Upgrade Serviio 2.0?
tagaz
Post Mon Feb 22, 2016 9:40 pm
Hi there,
I was just wondering when a new major upgrade is planned. I like to support your work and buy a licence key, but I wouldn't like to buy a licence and realize that within a month or so a major upgrade is released and I loose my pro licence (as it says on the 'buy pro' webpage).
Post Mon Feb 22, 2016 10:34 pm
Re: Upgrade Serviio 2.0?
There is no major version planned.
Lofi
Post Sun Oct 01, 2017 5:38 am
zip wrote:There is no major version planned.
Is there still no version 2.0 planned? Honestly, the comment on the website held me back from buying. I've been using serviio for months now and thought I should support your great work, even though the free version is enough for me. I only held back for version 2. If there is no version 2 planned, maybe you should remove that comment on your website, probably others think the same.
Post Sun Oct 01, 2017 7:32 pm
I assume you mean this quote:
The license does not entitle you to a free upgrade to a new major release, e.g. 2.0
I suppose Zip could add that there is no timeframe for such a release. But I suspect that he will make it clear when something like that is on the horizon.
Post Tue Oct 03, 2017 9:06 am
Will remove the comment. thanks.
Lofi
Post Tue Oct 03, 2017 4:50 pm
zip wrote:Will remove the comment. thanks.
Great! You get another sale in 5 minutes :D
