node.dll update?
Sparky
Post Wed Oct 11, 2017 11:37 am
node.dll update?
I've had Serviio running on v1.5.2 for ages and after the last Windows "version update" which reset the bound NIC I decided to update to 1.9.
I also run Secunia and it shows that node.dll is out of date. The installer came with 7.4.0 and the current version 7 is 7.10.1. Version 8 is up to 8.6.0. Is there an updated dll available...?
I've been to the Nodes.js site but can't find a node.dll replacement there in the various builds. I am reluctant to just download a node.dll from a random dll site.
The console doesn't run without it, which isn't a big problem as I don't use the console often. I can rename the dll until I need the console, but it's just something else to remember.
Windows 10 Pro 64-bit, Asus Sabertooth P67, Core i7-2600 3.4GHz, 16Gb DDR3-14900, Nvidia GeForce 8800GT 512Mb, HL-DT-ST GH22LS50, System: Intel SSD 520 Series 240Gb, VM: Intel SSD 330 Series 240Gb, Data: Seagate Barracuda ST31500341AS 1500GB 32Mb Cache, DLNA: Hitachi Deskstar P7K500 320GB 16Mb Cache
Samsung UE48H6400, Sony BDP-S490, PlayStation 3, Xbox 360, Xbox One.
Post Wed Oct 11, 2017 1:58 pm
Re: node.dll update?
It's provided by the web wrapper framework for the console. Not something I provide. Perhaps it'll be updated when I update the console build tools. I'd doubt though that it's a problem.
Sparky
Post Wed Oct 11, 2017 2:51 pm
Thanks Zip.
I did a search which mentioned that installing without the console and using a localhost URL provide the same function. Can I re-run the install to remove the console or is it an uninstall/reinstall.? If the latter is there a config backup I can do..?
Is it possible to remotely access the console? By browsing to http://<my machine>:23423 from another machine, or is it only possible from localhost?
Post Wed Oct 11, 2017 8:39 pm
Sparky wrote:Thanks Zip.
I think running the installer should work.
yes, remotely is possible.
Sparky
Post Wed Oct 11, 2017 9:36 pm
zip wrote: I think running the installer should work.
Quite right, it did.
The start menu shortcut is still there but opens the web console instead. A quick convert of the Serviio logo into an icon to restore a familiar look and you'd never know the difference...!
Thanks again Zip, much appreciated.
Users browsing this forum: Baidu [Spider] and 52 guests
