Transcoded Videos stops
PC: Intel i5-7200u, gtx 940mx, 8gb ddr4, Atheros/Qualcomm QCA9377 802.11ac
Router: Linksys EA7500ac
Device: LG Smart TV.
Pls help.
atc98092 wrote:Need more info please. What profile are you using for your player, and what are the codecs within the video that won't play correctly? You can get the codec information with ffmpeg at the command line. You enter ffmpeg -i file_name and then copy the information here. You probably need to type the full path to ffmpeg (on Windows, it's C:\Program Files\Serviio\lib\ffmpeg.exe by default). Also, if either the path and/or the file name have spaces in them, you need to enclose the path or file name in quotes. ("C:\program files\Serviio\lib\ffmpeg.exe" -i "J:\videos\Star Wars (1977).mkv")
ffmpeg version 3.2.4 Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 4.9.3 (GCC)
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enable-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config --bindir='/jenkins/workspace/FFmpeg - Win32/target'
libavutil 55. 34.101 / 55. 34.101
libavcodec 57. 64.101 / 57. 64.101
libavformat 57. 56.101 / 57. 56.101
libavdevice 57. 1.100 / 57. 1.100
libavfilter 6. 65.100 / 6. 65.100
libswscale 4. 2.100 / 4. 2.100
libswresample 2. 3.100 / 2. 3.100
libpostproc 54. 1.100 / 54. 1.100
Input #0, matroska,webm, from 'C:\Users\Zaharaddeen\Downloads\Music\test.mkv':
title : Grisaia no Meikyuu: The Cocoon of Caprice 0
encoder : libebml v1.3.0 + libmatroska v1.4.0
creation_time : 2017-02-15T10:48:54.000000Z
Duration: 00:47:40.37, start: 0.000000, bitrate: 618 kb/s
Chapter #0:0: start 0.000000, end 0.000000
title : Prologue
Chapter #0:1: start 341.007000, end 341.007000
title : Part A
Chapter #0:2: start 942.024000, end 942.024000
title : Part B
Chapter #0:3: start 1311.018000, end 1311.018000
title : Part C
Chapter #0:4: start 1717.090000, end 1717.090000
title : Part D
Chapter #0:5: start 2288.036000, end 2288.036000
title : Part E
Chapter #0:6: start 2532.780000, end 2532.780000
title : Ending
Chapter #0:7: start 2622.453000, end 2622.453000
title : Epilogue
Chapter #0:8: start 2855.352000, end 2855.352000
title : Preview
Stream #0:0(eng): Video: h264 (High 10), yuv420p10le(progressive), 1280x544, SAR 1:1 DAR 40:17, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(jpn): Audio: aac (LC), 48000 Hz, stereo, fltp (default)
Stream #0:2(eng): Subtitle: ass (default)
title : Chihiro
Stream #0:3: Attachment: ttf
filename : #44 Font.ttf
mimetype : application/x-truetype-font
Stream #0:4: Attachment: ttf
filename : Casper Bold Italic.ttf
Stream #0:5: Attachment: ttf
filename : Casper Bold.ttf
Stream #0:6: Attachment: ttf
filename : DFGHSMincho-W9.ttf
Stream #0:7: Attachment: ttf
filename : IwaOMinPro-Fate-Hv.ttf
Stream #0:8: Attachment: ttf
filename : Open Sans Semibold.ttf
Stream #0:9: Attachment: ttf
filename : Plantagenet Cherokee.ttf
Stream #0:10: Attachment: ttf
filename : Playtime With Hot Toddies.ttf
Stream #0:11: Attachment: ttf
filename : Swiss 721 Medium BT.ttf
Stream #0:12: Attachment: ttf
filename : The Buns.ttf
Stream #0:13: Attachment: ttf
filename : Vani.ttf
Stream #0:14: Attachment: ttf
filename : Vegur-Bold.OTF
Stream #0:15: Attachment: ttf
filename : You Are Loved.ttf
