Serviio on Debian
AQUSTIQ
Post Thu Oct 12, 2017 6:39 pm
Serviio on Debian
Can somebody explain me why on CentOS 7 it works fine and in Debian 9 I have problem on my LG TV with "unstable network connection" and When I start video after 1 min I'm getting "network disconnect"?
FFMPEG the same: https://johnvansickle.com/ffmpeg/releas ... tic.tar.xz
Java the same: openjdk-8-jre
Serviio files the same: version 1.9
Derby Log:
Thu Oct 12 15:57:39 EDT 2017:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.12.1.1 - (1704137): instance XX(edited)XX
on database directory /apps/serviio/library/db with class loader sun.misc.Launcher$AppClassLoader@135fbaa4
Loaded from file:/apps/serviio/lib/derby.jar
java.vendor=Oracle Corporation
java.runtime.version=1.8.0_141-8u141-b15-1~deb9u1-b15
user.dir=/
os.name=Linux
os.arch=amd64
os.version=4.9.0-4-amd64
derby.system.home=/apps/serviio/library
derby.stream.error.file=../log/derby.log
Database Class Loader started - derby.database.classpath=''
AQUSTIQ
Post Thu Oct 12, 2017 8:11 pm
Re: Serviio on Debian
The alone WARN what I have in logs is:
2017-10-12 15:58:03,024 WARN [UserDataUpdater] There was an error updating user data
java.net.SocketTimeoutException: connect timed out
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at sun.net.NetworkClient.doConnect(NetworkClient.java:175)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:242)
at sun.net.www.http.HttpClient.New(HttpClient.java:339)
at sun.net.www.http.HttpClient.New(HttpClient.java:357)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1202)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1138)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1032)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:966)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1546)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1474)
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480)
at org.serviio.util.HttpClient.retrieveStreamFromConnection(HttpClient.java:173)
at org.serviio.util.HttpClient.getStreamFromURL(HttpClient.java:103)
at org.serviio.util.HttpClient.retrieveTextFileFromURL(HttpClient.java:42)
at org.serviio.upnp.service.contentdirectory.rest.access.TuqPortCheckerProvider.isPortOpen(TuqPortCheckerProvider.java:20)
at org.serviio.upnp.service.contentdirectory.rest.access.PortMappingChecker.isPortOpen(PortMappingChecker.java:39)
at org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater.isSSLPortOpen(UserDataUpdater.java:178)
at org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater.doUpdateUserData(UserDataUpdater.java:101)
at java.lang.Thread.run(Thread.java:748)
2017-10-12 15:58:03,032 INFO [UserDataUpdater] Updating user data
Could it be related to my issue?
Post Thu Oct 12, 2017 8:55 pm
no this is not the problem.
AQUSTIQ
Post Sun Oct 15, 2017 2:07 am
OK. Seems like I have isolated my problem. I connected one of my LG TV to WiFi (Tp_link EAP245) and I can access internet without problem.
Once TV is on in serviio logs I begin to receive:
WARN [RendererManager] Error while retrieving renderer description: connect timed out
When this TV was wired connected I didn't have any problems.
I have another older LG TV wired connected. If I turn on only wired connected TV serviio works fine. If turn on both TV serviio on wired connected TV is very slow.
Seems like serviio has a big problem to work with wireless connected devices. Zip, do you have any tricks for this?
Post Sun Oct 15, 2017 6:30 pm
It's all Java based, I don't use any tricks.
Make sure you bind Serviio to the right NIC in the console.
Return to User experiences
