error in mediabrowser "hlsjs video file not found"
bunkerman
Post Mon Aug 28, 2017 4:39 pm
just bought the Pro license and having problems with the mediabrowser. audio und photos are working as expected, but when trying to play videos (in different formats) i get the error "hlsjs video file not found". I didn't found any helpful information on the internet.
Hope somebody can help me with this issue, because Serviio was the only longtime solution so far working without problems on my Synology 413j.
btw I activated debug mode for the logs but serviio.log is not giving me any logs when trying to play a video.
Post Mon Aug 28, 2017 10:44 pm
Re: error in mediabrowser "hlsjs video file not found"
First try clearing your browser cache. Others have reported this worked for them.
Post Tue Aug 29, 2017 2:05 pm
It's probably ffmpeg failing. Not sure it's because the way it's been compiled for Synology or something else.
You might ask Patters on the NAS sub-forum.
bunkerman
Post Tue Aug 29, 2017 3:31 pm
@atc98092: not working, tried different browsers with same outcome
@zip: ok will do. btw: serviigo android app works with vlc player and does play the videos
nkodak
Post Tue Aug 29, 2017 8:03 pm
I'm having a similar problem getting "hlsjs video file not found". I'm doing an SSL redirect from external, but this worked fine until I upgraded to v1.9. I've already tried clearing my cache, so please don't suggest this. Also, when I review the serviio.log file, I see a lot of Java errors.
2017-08-29 16:01:07,894 WARN [DiscoverySearchResponder] Problem during DiscoverySearchResponder, response will not be sent
java.net.SocketException: Network is unreachable: Datagram send failed
at java.net.TwoStacksPlainDatagramSocketImpl.send(Native Method)
at java.net.DatagramSocket.send(DatagramSocket.java:693)
at org.serviio.util.MultiCastUtils.send(MultiCastUtils.java:109)
at org.serviio.upnp.discovery.DiscoverySearchResponder.sendReply(DiscoverySearchResponder.java:123)
at org.serviio.upnp.discovery.DiscoverySearchResponder.run(DiscoverySearchResponder.java:96)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:748)
Serviio 2.4 Pro on CentOS 9 | Roku 4K Streaming Stick | Onn Roku TV | HD & 4K TV's
nkodak
Post Sat Sep 02, 2017 4:30 pm
@zip -- I tried your beta release. It didn't fix the issue and I'm still seeing the Java errors. Below is a block of errors from the log. Not sure if any of that is from me exiting a movie that I started locally via the MediaBrowser or not, but I know externally it still doesn't work. I'm using a https://url:4343/ --> http://serviio:23424/ on my edge device, and it handles the SSL part to allow for encryption. The MediaBrowser itself work find. I can login, see all the titles, etc... just can't play anything. This did work fine before the 1.9 update.
2017-09-02 12:24:03,280 WARN [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Could not find segment file: F:\Serviio Temp\Serviio\transcoding-temp-f1a59c30444319d1e4d13e01e897e2ef.stf\segment00006.ts
2017-09-02 12:24:03,280 WARN [ServiioStatusService] HttpCodeException occurred. Returning error code 404 to the REST layer. Message: null
org.serviio.restlet.HttpCodeException
at org.serviio.upnp.service.contentdirectory.rest.resources.server.CDSRetrieveMediaServerResource.deliver(CDSRetrieveMediaServerResource.java:96)
at sun.reflect.GeneratedMethodAccessor3419.invoke(Unknown Source)
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:524)
at org.restlet.resource.ServerResource.get(ServerResource.java:743)
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:618)
at org.restlet.resource.ServerResource.doNegotiatedHandle(ServerResource.java:679)
at org.restlet.resource.ServerResource.doConditionalHandle(ServerResource.java:357)
at org.serviio.restlet.AbstractServerResource.doConditionalHandle(AbstractServerResource.java:49)
at org.serviio.restlet.AbstractProEditionServerResource.doConditionalHandle(AbstractProEditionServerResource.java:35)
at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractCDSServerResource.doConditionalHandle(AbstractCDSServerResource.java:59)
at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractRestrictedCDSServerResource.doConditionalHandle(AbstractRestrictedCDSServerResource.java:58)
at org.restlet.resource.ServerResource.handle(ServerResource.java:1014)
at org.restlet.resource.Finder.handle(Finder.java:246)
at org.restlet.routing.Filter.doHandle(Filter.java:159)
at org.restlet.routing.Filter.handle(Filter.java:206)
at org.restlet.routing.Router.doHandle(Router.java:431)
at org.restlet.routing.Router.handle(Router.java:648)
at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:155)
at org.restlet.engine.CompositeHelper.handle(CompositeHelper.java:211)
at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:84)
at org.restlet.Application.handle(Application.java:384)
at org.restlet.Component.handle(Component.java:406)
at org.restlet.Server.handle(Server.java:516)
at org.restlet.engine.connector.ServerHelper.handle(ServerHelper.java:72)
at org.restlet.engine.adapter.HttpServerHelper.handle(HttpServerHelper.java:152)
at org.restlet.ext.simple.internal.SimpleContainer.handle(SimpleContainer.java:80)
at org.simpleframework.http.core.Dispatcher.dispatch(Dispatcher.java:121)
at org.simpleframework.http.core.Dispatcher.run(Dispatcher.java:103)
2017-09-02 12:24:36,657 WARN [DiscoverySearchResponder] Problem during DiscoverySearchResponder, response will not be sent
2017-09-02 12:24:38,336 WARN [DiscoverySearchResponder] Problem during DiscoverySearchResponder, response will not be sent
Post Mon Sep 04, 2017 12:36 pm
It could be several reasons. I'd need the complete detailed log of trying to play the file.
remlei
Post Tue Sep 05, 2017 10:47 pm
probably the processor from the server side where serviio is running wasnt fast enough to catch up with the timeout.
managed to fixed it on browser level (firebug), basically just adding some sort of delay before playing the media, of course this is much like a workaround rather than fix since this should be handled on the server side to tell to the client to wait.
Post Wed Sep 06, 2017 9:38 am
bunkerman
Post Wed Sep 06, 2017 10:58 am
so, I would like to help. could somebody tell me where and which logs you need (because the serviio logs did'nt contain anything, or I have to tweak permissions...).
Post Thu Sep 07, 2017 10:19 am
you could turn on Dev tools in Chrome, go to the Network tab and try to open the video in MediaBrowser. then post the network call details here (there will be many, and some of them will include calls or the Manifest files etc).
Serviio logs here here: detailed log
bunkerman
Post Thu Sep 07, 2017 2:00 pm
this is what the dev tools are showing (get process is aborting after 10s, so @remlei thought on the timeout seems not bad):
http://x.x.x.x:23424/cds/resource/93231 ... diaBrowser
GET /cds/resource/93231/MANIFEST/HLS-0/MEDIUM.m3u8?profile=html5&authToken=&clientName=MediaBrowser HTTP/1.1
Host: x.x.x.x:23424
Connection: keep-alive
User-Agent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.105 Safari/537.36 Vivaldi/1.92.917.43
Accept: */*
Referer: http://x.x.x.x:23424/mediabrowser/
Accept-Encoding: gzip, deflate
Accept-Language: en-US,en;q=0.8
HTTP/1.1 200 OK
Content-Length: 211
Content-Type: application/x-mpegurl
Cache-Control: no-cache
Date: Thu, 07 Sep 2017 13:49:38 GMT
Accept-Ranges: bytes
Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.9
Access-Control-Allow-Origin: *
data:application/x-mpegurl;base64,I0VYVE0zVQojRVhULVgtU1RSRUFNLUlORjpQUk9HUkFNLUlEPTEsIEJBTkRXSURUSD0xNjAwMDAwCmh0dHA6Ly8xOTIuMTY4LjAuMzoyMzQyNC9jZHMvcmVzb3VyY2UvOTMyMzEvTUVESUFfSVRFTS9ITFMtMC9NRURJVU0ubTN1OD9wcm9maWxlPWh0bWw1JmNsaWVudE5hbWU9TWVkaWFCcm93c2VyJmF1dGhUb2tlbj0zOTc1YzgxZTdkOWY0ZjVkYWI3YzE4MGIxOWY4MTVkMg==
http://x.x.x.x:23424/cds/resource/93231 ... authToken=
Request URL:http://x.x.x.x:23424/cds/resource/93231/MEDIA_ITEM/HLS-0/MEDIUM.m3u8?profile=html5&clientName=MediaBrowser&authToken=
Referrer Policy:no-referrer-when-downgrade
Request Headers
Provisional headers are shown
Referer:http://x.x.x.x:23424/mediabrowser/
User-Agent:Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.105 Safari/537.36 Vivaldi/1.92.917.43
Query String Parameters
profile:html5
clientName:MediaBrowser
authToken:
nkodak
Post Fri Sep 08, 2017 1:27 pm
@zip
OK, after a lot of poking and some updates and reboots, it actually worked externally on the last attempt, so it may be a process load issue on my end. I've been meaning to do an upgrade on some of these systems, so I'll keep an eye on things, but the 1.9.1 beta patch did fix the actual connection issue.
I have NOT checked the logs to see if all the Java errors have resolved themselves or not. Just wanted to give you an update on my situation.
Thanks!
martianw
Post Tue Oct 24, 2017 5:42 pm
I have the same problem. Started occurring after upgrading to 1.9. From the thread, it's not clear to me what the solution is.
CPU on the server never dips below about 85% idle and the desktop machine I'm running the browser on is a fairly high end machine spec'd for music production.
serviio.log contains a Java stacktrace with the message "[ServiioStatusService] IOException occurred. Returning error code 500 to the REST layer. Message: Transcoded file '/tmp/Serviio/transcoding-temp-5d5543d4e440ac4d25f746261b6794b6.stf/playlist.m3u8' cannot be found, FFmpeg execution probably failed"
Post Wed Oct 25, 2017 12:46 pm
can you enable detailed log and try again, then post the log file?
martianw
Post Wed Oct 25, 2017 4:28 pm
Absolutely. Thanks for the quick response.
(188.55 KiB) Downloaded 1842 times
Post Thu Oct 26, 2017 8:27 am
Are you using the bundled ffmpeg? Looks like our ffmpeg is either too old or too new ;-)
martianw
Post Thu Oct 26, 2017 8:37 am
Yes, I believe so. I don't recall installing it myself. That said, you never know. Does this help?
ffmpeg version git-2012-12-15-75b7e54 Copyright (c) 2000-2012 the FFmpeg developers
  built on Dec 15 2012 12:28:47 with gcc 4.4.3 (Ubuntu 4.4.3-4ubuntu5.1)
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-nonfree --enable-version3 --enable-x11grab
  libavutil      52. 12.100 / 52. 12.100
  libavcodec     54. 80.100 / 54. 80.100
  libavformat    54. 49.102 / 54. 49.102
  libavdevice    54.  3.102 / 54.  3.102
  libavfilter     3. 27.101 /  3. 27.101
  libswscale      2.  1.103 /  2.  1.103
  libpostproc    52.  2.100 / 52.  2.100
Post Thu Oct 26, 2017 3:56 pm
it's from 2012. on linux you should either build one from sources (links to sources on serviio download page) or get the latest from some repo
martianw
Post Thu Oct 26, 2017 4:10 pm
OK. Looks like I'll need to build from source then:
sudo apt-get install --only-upgrade ffmpeg
[sudo] password for martin:
Reading package lists... Done
Building dependency tree
Reading state information... Done
ffmpeg is already the newest version.
Users browsing this forum: No registered users and 110 guests
