Serviio 1.9 with Windows Server 2016 Core
japes
Post Wed Oct 04, 2017 12:10 pm
I 've installed Serviio 1.9 with a core version of windows server 2016.
But if I start the serviio console, an error occurs: .."Cannot connect to the server, it doesn't seem to be running..."
sc query serviio --> service stopped
sc start serviio -> start pending
what can I do for serviio service running? :-/
notice: ffmpeg error in logfile...serviio installation works fine without errors. ffmpeg.exe is still present in \lib
thx
best regards
serviio log
2017-10-04 15:28:56,714 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2017-10-04 15:28:56,714 INFO  [MediaServer] ------------------------------------------------------------------------
2017-10-04 15:28:56,714 INFO  [MediaServer] Serviio DLNA media streaming server v 1.9 (rev. a39231b8b876)
2017-10-04 15:28:56,714 INFO  [MediaServer] Petr Nejedly 2009-2017
2017-10-04 15:28:56,714 INFO  [MediaServer] http://www.serviio.org
2017-10-04 15:28:56,714 INFO  [MediaServer] Java 1.8.0_131-Oracle Corporation x86
2017-10-04 15:28:56,714 INFO  [MediaServer] OS Windows Server 2016 10.0
2017-10-04 15:28:56,714 INFO  [MediaServer] File encoding: windows-1252
2017-10-04 15:28:56,886 INFO  [MediaServer] Headless mode enabled: true
2017-10-04 15:28:56,886 INFO  [MediaServer] User: HP-SERVER$
2017-10-04 15:28:56,886 INFO  [MediaServer] User home dir: C:\Windows\system32\config\systemprofile
2017-10-04 15:28:56,886 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2017-10-04 15:28:56,886 INFO  [MediaServer] ------------------------------------------------------------------------
2017-10-04 15:28:56,901 DEBUG [MediaServer] Runtime params: -Dexe4j.semaphoreName=Local\c:_program_files_pc5dczc_bin_serviioservice.exe0, -Dexe4j.isService=true, -Dexe4j.moduleName=C:\Program Files\Serviio\bin\ServiioService.exe, -Dexe4j.tempDir=C:\Windows\TEMP\e4j9A8D.tmp_dir1507123735, -Dexe4j.unextractedPosition=413627, -Djava.library.path=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\WindowsApps;c:\program files\serviio\jre\bin, -Dexe4j.consoleCodepage=cp0, -Xms20M, -XX:+UseG1GC, -XX:GCTimeRatio=1, -XX:MinHeapFreeRatio=10, -XX:MaxHeapFreeRatio=20, -Djava.net.preferIPv4Stack=true, -Djava.awt.headless=true, -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade, -Dserviio.home=C:\Program Files\Serviio\bin\\.., -Dderby.system.home=C:\Program Files\Serviio\bin\\..\library, -Xmx512m, -Xrs
2017-10-04 15:28:56,933 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2017-10-04 15:28:56,995 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2017-10-04 15:28:56,995 INFO  [DatabaseManager] Using DERBY database language
2017-10-04 15:28:58,745 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2017-10-04 15:28:58,745 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2017-10-04 15:28:58,745 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2017-10-04 15:28:58,761 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2017-10-04 15:28:58,761 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2017-10-04 15:28:58,761 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2017-10-04 15:28:58,761 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2017-10-04 15:28:58,761 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2017-10-04 15:28:58,761 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2017-10-04 15:28:58,761 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2017-10-04 15:28:58,776 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2017-10-04 15:28:58,776 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2017-10-04 15:28:58,776 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2017-10-04 15:28:58,776 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2017-10-04 15:28:58,776 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2017-10-04 15:28:58,776 DEBUG [DBLogDAOImpl] Checking if script 'script-1.3.sql' has been run
2017-10-04 15:28:58,776 DEBUG [DBLogDAOImpl] Checking if script 'script-1.4.sql' has been run
2017-10-04 15:28:58,776 DEBUG [DBLogDAOImpl] Checking if script 'script-1.5.sql' has been run
2017-10-04 15:28:58,792 DEBUG [DBLogDAOImpl] Checking if script 'script-1.6.sql' has been run
2017-10-04 15:28:58,792 DEBUG [DBLogDAOImpl] Checking if script 'script-1.7.sql' has been run
2017-10-04 15:28:58,792 DEBUG [DBLogDAOImpl] Checking if script 'script-1.8.sql' has been run
2017-10-04 15:28:58,792 DEBUG [DBLogDAOImpl] Checking if script 'script-1.9.sql' has been run
2017-10-04 15:28:59,011 INFO  [WebServer] Socket buffer set to 65535 bytes
2017-10-04 15:28:59,011 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2017-10-04 15:28:59,026 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2017-10-04 15:28:59,026 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2017-10-04 15:28:59,026 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
2017-10-04 15:28:59,933 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/cds) exposed on port 23424
2017-10-04 15:28:59,933 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/mediabrowser) exposed on port 23424
2017-10-04 15:28:59,933 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/cds) exposed on port 23524
2017-10-04 15:28:59,933 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/mediabrowser) exposed on port 23524
2017-10-04 15:29:00,058 DEBUG [LicensingManager] Updating license
2017-10-04 15:29:00,058 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2017-10-04 15:29:00,089 DEBUG [LicenseValidator] Validating license file (348 bytes)
2017-10-04 15:29:00,214 INFO  [MediaServer] ------------------------------------------------------------------------
2017-10-04 15:29:00,214 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2017-10-04 15:29:00,214 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2017-10-04 15:29:00,323 INFO  [Device] Created UPnP Device with UUID: 2888761c-69cb-34ac-91c9-f04507383e6d, bound address: 192.168.178.100
2017-10-04 15:29:00,511 INFO  [ProfileManager] Loading profiles from file /profiles.xml
2017-10-04 15:29:01,089 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2017-10-04 15:29:01,089 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2017-10-04 15:29:01,182 INFO  [CustomisationManager] No customisation properties found
2017-10-04 15:29:01,292 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2017-10-04 15:29:01,292 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2017-10-04 15:29:01,323 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2017-10-04 15:29:01,323 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2017-10-04 15:29:01,323 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2017-10-04 15:29:01,323 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2017-10-04 15:29:01,323 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2017-10-04 15:29:01,323 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile ps4
2017-10-04 15:29:01,339 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 4' (id=ps4)
2017-10-04 15:29:01,339 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2017-10-04 15:29:01,339 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2017-10-04 15:29:01,339 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2017-10-04 15:29:01,339 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2017-10-04 15:29:01,339 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_h
2017-10-04 15:29:01,339 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2017-10-04 15:29:01,339 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_j
2017-10-04 15:29:01,354 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (J-series)' (id=sam_j)
2017-10-04 15:29:01,354 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_ef
2017-10-04 15:29:01,354 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2017-10-04 15:29:01,354 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2017-10-04 15:29:01,354 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2017-10-04 15:29:01,354 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2017-10-04 15:29:01,354 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2017-10-04 15:29:01,354 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2017-10-04 15:29:01,354 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2017-10-04 15:29:01,354 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2013
2017-10-04 15:29:01,354 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2017-10-04 15:29:01,354 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2013
2017-10-04 15:29:01,354 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2017-10-04 15:29:01,354 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2017-10-04 15:29:01,370 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2017-10-04 15:29:01,370 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2017-10-04 15:29:01,370 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2017-10-04 15:29:01,370 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2017-10-04 15:29:01,370 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2017-10-04 15:29:01,370 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2017-10-04 15:29:01,370 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2017-10-04 15:29:01,370 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2017-10-04 15:29:01,370 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2017-10-04 15:29:01,370 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile tosh2012
2017-10-04 15:29:01,370 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2017-10-04 15:29:01,370 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2017-10-04 15:29:01,370 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2017-10-04 15:29:01,370 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2017-10-04 15:29:01,370 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2017-10-04 15:29:01,370 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2017-10-04 15:29:01,370 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2017-10-04 15:29:01,370 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2017-10-04 15:29:01,370 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2017-10-04 15:29:01,370 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2017-10-04 15:29:01,386 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2017-10-04 15:29:01,386 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2017-10-04 15:29:01,386 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2017-10-04 15:29:01,386 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2017-10-04 15:29:01,386 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2017-10-04 15:29:01,386 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2017-10-04 15:29:01,386 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2017-10-04 15:29:01,386 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2017-10-04 15:29:01,386 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2017-10-04 15:29:01,386 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2017-10-04 15:29:01,386 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2017-10-04 15:29:01,386 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2017-10-04 15:29:01,401 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2017-10-04 15:29:01,401 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2013
2017-10-04 15:29:01,401 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2017-10-04 15:29:01,401 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2017-10-04 15:29:01,401 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2017-10-04 15:29:01,417 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2017-10-04 15:29:01,417 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2009
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2009)' (id=viera2009)
2017-10-04 15:29:01,417 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2017-10-04 15:29:01,417 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2017-10-04 15:29:01,417 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2017-10-04 15:29:01,417 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2017-10-04 15:29:01,417 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2017-10-04 15:29:01,417 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile panasonicBDT220
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2017-10-04 15:29:01,417 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile philips_streamium
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2017-10-04 15:29:01,417 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile roku
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2017-10-04 15:29:01,417 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuMPApp
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2017-10-04 15:29:01,417 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile Roku4kMPApp
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Roku 4K Media Player (2016+)' (id=Roku4kMPApp)
2017-10-04 15:29:01,417 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuNo4kApp
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Roku 1080 Media Player (2016+)' (id=RokuNo4kApp)
2017-10-04 15:29:01,417 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuTV
2017-10-04 15:29:01,417 INFO  [ProfilesDefinitionParser] Added profile 'Roku TV (non 4K)' (id=RokuTV)
2017-10-04 15:29:01,432 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile Roku4kTV
2017-10-04 15:29:01,432 INFO  [ProfilesDefinitionParser] Added profile 'Roku 4K TV' (id=Roku4kTV)
2017-10-04 15:29:01,432 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile YamBD
2017-10-04 15:29:01,432 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2017-10-04 15:29:01,432 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile TNDC
2017-10-04 15:29:01,432 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2017-10-04 15:29:01,432 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile xbox_one
2017-10-04 15:29:01,432 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2017-10-04 15:29:01,432 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile raumfeld
2017-10-04 15:29:01,432 INFO  [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2017-10-04 15:29:01,432 INFO  [ProfileManager] Loading profiles from file /application-profiles.xml
2017-10-04 15:29:01,511 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2017-10-04 15:29:01,511 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2017-10-04 15:29:01,511 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2017-10-04 15:29:01,526 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile html5
2017-10-04 15:29:01,526 INFO  [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2017-10-04 15:29:01,526 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_standard
2017-10-04 15:29:01,526 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2017-10-04 15:29:01,526 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2017-10-04 15:29:01,526 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_hls
2017-10-04 15:29:01,526 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2017-10-04 15:29:01,526 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_gtv
2017-10-04 15:29:01,526 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2017-10-04 15:29:01,526 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile googlecast
2017-10-04 15:29:01,526 INFO  [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2017-10-04 15:29:01,526 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile chromecast
2017-10-04 15:29:01,526 INFO  [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2017-10-04 15:29:01,526 INFO  [ProfileManager] User profiles definition (user-profiles.xml) not found, using built-in profiles only
2017-10-04 15:29:01,589 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2017-10-04 15:29:01,589 INFO  [PluginCompilerThread] Started looking for plugins
2017-10-04 15:29:01,604 INFO  [UpdateChecker] Checking if a new version is available
2017-10-04 15:29:01,620 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe
2017-10-04 15:29:01,620 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe
2017-10-04 15:29:01,745 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: FFMPEG not found. Serviio will not work properly.
java.lang.ExceptionInInitializerError
   at org.serviio.MediaServer.main(MediaServer.java:145)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
   at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:62)
   at com.exe4j.runtime.WinLauncher$2.run(WinLauncher.java:96)
Caused by: java.lang.RuntimeException: FFMPEG not found. Serviio will not work properly.
   at org.serviio.external.FFMPEGWrapper.loadFFmpegInfo(FFMPEGWrapper.java:138)
   at org.serviio.external.FFMPEGWrapper.<clinit>(FFMPEGWrapper.java:111)
   ... 7 more
2017-10-04 15:29:01,761 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2017-10-04 15:29:01,761 WARN  [IndexedDiskCache] Region [subtitles_metadata] Disk cache not shutdown properly, shutting down now.
2017-10-04 15:29:01,761 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2017-10-04 15:29:01,761 WARN  [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2017-10-04 15:29:01,761 WARN  [IndexedDiskCache] Region [subtitles] Disk cache not shutdown properly, shutting down now.
2017-10-04 15:29:02,011 INFO  [TrakttvService] Started trakt.tv sync updater
2017-10-04 15:29:02,011 INFO  [TrakttvService] Started trakt.tv scrobble poster
2017-10-04 15:29:02,042 INFO  [FileDeltaWatcher] Using 'sun.nio.fs.WindowsWatchService' for delta scan
2017-10-04 15:29:02,057 INFO  [LibraryOneTimeScanner] Interrupting library scan
2017-10-04 15:29:02,057 DEBUG [LibraryOneTimeScanner] Library scan has been interrupted
2017-10-04 15:29:02,057 INFO  [PluginCompilerThread] Finished looking for plugins
2017-10-04 15:29:02,198 INFO  [SearchManager] Starting up search engine
2017-10-04 15:29:02,620 INFO  [SearchIndexer] Closing search index writer
2017-10-04 15:29:02,682 INFO  [PlaybackProgressUpdater] Started playback progress updater
2017-10-04 15:29:02,698 INFO  [RendererSearchSender] Stopping Renderer searcher process
Post Wed Oct 04, 2017 2:55 pm
Re: Serviio 1.9 with Windows Server 2016 Core
Per the log, it isn't seeing ffmpeg.exe in the Serviio/lib folder. Are you certain the file (with that exact name) is in the proper folder? If so, I suggest downloading the latest 64 bit version of ffmpeg here (https://ffmpeg.zeranoe.com/builds/). Rename the existing file and then copy ffmpeg.exe into the folder. I regularly change the ffmpeg to a 64 bit version. Since you are running Server 2016, it might not like the 32 bit version.
japes
Post Wed Oct 04, 2017 10:23 pm
Hi and thx :) It seems that a Server Core Installation have no WOW64 Support. That means no 32bit Applications will work. If the original ffmpeg.exe (comes with serviio) is 32bit...then you are right. I will test with the downloaded latest 64bit version 3.3.3.
thx dude
regards
Post Thu Oct 05, 2017 10:39 am
Yes, Serviio ships with the 32 bit version of ffmpeg. There are still enough people running 32 bit Windows that he can't switch over yet.
japes
Post Thu Oct 05, 2017 11:56 am
:-/ don't work.
ServerCore-WOW64 ist installed at the Core Testsystem. (I failed...because WOW64 is supported @Server Core too)
The Logfile tells me FFMPEG not found..but it is in \lib. xcopy 64bit version of ffmpeg and overwrite the standard ffmpeg file was done.
Maybe it's not possible at this time to use Serviio with a Core Installation of Windows Server (2016)
Thx Dan for Help :)
Best regards from germany
Post Thu Oct 05, 2017 2:39 pm
Huh, that's strange. I suppose there could be something about the Core install. I've tried it on Home Server 2011 without issue, and that too was an x64 OS. Of course, it was a full GUI install.
I have another idea. Microsoft has made changes in recent years to have some program files install under the user account folders. For example, some of the programs I wrote for the FAA years ago were first created when we were using Windows 2000 and XP. All application data installed to the install folder under C:\Program Files. Now under Windows 7 (and after I had built new .NET versions of the programs), some of the files install to c:\program files (x86), while others install under c:\users\USER_NAME\appdata\local. Take a look under the user account you were using when you installed Serviio, under appdata, and check both the Local and Roaming folders. See if there's a Serviio folder there. probably not, but worth a look. If you find a \lib folder, stick ffmpeg.exe in there and try again. :D
japes
Post Thu Oct 05, 2017 7:43 pm
Hmmmm....the Core Testsystem was kicked off by me today :-D Now I have the "normal" Standard Server with GUI an Serviio works without any Problems.
Thx Dan :)
maybe I will try it in the Future ones more
jrtolle
Post Mon Oct 30, 2017 8:58 pm
As a note to future users who might try this, Serviio works fine on Win Server 2016 Core. I have been running it for months in this configuration. I have ffmpeg v3.2.4 (x86 build) in the lib folder. That is likely the bundled version with Serviio v1.9. i did NOT try running a x64 build without WOW64, but I have other programs on this system that require the WOW64 subsystem anyways. I do believe I had to copy some dlls from a GUI system to get ffmpeg to work properly. It calls out to some dlls that are not installed on Core, but if copied over, ffmpeg runs fine. I cannot find my folders where I saved them, so to find out which ones, run Procmon targeting ffmpeg.exe to see which files it is looking for that it fails to find. Copy those files (and the appropriate language file from system32\en-us or your system language code) into the system32 folder (and en-us/language folder).
JR
VLun
Post Mon Jan 01, 2018 10:54 am
ffmpeg crash if not find: avicap32.dll, msvfw32.dll
find this files on another OS and copy to system32
japes
Post Thu Jan 04, 2018 7:17 pm
oh works fine, but not from system32...it must be copied from the syswow64 directory of win10 to the syswow64 of the core server
thx a lot. now i can use Serviio with my Core Server :) Serviio 1.9.1 beta standard installation procedure + this 2 files from syswow64 directory. no other workaround is needed.
EDIT: it's not possible to activate serviio with my licensefile. serviio crashes. i think its because core server does have no explorer.exe, which is needed for choose the license. :/
RESOLVED: must be activated from another computer remote. URL is 'http://IP Address:23423/console/#/app/welcome'
