Check stream URL fails
lagunaa
Post Fri Oct 06, 2017 9:50 am
I updated Serviio to latest stable version v1.9 and now checking the stream URL always fails for online resources. Only the check seems to fail because the online content then plays correctly.
I don't see any log entries for these check calls to try to understand what's the cause...
Any advice?
Thanks in advance.
Cheers.
Post Fri Oct 06, 2017 1:50 pm
Re: Check stream URL fails
an example URL you're checking?
lagunaa
Post Tue Oct 10, 2017 12:04 pm
For example, I installed the HD-Trailers plug-in and set the source URL as http://www.hd-trailers.net/page/1/ for the online resource.
Thanks in advance for your help.
Cheers.
Post Wed Oct 11, 2017 8:25 am
for plugins, you have to select either rss feed or web content plugin, not live stream.
Also, I'm not sure if this plugin still works
lagunaa
Post Wed Oct 11, 2017 9:05 am
zip wrote:for plugins, you have to select either rss feed or web content plugin, not live stream.
Of course, zip.
zip wrote:Also, I'm not sure if this plugin still works
This plug-in is still working, only checking the stream URL on Serviio console is failing.
Cheers.
Post Wed Oct 11, 2017 1:59 pm
The Check Stream URL button should only be available when you are adding a live stream type of online source..
lagunaa
Post Thu Oct 12, 2017 5:16 pm
Oh, I see. That's why checking the stream URL for a web contents fails, then. (Maybe you should disable that button in these cases?)
Thank you for your support.
Cheers.
Users browsing this forum: Baidu [Spider] and 30 guests
