Noob transcoding question for Yamaha RX Reciever
Dusty311
Post Sun Oct 01, 2017 12:35 am
Hello all. I have tried a few different profile additions to the XML in the config of the Serviio installation but for the life of me I can't seem to figure out how to simply add the ability to transcode a few file types that are not already decoded by my receiver (an RX-V681). I only wish to add in a function/profile to transcode things like WavPack, MusePack and Monkey's Audio. I've been using an XML editor to validate entries but I just can't seem to get it. Any help would be appreciated. Thanks in advance.
Post Sun Oct 01, 2017 12:48 am
Re: Noob transcoding question for Yamaha RX Reciever
Dusty311 wrote:Hello all. I have tried a few different profile additions to the XML in the config of the Serviio installation but for the life of me I can't seem to figure out how to simply add the ability to transcode a few file types that are not already decoded by my receiver (an RX-V681). I only wish to add in a function/profile to transcode things like WavPack, MusePack and Monkey's Audio. I've been using an XML editor to validate entries but I just can't seem to get it. Any help would be appreciated. Thanks in advance.
Have you looked at this page? http://www.serviio.org/index.php?option ... icle&id=24
There is a section about audio transcoding profiles. The examples listed are the only supported codecs. It's possible that the codecs you mention (WavPack, MusePack and Monkey's Audio) might not be supported. I'm not familiar with them, so can't say for sure how to match them.
