Subtitle Config / Multiple Streams
DrSuSE
Post Sat Sep 09, 2017 2:41 am
Hi guys! New to Serviio, tried to search for the answer on my own but came up short...
I think this is a config issue, not a player issue... but I am playing this on a Samsung H6350 series TV (assigned the E/F profile by default).
I am trying to play MKV files with embedded ASS subtitles. The issue is that there are 2 streams (streams 3 and 4), both ENG. Stream 3 (default in the file per ffmpeg) is only for "signs/songs" where as stream 4 is what I really want ("full subs").
How do I tell Serviio which stream to use? I tried checking/unchecking about every combination of boxes in Languages & Subtitles sections of the console.
Help appreciated in advance, thank you.
lagunaa
Post Wed Sep 13, 2017 8:52 am
Re: Subtitle Config / Multiple Streams
DrSuSE wrote:The issue is that there are 2 streams (streams 3 and 4), both ENG. Stream 3 (default in the file per ffmpeg) is only for "signs/songs" where as stream 4 is what I really want ("full subs").
I think it could be related to ticket https://bitbucket.org/xnejp03/serviio/i ... les-marked. And maybe it depends on the device you are using if it supports multi tracks selection for subs.
