54 wrote:I also have the D8000 series TV. Unfortunately my video files aren't working. I can get them to work with another DLNA server, just not Serviio. Here is information on one file, any ideas?
FFMPEG info
    major_brand     : mp42
    minor_version   : 0
MediaInfo
Format                           : MPEG-4
Codec ID                         : mp42
Duration                         : 2h 8mn
Codec ID                         : avc1
Duration                         : 2h 8mn
Width                            : 842 pixels
Height                           : 368 pixels
Format                           : AC-3
Codec ID                         : ac-3
Duration                         : 2h 8mn
Bit rate                         : 448 Kbps
Bit depth                        : 16 bits
Language                         : English
What Profile are you using? for this tv you will need to use the Samsung C series profile until the next release when a D series profile will be added..
solid54
Post Sat Mar 26, 2011 5:34 pm
I am using the Samsung series C profile. Since these same files work through a different DLNA server without transcoding, I believe they will work with my tv. I would prefer to use Serviio though.
Post Sat Mar 26, 2011 5:49 pm
solid54 wrote:I am using the Samsung series C profile. Since these same files work through a different DLNA server without transcoding, I believe they will work with my tv. I would prefer to use Serviio though.
hmm no sure on this one i thik this is a question for illico and ZIP sry..
solid54
Post Sun Mar 27, 2011 2:20 am
Thanks for the help. Looking through the log file I see something I missed before. This is probably causing my problems.
2011-03-26 20:18:10,554 WARN  [VideoDeliveryEngine] Cannot resolve DLNA format profile of the original file: *******.m4v. Message: MP4 video file ********.m4v does not match any supported DLNA profile
I got it to work using transcoding. I added the following lines to the Samsung C series profile:
<!-- transcode H264 MP4 files -->
Is there anyway to get these files to work without transcoding? The trancoding makes the video slightly choppy. Thanks.
Post Sun Mar 27, 2011 7:55 am
solid54 wrote:Thanks for the help. Looking through the log file I see something I missed before. This is probably causing my problems.
not at the current time as MP4 is not stream friendly
Post Sun Mar 27, 2011 4:49 pm
He's asking if it can be played natively ;-) It looks that the file doesn't fit into any DLNA profile (I think only SD h264 is supported with ac3 in MOV). I could make it play but it would be going around the standard. Will see - create a bitbucket ticket with link to this topic, pls.
Post Sun Mar 27, 2011 5:02 pm
zip wrote:He's asking if it can be played natively ;-) It looks that the file doesn't fit into any DLNA profile (I think only SD h264 is supported with ac3 in MOV). I could make it play but it would be going around the standard. Will see - create a bitbucket ticket with link to this topic, pls.
yer i know, they always seem to think we transcode files for the fun of it or to make life difficult, and not for the fact it wont work if it isnt transcioded. :roll: :mrgreen:
